Old 06-15-2012, 12:32 AM   #76
c10seconds
c10seconds's Avatar
Re: Another Dropmember version???? :)
Nate, which one did I end up with?
c10seconds is offline   Reply With Quote
Old 06-15-2012, 12:34 AM   #77
PBFAB.COM
PBFAB.COM's Avatar
The mild.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-15-2012, 09:13 AM   #78
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by porterbuilt View Post
This is the "mild" version. Same geometry as the "touring" version. Only difference between the two is that the mild raises the cross member one inch, and the touring raises the cross member two inches.
Where is the 1 or 2 inches referenced? LCA pivot?
Is it safe assume, with the touring version, that the UCA mount moves up the same inch, no longer allowing use of the stock inner fenders?
Have you fit an LS motor w/ F-body accessory drive with either version?
Anyone driving on one of these yet that can give impressions?
This thing looks great, Nate. Might have to make this my third Dropmember...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-15-2012, 11:05 AM   #79
PBFAB.COM
PBFAB.COM's Avatar
Very safe to assume..... On the Touring version, all the suspension pivot points are raised one inch higher than the "mild" version.
There are a bunch of them out there, but only a few board members who have them. Should start seeing more and more on the road and I am sure they will give their impressions. I am installing a front and rear set-up (Touring) on one of my 70s here soon.... gonna drive it all the way to Dallas for the Goodguy's show in October.
Here are some more details....
When running a 28" tall tire and a 2.5" drop spindle, the Mild version has a ride height of 7" from the bottom of the frame to the ground. (We reference the bottom of the frame-rail right behind the front cab mount).
The picture shown has a tire installed that is just under 30" tall, thus the 8" measurement. When I measure my 70 that is completely stock, this equates to right at a 5" drop. The Touring version would make it a 6" drop. Keep in mind, that we have 2.5" drop spindles, so the crossmember alone would yield 2.5" of drop if using a factory height spindle.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-15-2012, 03:27 PM   #80
gringoloco
A guy with a truck
gringoloco's Avatar
Was planning on forgoing GG for CTC this year, but between you and Cheby showing at GG, we may have to change plans...
-Chris
Old 06-15-2012, 10:26 PM   #81
gringoloco
A guy with a truck
gringoloco's Avatar
One more question (for now): you've stated that the track width is narrowed 1/4" per side when using this crossmember. Is this with the CPP modulars, or in addition? Basically, if I ditched my current Belltech 3" drop spindles and stock suspension, would the mild DM and CPP modulars narrow my track width an inch (.25 for DM and .75-ish for spindles) per side?
-Chris
Old 06-16-2012, 02:58 AM   #82
SCOTI
SCOTI's Avatar
So let me get this straight..... If PB comes to Dallas, mountains can move. Otherwise... momma is in charge?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-16-2012, 09:44 AM   #83
67cheby
67cheby
67cheby's Avatar
LOL....thats what i am talking about, lets have the biggest C10 turnout Dallas has ever seen !
67cheby is offline   Reply With Quote
Old 06-16-2012, 11:15 AM   #84
gringoloco
A guy with a truck
gringoloco's Avatar
Haha- yeah, she gets what she wants usually, but on this one she's just along for the crazy ride.
We were pretty thick last year-- can we one up it? Man, I gotta get to work on the truck...
-Chris
Old 06-16-2012, 11:27 AM   #85
67cheby
67cheby
67cheby's Avatar
well i know we can at least 1 up it...i was there but my truck wasnt there last year so that is 1 more !! LOL
Old 06-16-2012, 06:52 PM   #86
Jparks
Jparks's Avatar
Make that 2, I should be there as well
Jparks is offline   Reply With Quote
Old 06-16-2012, 08:10 PM   #87
PBFAB.COM
PBFAB.COM's Avatar
This measurement is referenced in the distance between the lower control arm pivots of our mild and touring Dropmember vs factory crossmember.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-16-2012, 09:36 PM   #88
gringoloco
A guy with a truck
gringoloco's Avatar
Perfect. This is looking better every day...
-Chris
Old 06-16-2012, 11:07 PM   #89
Alvin
Never Done?
Alvin's Avatar
Chassis bracing looks great - is that a trailing arm cross member?
Is the bracing available separately?
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 06-17-2012, 02:19 AM   #90
SCOTI
SCOTI's Avatar
Well, well, well.... look who's checking in.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-17-2012, 04:29 PM   #91
gringoloco
A guy with a truck
gringoloco's Avatar
Looking on PBs website, the bracing is a one-off item, intended for a four-link, not available for purchase, yet...
-Chris
Old 06-17-2012, 04:57 PM   #92
SCOTI
SCOTI's Avatar
Prob another couple of weeks . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-19-2012, 06:03 PM   #93
Raguemoe
Junior Member
Raguemoe's Avatar
Nate, that looks great! My 67 is not going to be safe for very long. Can't wait till you get everything dialed in and road tested. BTW those Ridetech coilovers are sweet (I have a set on my 69 Camaro and love them).
Would like to see complete pkg setup front & rear (prices)!
Raguemoe is offline   Reply With Quote
Old 06-20-2012, 07:02 PM   #94
PBFAB.COM
PBFAB.COM's Avatar
Something like this out back?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-20-2012, 08:07 PM   #95
duallyjams
duallyjams's Avatar
Sweet so the rear package comes with a 9" .
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 06-20-2012, 08:10 PM   #96
PBFAB.COM
PBFAB.COM's Avatar
It's 9" compatible.
Customer requested a 9". The only difference between the four-link components for the 12 bolt vs. 9" is the spreader bar that ties the 4-link brackets together and runs under the housing. The one for the 12 bolt is contoured differently.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-20-2012, 09:12 PM   #97
gringoloco
A guy with a truck
gringoloco's Avatar
Looks great I assume this is the 'mild' coilover setup? Will the touring version use the 'mild' step notch?
-Chris
Old 06-21-2012, 10:51 AM   #98
PBFAB.COM
PBFAB.COM's Avatar
You assume correctly!
This kit utilizes the Stage 2 notch, and is the best fit for he Mild Dropmember. All the components also package nicely under an unmodified bed floor.
Since the Touring Dropmember has a more aggressive stance, the rear kit that will matches best uses the same notch as the Dropmember Rear Mild kit. It's ride height is a couple inches lower allowing for a no rake stance. Since it includes a deeper notch, the bed floor needs to be raised approx. 5".
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-21-2012, 01:52 PM   #99
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Beautiful.....
Man I wish I could find a pot of gold for that mild kit. This would be the perfect combo between stance/handling.
Did you post a price front/rear for the mild kit?
I like
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 06-22-2012, 02:08 PM   #100
Raguemoe
Junior Member
Raguemoe's Avatar
I'd like to see some more pics of the trailing arm setup for the coilovers. I want to keep my 5/7" drop w/stock bedfloor. Looks great!!!!
