Old 05-29-2013, 10:06 PM   #201
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: LS engine swap info
they also show stepped headers available in their long tube's with primaries up to 2".
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-30-2013, 12:54 PM   #202
aggie91
I'm just glad to be here!
aggie91's Avatar
Originally Posted by 68GMCCustom View Post
not sure if these have been mentioned....but the Hedman/MuscleRods mid-length 1 3/4" x 3" set at Pace Performance in raw steel.....for $309! Or...with the HTC 1300 degree, Shinny Silver Finish for $579
BTW....they show fitting as '67-'98.
Those appear to be the same ones from BRP, coated is $499 from BRP. PN45666 is the coated version of the 45660.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-06-2013, 08:37 PM   #203
Flatpat
Flatpat's Avatar
Sorry if this has been answered, I've searched and searched and have gone through a lot of threads.
If I am using the under hood fuse block that came with the 5.3 in my swap, do I run the grey wire from C3-F1 (fuel pump power) straight to my fuel pump of does it need to go to a relay first? I think it already goes through a relay on the block but I'm not 100%.
Thanks to everyone for all the info that is out there.
Flatpat is offline   Reply With Quote
Old 09-09-2013, 10:59 AM   #204
aggie91
aggie91's Avatar
look at this schematic on this page:
http://lt1swap.com/pictures/fig_7.gif
It appears that the gray (18ga) wire (circuit 120) from the fuse block (location F1/ connector C3) goes thru the relay on the fuse block and go straight to the pump.
here is the connector ref that I used to ID the wire:
http://lt1swap.com/underhoodfuseblock.htm
Hope this helps you out...
Karl
The LST Challenge:
Old 09-10-2013, 12:08 AM   #205
Flatpat
Flatpat's Avatar
Confirmed what I was thinking. Thank you
Old 10-04-2013, 07:28 AM   #206
chuckmc8
It's alsways something.....
chuckmc8's Avatar
The TRailblazer SS exhaust manifolds are available from GM Parts direct. On the homepage, put 2005 Trailblazer and click the model option with the 5.3 engine. The left side is $51.94 and the right side is $49.21. I will order a set for my next build in a couple weeks. These are suppose to tuck inside the 67-72 frame rails.
here is da link: http://www.gmpartsdirect.com/catalog/frameset.cfm
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 10-04-2013, 02:52 PM   #207
68GMCCustom
those for the 5.3L on the V8 TrailBlazer... are the same as the ones on the 6.0 LS2 TrailBlazer SS?
Also, TBSS's were made from 2006-2009.
Kurt -
Old 10-04-2013, 07:54 PM   #208
chuckmc8
chuckmc8's Avatar
I just changed the search parameters for 2007 Trailblazer SS with the 6.0 and the price is the same, so I ASSume its the same manifold. They dont list a part number on the website. I just added both to the shopping cart and the total with shipping is $126.22 for the pair
Old 01-29-2014, 08:25 PM   #209
iceship
So how bad would it drive with on tune...
iceship is offline   Reply With Quote
Old 03-11-2015, 03:13 PM   #210
aggie91
aggie91's Avatar
Back on Post #8, the link to Do's Blocks no longer works since that company is no longer in business. I was searching for the Denso 10S17F 10S20F Suction and Discharge Compressor Adapters for the truck compresser in the OE truck position. The old part numbers where AA2209 and AA2210.
Those numbers lead me to coldhose.com and these parts:
http://coldhose.com/catalog/product/...g/category/39/
Those are not what I was looking for but will certainly work.
I did find on their site these parts, which are the ones I was looking for:
http://coldhose.com/catalog/product/...s/category/39/
So, for anyone looking for the adapter fittings, there is the info for two different styles that are currently available and a source to get them from.
Hope this helps some one.
Karl
The LST Challenge:
Old 03-23-2015, 08:50 PM   #211
rharp
So, if a guy bought a wrecked 2010 Camaro Ss, with a complete, running engine with all wiring, how hard would it be to transplant it to a '69 Chevy C10?
