01-25-2013, 02:28 PM | #51 |
Re: She is back.
Yes, if you have an Edelbrock, a fuel pressure regulator is a great investment, even with a stock-style fuel pump.
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
01-25-2013, 04:13 PM | #52 |
67-72 parts collector,…
Re: She is back.
01-26-2013, 11:02 AM | #53 |
Re: She is back.
Any updates?
01-26-2013, 11:16 AM | #54 |
Junior Member
Re: She is back.
No updates from the shop yet.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
01-26-2013, 08:55 PM | #55 |
Re: She is back.
The metal fuel line has a jumper hose in the frame inboard of your third door and is an excellent place to plumb in a marine spin-on fuel filter ( available from West Marine or other online marine sources). This hose is bent in a "U" just like the jumper hose coming into the fuel pump, so check both of these to make sure they arent flattening out and sucking shut and that neither are leaking air. Any filtering should be done BEFORE the fuel pump! If you have a filter after the pump get clogged, it will shut down the flow from the pump...The 62 pickup I built for my son exhibited the same symptoms and what had happened there was....the truck had been inactive for several years and the fuel flow worked fine until our highly-solvent modern fuels loosened up the leftover crap in the lines turning it into a clogging goo, which I had to blow out with compressed air. Fuel hoses can also form annuerisms (a blister or flap inside) as they age....
As for ignition, I'll assume that you are using a points distributor, OR if you've switched to HEI, that you have replaced the resistance wire from the ignition switch with one that has no resistance. (HEI won't work without the full twelve volts) A common intermittant ignition problem with a points setup is the coil often fails intermittantly (usually when it warms up and you're a good distance from home) Don't ask me why, but if you remove the coil and shake it next to your ear and hear the oil sloshing inside, it's usually shot! There are other things to look for inside a distributor after these basics are covered! Good Luck to you! |
01-27-2013, 02:24 AM | #56 | |
Re: She is back.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
01-28-2013, 04:17 PM | #57 |
Junior Member
Re: She is back.
The shop called and said they put 5 gallons of gas in it and it is running fine. They did not do a thing 3!@&^&^%%@! I just ordered an Eldebrock fuel pump and will go from there since they pump at 6 psi max. If my head was not already shaved I would be pulling my hair out for sure.
01-28-2013, 04:25 PM | #58 |
Proprietor of Dale's Corner
Re: She is back.
did you tell them to drive it and put some miles on it to make sure it runs ok
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-28-2013, 04:32 PM | #59 |
Junior Member
Re: She is back.
I am going to pick it up this afternoon and put the new fuel pump on when it gets here in a couple of days. I am not sure how much they drove it. It does run fine at times. I have not been too pleased with the shop. It took them a week to get this far.
01-28-2013, 04:41 PM | #60 |
Re: She is back.
Well I hope all goes well, Keep us posted
01-28-2013, 07:07 PM | #61 |
Junior Member
Re: She is back.
I went to pick it up and determined they did not drive it very far. I am beginning to wonder if there isn't a problem with the tank. The owner of the shop is supposed to drive it more tomorrow.
01-28-2013, 08:16 PM | #62 |
6>8 Plugless........
Re: She is back.
Hopefully he can get it to fail while he's driving it.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-28-2013, 08:54 PM | #63 |
Re: She is back.
I hate intermittent problems, can't diagnois unless it acts up. Keep us posted, I for one am curious.
01-28-2013, 08:58 PM | #64 |
Re: She is back.
Run it off of a gas can.
That will tell you if it's the tank of not.
01-28-2013, 09:04 PM | #65 |
Junior Member
Re: She is back.
It has always ran fine off the gas can. It is a FUELCELLGUY tank but I don't know muh about it really.
01-28-2013, 09:10 PM | #66 |
Re: She is back.
Did you talk to fuel cell guy?
01-28-2013, 10:51 PM | #67 |
Junior Member
Re: She is back.
I am thinking of giving him a call tomorrow.
01-29-2013, 12:06 PM | #68 |
Re: She is back.
Is it foam filled, like the racing ones?
01-29-2013, 01:54 PM | #69 |
Junior Member
Re: She is back.
Just got a call from the shop that the alternator is bad. It is a rebuilt with no miles from Autozone so anything is possible. I am going to exchange it and swap it out my self tonight and hopefully they can find the problem tomorrow.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 01-29-2013 at 02:40 PM. Reason: spelling |
01-29-2013, 07:34 PM | #70 |
Cool Truck
Re: She is back.
I accidentally clicked on the burb section but that is one sweet ride!
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
01-29-2013, 09:55 PM | #71 | |
Junior Member
Re: She is back.
I rushed over to the shop after they closed and took the alternator off and took it back to Auto Zone and lucked out. I got a cool young kid who knew what he was doing. He tested the alternator and it tested fine but they can not check volts and according to the shop it was not right so he swapped it out with no questions. I upgraded from a 63 amp to a 96 amp for $30 with my warranty. I took it back to the shop and put it on then we tested it and bam 14 volts. The shop thinks this may be why it was dying and back firing. I left it with them and asked him to drive it some more tomorrow. He said he would but he didn't want to because it is going to make him want it more. It was cool to hear that from a guy who has some very nice expensive rides in his shop.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 01-29-2013 at 10:04 PM. |
01-29-2013, 09:59 PM | #72 |
Re: She is back.
That is pretty cool!
01-29-2013, 10:10 PM | #73 |
Junior Member
Re: She is back.
I forgot to mention the youngster even took the sepentine pulley off with an impact and put the v-belt pulley from the old one on for me.
01-30-2013, 07:36 PM | #74 |
Junior Member
Re: She is back.
I picked it up today and drove here home and it ran fine. The shop adjust the timing a little and adjusted the carb a little as well. I am going to take it to the tranny shop because the tranny is slipping. I also need to change to a 3.73 rear end to go with the overdrive. The only other known problem at this time is the tire rubbing issue so I am going to order a set of spacers for the rear.
01-30-2013, 08:00 PM | #75 |
Re: She is back.
I hope it's fixed, Keeping my fingers crossed
