Old 06-23-2012, 02:08 AM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
Stock Manifold Options for LS Swaps
I have been thinking about Trailblazer SS manifolds. I did some searching and found part numbers. They are supposed fit almost any frame from 60's to 80's.
12600526 MANIFOLD. Engine Exhaust Manifold - LH. Required: 01LHD.
12600527 MANIFOLD. Engine Exhaust Manifold - RH. Required: 01RHD.
LINK to data page.
www.GMPartsDirect.com
Left Side: $51.18
Right Side: $48.49
Please feel free to ADD PICTURES.
I would like to see some installed on 67-72 4x4 trucks....
Rich
1972 K5 Blazer CST Click HERE
Old 06-23-2012, 10:07 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: TBSS Exhaust Manifold Info (Pictures)
Wow, good prices. GMpartsdirect generally kills you on shipping though. Check out the build thread index-- I know there are a few running them in there for sure. Or, do a search for TBSS...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-24-2012, 02:29 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I used them, Only clearance issue was between the motor mounts and the manifolds. I shaved the bump off of the mounts. Others just do a little clearanceing with a grinder.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-26-2012, 11:59 AM   #4
MAK191
I'm using TBSS manifolds with dirty dingo adjustable 73+ mounts with the matching stands and rubber. They fit great with zero issues, they are not even close to the mounts or stands. I did notice the part numbers cast on mine are 12567483(LT) & 12567484(RT). Not sure what the difference is.
MAK191 is offline   Reply With Quote
Old 06-26-2012, 01:20 PM   #5
softballnrd27
Always a work in progress
softballnrd27's Avatar
They charge $25.41 to ship them for a total of $125 so not too bad if you don't have maninfolds that work already.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 06-26-2012, 01:58 PM   #6
ls1nova71
ls1nova71's Avatar
Does anybody know it the GMparts direct manifolds come with the heat shields?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-26-2012, 03:05 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Lists a seperate part number...in my experience with them, anything listed separate that doesn't have a "*, kit, package" listed means its the item ala carte. I would expect to get the manifold alone, no studs no heatshield.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-26-2012, 04:23 PM   #8
kwin
kwin's Avatar
They don't ship to Canada!! AAAAAHhh!!
kwin is offline   Reply With Quote
Old 06-26-2012, 09:01 PM   #9
mcmlxix
mcmlxix's Avatar
Those two part numbers list as Chevy SSR truck manifolds...
Rich
Old 06-26-2012, 10:50 PM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
I do! ...and mine come with heat shields and pipes...
http://67-72chevytrucks.com/vboard/s...d.php?t=530619
Same engine, same chassis, stands to reason same manifolds. Never look at an SSR the same again...
-Chris
Old 07-03-2012, 09:51 AM   #11
mcmlxix
mcmlxix's Avatar
Re: Stock Manifold Options for LS Swaps
2004+ GTO : 12563277 and 12563278
They look like they tuck close to the block and ont have two vertical studs. Should be plenty of frame clearance...
Rich
Old 07-03-2012, 10:46 AM   #12
Wasted Income
Boosted Member
Wasted Income's Avatar
I used those GTO manifolds too....but in a little different configuration
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 07-05-2012, 01:49 AM   #13
yossarian19
Any input on which (if any) manifolds for a stock '57 front end?
yossarian19 is offline   Reply With Quote
Old 07-06-2012, 12:27 PM   #14
68MoneyPit
Didnt the ssr have different heads with d port on exhaust ?
68MoneyPit is offline   Reply With Quote
Old 07-07-2012, 05:07 AM   #15
mcmlxix
mcmlxix's Avatar
I dont believe so. They started in 2003 with the 5.3L so it should be round port exhaust....
PS: I have a pair of 5th Gen Camaro manifolds on the way. I'll post pics when I get them...
Rich
Old 07-11-2012, 08:45 PM   #16
mcmlxix
mcmlxix's Avatar
Also test fit the 2010 Camaro manifold... Camaro on the left, Sierra on the right...
Rich
Old 07-18-2012, 11:17 PM   #17
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Anyone know if the TBSS manifolds will fit with a 5.3/Dropmember set up?
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 07-19-2012, 12:36 PM   #18
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Anyone?? Can't seem to find what headers guys are running in the squares, with DM and LS Swap....
77' Chevy SB
5.3/4l60e combo
Old 07-19-2012, 08:53 PM   #19
mcmlxix
mcmlxix's Avatar
Its 7" from the last manifold bolt on the head straight down to the flat gasket surface of the flange.
It sticks out 5.25" from the side of the block at its widest point. (Opposte of where the starter would attach.)
Rich
Old 10-29-2012, 12:00 PM   #20
mrhurt73
does anybody know if the stock LM7 flange fits the TBSS manifolds?
i see they are both three bolt flanges, i was wondering if i could get that lucky. i need a set of manifolds, but was hoping to still use the pipe and flanges.
i know i will have to cut the pipes loose from the y so they will fit in the frame.
LINK to data page.
Left Side: $51.18
Right Side: $48.49
mrhurt73 is offline   Reply With Quote
Old 10-29-2012, 12:14 PM   #21
MAK191
The ones I have bolted right up. I think I have the SSR manifolds but they are identical to the TBSS ones
Old 11-03-2012, 10:12 PM   #22
JNJchev77
Registered Cruiser
JNJchev77's Avatar
LINK to data page.
Left Side: $51.18
Right Side: $48.49
What are people using for reducers/collectors for the TBSS Manifolds? Do I have to find a TB and grab the exhaust system off of it, or is there an aftermarket piece?
77' Chevy SB
5.3/4l60e combo
Old 11-05-2012, 03:17 PM   #23
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Anyone?
I wonder if an exhaust shop can fab some collectors for the manifolds?
77' Chevy SB
5.3/4l60e combo
Old 11-05-2012, 06:05 PM   #24
mcmlxix
mcmlxix's Avatar
I unded up using the Camaro 2 bolt manifolds but I had the local waterjust guy cut two 3/8" steel flanges for a 2.5" OD exhaust pipe....
Rich
Old 11-05-2012, 07:12 PM   #25
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Ya, looks like I'm just going to have some made, or make my own ;P... Thanks mcm
77' Chevy SB
5.3/4l60e combo
fuvk off
