so the 350 in my truck has a leaky rear main seal
Tyler ------------------------------------------------------ 1980 2wd blazer 1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276 1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: easiest way to change the rear main seal
Assuming its not a later model engine with a 1 piece rear main seal, yes, you just drop the pan and rear bearing cap to change the seal. No need to drop the trans.
Posted via Mobile Device |
easiest way i found was to drop it off at a good shop and pick it up after its done
#4 | ||
#5 | ||
"I ain't nobody, dork."
If it's in the '80 in the Blazer in your sig line... you won't need to lift the engine to get the pan out. Which it a good thing. But... the whole process is a PITA no matter how you do it.
Gary
I don't know about getting the pan off without lifting the engine on his truck.
#7 | ||
I've done a few rear mains in late 70's and early 80's (2 piece) trucks and didn't have to lift the engine. They were all 4x4's as well.
Gary
I just tore into it this morning and I got the pan and main cap off without lifting the motor, should have it put back together tonight.
There's a guy in another thread who takes about making sure the timing mark is facing straight down. Apparently this places the crank in a position where the pan slides out once unbolted. My rear main is leaking like a sieve, and am planning on doing the seal replacement myself. I will let you know about the pan.
#11 | |
#12 | |
I never try to work around the oil pump. I drop the pan enough to get a wrench on the oil pump bolt and drop the pump into the pan.
#14 | |
No No
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
#15 |
My 72 K20 isn't that bad. A jack and about 15 bolts gets the 3 piece crossmember out. You can then drop it straight down. Easiest one I have ever done. Pan easy, realligning the crossmember is a PITA due to slight frame twist (old age, not damage)!
#16 |
My Carbon Footprint
Hopefully you will roll the seal through so it's sticking out an 1/8th inch or so otherwise you might be right back in the same situation. In other words, don't have the where the 2 halves of the seal line up with the 2 halves of the main cap. That is where oil wants to leak under pressure.
