Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-24-2012, 11:41 PM   #26
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: NO-E street build
Originally Posted by bigguy69 View Post
I like this truck
nothing but a photo update .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-25-2012, 10:27 PM   #27
hotrod 80
mini truck racer
hotrod 80's Avatar
I have been researching how to keep the A/C on the truck and this is what i came up with . Thes two are made by Alan Grove . Gonna have to do some measuring to order the correct one , but this is the ideal . Mounting the compressor where the fuel pump would be . Which is where it is located now . No hose changes except for up from at the condensor . I'll have to move it to make room for the larger aluminum radiator .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-26-2012, 02:47 PM   #28
hotrod 80
mini truck racer
hotrod 80's Avatar
Neither of the low mounts will work . The Idle steering arm is in the way of the higher one . I measured off the yellow truck . Also the lower radiator hose coming from the radiator would be up against the clutch of the compressor . The belt was already goning to be close to the hose .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-27-2012, 10:57 PM   #29
hotrod 80
mini truck racer
hotrod 80's Avatar
No pics today due to rain , but i dropped it off at the chassis shop for the motor mounts to be welded in and the pinion angle to be set . Preches will be adjusted and plated for strength . They are going to build a shifter stand while they got it also .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-28-2012, 09:34 PM   #30
hotrod 80
mini truck racer
hotrod 80's Avatar
In the chassis shop for mounts welded in , pinion angle ,front crossmember relief, shifter stand etc.
Hey , is anybody in here ?
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-29-2012, 12:05 AM   #31
Captainfab
60-66 Nut
Just me right now.......
Old 01-03-2013, 08:04 AM   #32
hotrod 80
mini truck racer
hotrod 80's Avatar
Got it out of the chassis shop last night . Pretty happy with everything except the shifter stand which i can fix . It was raining and dark last night when i got home so ill get some pics up tonight . Motor going in this weekend for sure .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-03-2013, 01:08 PM   #33
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: NO-E street build
Ole' Chevy LUV Trucks..
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-04-2013, 09:21 AM   #34
hotrod 80
mini truck racer
hotrod 80's Avatar
Well , i got the truck back from the chassis shop . and got it this far last night . The oil pan i bought is a bit longer than the factory truck pan i used on the Yellow truck . It will be ok . Motor and trans are in thought .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-04-2013, 10:43 PM   #35
hotrod 80
mini truck racer
hotrod 80's Avatar
Finished up the firewall clean up , header install , carb on , distributer assembled , crossmember modded for larger pan , driveshaft in .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-09-2013, 10:23 AM   #36
hotrod 80
mini truck racer
hotrod 80's Avatar
Are these too much ? i kinda thought theywould be cool .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-21-2013, 11:13 PM   #37
hotrod 80
mini truck racer
hotrod 80's Avatar
Ran into a snag . Motor mounts were welded in 3/4 " to far forward . This would not allow me to get the water pump and fan installed . Back to the chassis shop for thr mounts to be cut out and moved . Also had a few other things done . Had hooks weled to the frame to strap truck down , panels made for speakers in rear cab corners , battary tray cut out & a set of universal traction bars cut up and welded to the rear shock mounts . Pics to follow .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-27-2013, 12:31 AM   #38
hotrod 80
mini truck racer
hotrod 80's Avatar
Got the motor back in . been a busy weekend so far .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-27-2013, 10:19 AM   #39
Hart_Rod
Hart_Rod's Avatar
Nice build!
Hart_Rod is offline   Reply With Quote
Old 02-03-2013, 10:37 AM   #40
hotrod 80
mini truck racer
hotrod 80's Avatar
Thanks Hart rod , it's getting there .
Got some time to workon this . I dont think im going to have it ready for the season opener , but im trying .
This is the material for the interior . I am having the door panels , seat , kick panels redone .
I got the cooling system completed yesterday . I bypassed the cable heater block valve , as i have never had one that didnt leak . I added a manual valve for summer when the air is on . Got the Condensor and liquid line filter drier mounted and hooked up . All that is left is the compressor mount and hook ups for A/C . Well enough talk here is the current picks .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-03-2013, 10:59 AM   #41
bigguy69
dazed and confused
bigguy69's Avatar
That is going to be a cool ride!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 02-11-2013, 10:34 PM   #42
hotrod 80
mini truck racer
hotrod 80's Avatar
Did a little more on it , but not much . Not going to make the season opener with it . I was planning to have my wife drive it and contend for rookie of the year .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-02-2013, 10:04 AM   #43
hotrod 80
mini truck racer
hotrod 80's Avatar
Upolstry off for redo . Door panels , seat and kick panels . Factory tank is being sumped modded and coated . Glass is out for new winsheild gasket and rear window seal . Dash repair in progress for new dash cap . Stereo going in new speaker panels covered and onstalled . Lots of little stuff done . Throttle pedal modified and cable fitted and installed . Choke cable installed ( this will also double as a staging RPM tool with the choke flap removed ) . Reused one of the vapor recovery lines from the tank as vacuum for modulator valve . Moved wires around in harness to make factory relays work for fuel pump and distributor instead of ballast bypass and combo fuel pump/distributor . Truck is getting really close .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-11-2013, 10:43 PM   #44
hotrod 80
mini truck racer
hotrod 80's Avatar
Made heat with this one tonight . Had #6 top dead , but after thst is busted right off . Good running litlle motor .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-12-2013, 11:40 PM   #45
gofastnut
gofastnut's Avatar
Man, hotrod 80!
Sweet ride and serious progress! Love the visual updates, keep em coming!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 04-13-2013, 06:43 AM   #46
hotrod 80
mini truck racer
hotrod 80's Avatar
Originally Posted by gofastnut View Post
Man, hotrod 80!
Thanks , it is open exhuast ( Hooker block huggers with 2.5" head pipes )right now so it is pretty load . The thermostat stuck closed so i pulled it out and that helped . These things make some heat when they are new . Fuel system is -8 from the sumped factory tank to a summit inline filter then -8 to a Holley blue pump . I installed a Fram HP1 cartrige type filter after that and then -6 to the regulator up front . I bought a 650 Holley double pump for this thing off the holley EBay sight for a really good price , but i found out why the price was so good . The front accellerator pump arm was bound up on the roll pin . the cam lever with the spring loaded bolt couldn't make the front pump squirt . I tapped out the roll pin and filled ot square and chamfered the pin hole , good as new . Set the initial timing at 14 and it seems really happy there .
I have it scheduled for exhaust next wendsday . Finish the driveshaft monday . Glass install tuesday.
Upolstry should be finished tuesday also . I got the dash fixed and the rear speakers installed . The carpet and padding will follow the glass install . It has been alot of work .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-29-2013, 10:34 PM   #47
hotrod 80
mini truck racer
hotrod 80's Avatar
Got this thing lined out enough to drive it . I will post pics of it completed with the interior , but it has a new owner that wanted it more than me . It truely is a nice truck with a/c and nice stereo . Just to give you an idea what the interior looked like i'll post a pic . Finished pics coming .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-02-2013, 09:58 AM   #48
hotrod 80
mini truck racer
hotrod 80's Avatar
This truck is finished and has a new home . Just figured i would post up the finished photos .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-02-2013, 11:31 AM   #49
bigguy69
dazed and confused
bigguy69's Avatar
Turned out a sweet ride!
