AWD Square body (Concept)
I was pondering the idea of making a streetable AWD square body. ANyone ever seen one that wasnt a drag truck. My idea was to take like a 2007 and up escalade (I have one which is what made me think of it.) and maybe modify the square frame with the suspension and axle setup off the front of the escalade the using a 6.2 motor and tranny to power it all. Would like to be able to keep it low to the ground at the same time. Just a thought thats been wandering around in my brain and wanted to see if anyone has heard of such a thing.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
Re: AWD Square body (Concept)
It would be a very cool project.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Seems like a lot of work, but it would be sweet. Good luck.
Posted via Mobile Device |
Getting the frame to match up with body would be the biggest challenge.
I have a current project that's kinda along these lines. Mine is a short wide dually 4WD, sits on a frame with a 1-ton front clip, cab & chassis rear (allows for much bigger tubs and wider wheels) and 1-ton dually rear end. Biggest problem is tires, I think I'm going to build custom wheels with a dually center and 15" hoops so I can use all the tires that are available for 15" rims. Engine is pump gas 565, should be around 725hp N/A. |
I think that would be a sweet project and something different. You can get the AWD drive to sit low, but would take some creativity. Here is one that Pacific Coast Customs is working on (maybe finished by now), that lays on the ground with the AWD.
You can see how they did theirs with the air ride suspension, and might help when planning yours out, if you do move forward with it. AWD Denali |
#6 | |
#7 | |
#8 | |
Gonna be interesting that's for sure.
![]() Posted via Mobile Device
Take a look at a AWD Trailblazer SS front axle setup. Would be much easier to use than grafting the AWD front suspension/axle from a truck onto your frame.
Ill have to look into that. might be a closer wheelbase match as well if i wanted to just use frame and all.
I found that GM used front and back stubs from '88 up. They weld together just about under your feet. That's how I'm mating the 1-ton 4WD front to the C&C 2WD rearend. I planned to junk the back part of the 4WD and the front part of the C&C, so I just torched mine close and cleaned 'em up with everything else out of the way, wasn't hard at all. I have mine ready to weld, just gotta get 'em to a pro's shop for welding. He's going to put my 4-link and shock brackets on at the same time, that's the hold-up at this point.
#13 | |
If I think about it, I'll shoot a couple at the shop later.
#15 |
Moderator
![]() Join Date: Oct 2008
73-79 had the NP203 full time 4wd system. The 203 is very heavy. The late model AWD transfer case is probably much lighter.
If you're not looking to use IFS from the later models you could use the late 6.2 engine, trans, and AWD transfer case in your square frame with an early full time 4wd solid front axle.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#16 |
...I suppose you could do a body swap with the whole Trailblazer chassis but that was not what I meant. On the AWD Trailblazer SS, the front axle is mounted to the oilpan (not the frame) so there is nothing to fab up to get an axle in there especially if you are planning to already use an LS engine. The only thing that would need to be done is to make some room to get the halfshafts from the axle out to the knuckles and switch the knuckles out for some with a splined ID that would accept the halfshafts. For the knuckles I think you could use GM minivan (Astro/Safari) AWD knuckles.
#17 | |
#18 |
I saw a Nissan 240sx with an LS1 that had an awd conversion much like what is described above using a trailblazer oil pan and diff.
If you can make clearance for the diff and half shafts, then you need to move the spring somewhere else. A coil over outside the a arms should work. You could try spindles from a 66-78 E body fwd full size car. These will have the 5x5 pattern that is correct for these trucks and they were pretty big cars so they just might be similar enough in size to work. The only thing about this method is that custom half shafts will be required an rear gearing will need to be matched to the front. A cheaper yet more fabrication heavy method would be to find a 88-98 4x4 donor vehicle. Graft the front frame section into the 73-87 frame. Your choice if you want to convert to outboard coil overs or try to use the torsion bars. Take the 88-98 rear axle and move the shock mounts and spring perches so it will work under the 73-87 frame. This eliminates any custom half shafts which means you use all stock front end parts and your gearing will already be matched. This also puts you at 6 lug, but you can get 6 lug rallys if you like stock, theres tons of newer 6 lug factory wheels floating around, and the aftermarket is booming with lots of 6 lug wheels too. Also, you're not tied to using an LS motor with the method since the front differential is seperate and attatched to the frame so you can run a small block or big block if you like. Either way, make sure you have lots of time and money for this one. Posted via Mobile Device
1977 GMC Sierra Grande |