1969 Chevy CST/10 396, PS, PB, A/C
rharp is offline   Reply With Quote
Old 03-24-2015, 08:52 AM   #212
mcbassin
Still Learning
mcbassin's Avatar
This depends on how you want to do the swap, i.e. how much do you want to spend? or what is your skill level with wiring?
You can buy a plug and play harness/pcm that all you have to do is connect like 4 wires or you can completely rework the stock harness and have the pcm reflashed.
It's not hard but it does take some time and a whole lot of patients.
Brendon at lt1swap.com can reprogram your pcm and he has some info about the harness : HERE
Old 03-24-2015, 08:58 AM   #213
ls1nova71
ls1nova71's Avatar
I just helped a guy do this very engine in a 72 GMC. You will need a different oil pan, have to remove the oil cooler from the side of the engine and if its an L99/6l80e, you will need a high hump floor to clear the trans.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-24-2015, 09:01 AM   #214
Hart_Rod
Hart_Rod's Avatar
I did it here: http://67-72chevytrucks.com/vboard/s...358692&page=17
Hart_Rod is offline   Reply With Quote
Old 10-22-2015, 07:55 PM   #215
Shortbed 68
Looking for any and all good info on ls swaps. I have a 68 short bed I'm putting a 5.3 4l60e in. Any help is appreciated.
Shortbed 68 is offline   Reply With Quote
Old 10-22-2015, 08:17 PM   #216
LockDoc
The Older Generation
LockDoc's Avatar
???... Anything you could ever want to know is in this thread. Start with the first post and read it all the way through, clicking on the links..
LockDoc
Leon
Old 12-27-2015, 06:17 PM   #217
68SSC10
68SSC10's Avatar
Has Anyone Used These..... http://www.jegs.com/i/Hooker+Headers...FY-Cfgod7bYM3Q .Any Thoughts??
I've Reached The Age Where Happy Hour Is A Nap!!
68SSC10 is offline   Reply With Quote
Old 12-27-2015, 07:07 PM   #218
doublebeetx
The Hooker header looks good, but being cheap, I found a set of Trailblazer SS manifolds on eBay. I took off the heat guards, ground off the mounting points for them, plus all the casting flash and part numbers. They look awesome and I have 40ish dollars in them. Just talked to a guy about ceramic coating them and they'll be done, still at half the cost .
doublebeetx is offline   Reply With Quote
Old 12-28-2015, 04:56 AM   #219
mcmlxix
Collector of Projects
mcmlxix's Avatar
Those are basically 2010+ Camaro manifolds... If you're luck you can come up with some 2014+ Z28 stainless steel manifolds off ebay... for the cool factor...
Rich
1972 K5 Blazer CST Click HERE
Old 12-28-2015, 11:04 AM   #220
LockDoc
LockDoc's Avatar
I used them on the '67 Panel Truck. They fit like a glove and were easy to connect the rest of the exhaust to. The shop that did my exhaust just welded the o2 bungs in the pipe below the manifolds. That is a good price. The cheapest I could find on e-Bay when I bought mine was $319..... I couldn't find any GM takeoffs at that time.
LockDoc
Leon
Old 10-26-2016, 10:27 PM   #221
six7swb
Hi, do u know of any resonable price long tube headers that will fit im swaping a 5.3 in my 67 c10, thanks a lot!
six7swb is offline   Reply With Quote
Old 10-27-2016, 02:11 PM   #222
knomadd
knomadd's Avatar
I'm not sure what you consider reasonable, but a lot of guys are running the Doug Thorley 324y-c https://www.summitracing.com/parts/dte-324y-c
I have them going into my 71 with 6.0 and they seem to be a really nice fit. I've had them in once with the engine in and out several times.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-27-2016, 02:27 PM   #223
six7swb
They are nice i had done of his headers in my 71 impala, great quality!
Old 01-08-2017, 12:56 PM   #224
kehstr
kehstr's Avatar
A lot of good information in this thread!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 01-21-2017, 05:41 AM   #225
Putso
I will definitely be referring to this thread a lot for when I start my swap this spring. 2000 lq4 4l80e in to a 88 3500 crew cab.
Putso is offline   Reply With Quote
