01-30-2013, 06:30 PM | #10 |
Building Dreams out of Dimes!
Yes I have the 76-78 calipers and I got Wearever silver brake pads. MFG NAD 122 Duralast Rotors Bolt Pattern Diameter (mm): 127 Rotor Bore Diameter (mm): 78.5 Rotor Initial Thickness (mm): 32.70 Rotor Outside Diameter (mm): 295 Rotor Overall Depth (mm): 83 Wearever Silver Brake Pads - Rear Friction Material Thickness, Inner Pad: 0.4 in Friction Material Thickness, Outer Pad: 0.43 in Front or Rear Brakes: Rear Fenco Disc Brake Caliper, Rear Right & Left I can not figure it out. I mean the rotors will NOT fit in the calipers with the brake pads installed....? The rotors are like .25 in too big..? Last edited by Hazieview; 01-30-2013 at 06:59 PM. |
