Old 01-07-2013, 01:59 PM   #1
1968 chevyc10
tire size help?
I have 68 c10 and am not sure what tire size to put on my truck It will have 15'' inch rims on it, thinking of putting on 235/75r15 on an 8'' rim for the front and 265/75r15 on an 10'' rim for the back. but not sure, pictures of any 15'' rim/tire size would be great thanx.
1968 chevyc10 is offline   Reply With Quote
Old 01-07-2013, 02:32 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: tire size help?
Welcome to the board! Those rims -- especially the 10" rears -- sound too wide for the tire sizes you mentioned. If you go to http://www.tirerack.com/index_w.jsp, you can select any size tire and it will show the acceptable rim width range.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 01-07-2013, 03:16 PM   #3
~Whitey~
~Whitey~'s Avatar
Re: tire size help?
These are 275/60/15 all the way around on 15x8 in ralleys on my 69
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 01-08-2013, 02:00 PM   #4
1968 chevyc10
Re: tire size help?
Thanks for the tip I thought those tires would work with a 10'' rim but you were right, tirerack says the biggest rim those tires will fit are a 9'', thanks for the advise.
Old 01-09-2013, 05:40 PM   #5
badfiero
Re: tire size help?
For your information the 265/75r15 is the same dimensions as a 31x10.50r15 which I have been running on 15x8 wheels since 1994 all the way around.
badfiero is offline   Reply With Quote
Old 01-09-2013, 08:57 PM   #6
cleanfreak
cleanfreak's Avatar
Re: tire size help?
2 different settups. 6" , 7" steelies , 215/75 front , 235/75 rear. 7", 8" ralleys , 235/75 front , 255/70 rear. Are you going stock or lowered?
cleanfreak is offline   Reply With Quote
Old 01-09-2013, 09:55 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: tire size help?
If you plan to lower the truck, consider that before you buy tires/rims.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-09-2013, 10:22 PM   #8
hayhauler71
hayhauler71's Avatar
Re: tire size help?
245 70 15 on front 15x8 wheel
275 60 15 on rear 15x10 wheel
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-10-2013, 06:45 PM   #9
1968 chevyc10
Re: tire size help?
I am definately lowereing it, not shure how much though thinking about a 4'' inch drop.
nice truck by the way looks great!
Old 01-10-2013, 06:49 PM   #10
1968 chevyc10
Re: tire size help?
I like the tire sizes on your truck allot, thanks for posting the pics.
