Old 04-28-2013, 09:22 PM   #1
Dylan86
Dylan86's Avatar
traction- how to hook up?
I am trying to get some traction on a launch, until my truck hits second gear, in WOT, i just sit there and spin. i only have 2.73 gears in the rear. and 275mm wide rear tires... any ideas other than adding allot of weight to the back?
Dylan86 is offline   Reply With Quote
Old 04-28-2013, 09:37 PM   #2
MB84C10
Re: traction- how to hook up?
4 link it
MB84C10 is offline   Reply With Quote
Old 04-28-2013, 09:42 PM   #3
cory d
cory d's Avatar
you need something to control wrap. there are many options for that. drop shackles will give you more squat too
cory d is offline   Reply With Quote
Old 04-28-2013, 09:46 PM   #4
rs74
rs74's Avatar
Has anyone used these. I was thinking about them for my truck but not sure if they will work on a lowered truck.
http://calvertracing.com/cart/index....products_id=28
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-28-2013, 09:57 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
They make them for flip kit trucks yes. Those will help with squat angle and wrap up. People run tens easy with just those. Moving weight to the rear will help much as well. Moving the front spring eye up helps alot and not dumping the gas right away too. Wider tires or slicks will be a good idea too
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-28-2013, 10:10 PM   #6
Dylan86
Dylan86's Avatar
i have drop spindles and shackles, it did help a bit... and also am interested in the caltracs also rs74. can you install them on a 4" drop? are they worth the coin?
Old 04-28-2013, 10:17 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Caltracs work!!
Old 04-28-2013, 10:37 PM   #8
Gigem
Gigem's Avatar
Stupid question, but do you have a positraction rear end?
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 04-28-2013, 10:45 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Gears, posi,shocks and tires are all part of the equation making trucks hook.
Then you will find all the other weak links in the drive train
Old 04-28-2013, 10:46 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
Old 04-28-2013, 10:54 PM   #11
meatwagon83
meatwagon83's Avatar
Originally Posted by KQQL IT View Post
Caltracs work!!
x1000!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 04-28-2013, 11:41 PM   #12
cory d
cory d's Avatar
a big factor is what you have under the hood. to get the most traction from my truck (2.73 gears and mild HP 350) isnt goin to be the same as a 500HP truck with 3.73
Old 04-28-2013, 11:50 PM   #13
Hook0215
Caltracs...
Hook0215 is offline   Reply With Quote
Old 04-29-2013, 07:28 AM   #14
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I use a custom set of traction bars on my 12 bolt. Better launch but with no weight, the ZZ4 just tears up tires.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 04-29-2013, 11:01 AM   #15
68Timber
I know the pieces fit
68Timber's Avatar
Right now those gears are your worst enemy. Swap the 2.73's for 3.73's or 4.10's.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-29-2013, 11:15 AM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Chemist mine hooks with 0 weight added.
Old 04-29-2013, 07:46 PM   #17
Dylan86
Dylan86's Avatar
yes i have posi.... and swapping to 3.73 or 4.10 would make my problem worse- my torque would be increased to the wheels. i have too much spin as it is. i think im gunna go caltracs and put some fatter tires on her. thanks guys
Old 04-29-2013, 07:59 PM   #18
INSIDIOUS '86
Yes torque would increase to the wheels but the rate at which its applied is slower I guess you could say or longer over time. I had 2:73 gears and if I farted at the gas it lit my 295s up. Now with 373s I can go a lot more on the gas before they lite but if I floor it I can spun them as long and in any gear I like. If that makes any sense. The Caltracs will be a nice addition. A swaybar in the rear will help to mine torques to the right of my shoulder hardcore
Old 04-29-2013, 08:07 PM   #19
Dylan86
Dylan86's Avatar
really? thats good to know. my only issue is i have a th350 trans, if i had 4.10s i would almost be red lining before i could go hi-way speeds
Old 04-29-2013, 08:11 PM   #20
INSIDIOUS '86
I have a th350 as well. I'm turning about 3-3500rpm avg with 3:73 and 27in tall tires. Tops at 110 @6krpm by my speedometer. A 200r4 from ck or a 700r4 from patc will make them very livable though.
Old 04-29-2013, 08:33 PM   #21
Dylan86
Dylan86's Avatar
would maybe 3.42s be the best choice then?
Old 04-29-2013, 08:45 PM   #22
gchemist
gchemist's Avatar
If I had sticky tires, mine would hook up too.
The guy that made my traction bars drove them on a 87 SWB. It was powered by a 454 making over 550 HP. The truck with slicks just squatted, hooked, and launched hard down the track. Once my truck is ready for hardcore track running, I will slap on a set of slicks.
Old 04-29-2013, 09:17 PM   #23
KQQL IT
At the body shop.
KQQL IT's Avatar
All mine wanted to do was wheel hop with street tires.
In reference to Dylan I changed converter to 3500 ish stall. 3:82 gears cal tracs Hoosier drag radials.
Went from 2.20 to 1.67 60' at the strip.
And 13.50's to 12.20's all at 109-110 mph it can be done.
