03-11-2012, 11:29 PM | #1 |
Recommended headers (ls) for dropmember 67-72??
Anyone have pics on stage 2 dropmember they will share? I am looking now but don't want to buy wrong set!! Seen d.t's and dynotech's but still unsure if fit is there......thanx jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
03-12-2012, 04:42 AM | #2 |
Re: Recommended headers (ls) for dropmember 67-72??
I have my LS installed with the stage 2 DM. I am looking for headers that will fit as well. Wondering what will work with the steering linkage.
Posted via Mobile Device |
03-12-2012, 10:38 AM | #3 |
JRods Garage
Hey guys, I was in the same situation and I found this guys build on Porterbuilt's website. They are Pacesetter 72C2256
I bought them after I saw the fitment pics, and the price was right too. I payed $400 shipped brand new on eBay. I guess Nate suggested these to him
Orange Julius-My dropmember'd, LS'd, SWB street machine... |
03-12-2012, 10:50 AM | #4 |
Tell me about the slip on collectors--always used to a bolted flange--do they come with slip on clamps or do u have to purchase separate ??? Not sure i like that outward turn on drivers side but if it works!!!! thanx jim
03-12-2012, 10:59 AM | #5 |
JRods Garage
Im not quite sure I will use "slip on" feature. I will most likely weld on either a 3 bolt flange or a v-band flange
03-15-2012, 11:55 AM | #6 |
On the fast track to nowhere..
I don't care for it either. You also have to watch what you buy, I got a set of the 200.00 F-body headers off of eBay and they didn't fit. If Nate recommends a particular part number make sure that's the one you get
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
03-15-2012, 03:58 PM | #7 |
Truck and auto performance nut
those are the 4th gen f-body headers that work for some...not so much for others.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-04-2012, 01:55 AM | #8 |
Anything else?
04-04-2012, 09:58 AM | #9 |
A guy with a truck
There's a thread around here with Kooks TBSS headers on a DM setup...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-04-2012, 10:12 AM | #10 |
Here's the link......
http://67-72chevytrucks.com/vboard/s...d.php?t=514041 Probably the ones I will use...stilll researching.............jim
04-04-2012, 10:34 AM | #11 |
Ouch.
04-28-2012, 02:33 AM | #12 |
I tried the 5th gen eBay headers and they're a no go for frame laying.
04-28-2012, 02:58 PM | #13 |
Thanx for info......jim
07-01-2012, 09:36 PM | #14 |
Anyone thats tried the fbody headers with a dropmember have a pic of the driver side where the steering linkage would run? Thanks. I tried the Schoenfeld long tubes 1302ls1 but trying to route the steering linkage looks to be a problem and so far the drivers side header hits the rear of the control arm. Have not tried the pass side yet but dont look like there would be any clearance issues there.
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy |
07-03-2012, 06:18 PM | #15 |
kooks 1 7/8" 4th gen f-body headers do not fit with the mild front dropmember. Just in case anyone was wondering
07-08-2012, 06:38 PM | #16 |
True Addiction
I went with the DT's. I have an original PB dropmember and they fit great.
RCC |
07-16-2012, 11:08 PM | #17 | |
07-17-2012, 08:50 AM | #18 |
did it just contact the lower arm or was it uninstallable completely? i dont mind having to bang a dimple in the tube to get it to clear.
07-19-2012, 09:52 PM | #19 | |
07-20-2012, 09:12 AM | #20 |
gotcha, thanks for the input im thinking i may try the tbss long tubes from summit after looking at c10seconds thread with the mild dropmember and with me having the extreme dropmember the motor sits a bit higher and i think it'll work. we will see and i'll post up some results.
07-20-2012, 11:18 AM | #21 |
A guy with a truck
Check out Amazon- they have the Pacesetter TBSS LTs $350 shipped...
07-20-2012, 11:26 AM | #22 | |
but as you mentioned that i went on amazon and found them for 253.00 shipped thanks Gringoloco!
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy Last edited by paul66c10; 07-20-2012 at 11:40 AM. |
07-20-2012, 11:53 AM | #23 |
A guy with a truck
Oh, yes. Uncoated- $250, ceramic-coated, $350. Great deal either way...
07-20-2012, 06:39 PM | #24 |
I'm leaning same way but look at pic 3 in post #12 of c10seconds......my motor with extreme is higher and closer to firewall.....although these are Kooks and the pacesetter pics show a different tube route.......
07-20-2012, 10:12 PM | #25 | |
