03-13-2013, 02:24 PM | #1 |
check engine light
what are you guys running for a check engine light? pics would be cool too!
something like this is my idea... but idk where I would put it... and I would have have to remove the emblem LOL http://www.ebay.com/itm/HONDA-PGM-FI...712624&vxp=mtr
70 C10 working on a LSx swap 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
03-13-2013, 03:47 PM | #2 |
meowMEOWmeowMEOW
Re: check engine light
http://www.allelectronics.com/
Tons of little lights, led's, and panels. Just make sure to check the voltage and order a resistor if you need to.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
03-13-2013, 05:06 PM | #3 |
I just rigged mine into my choke light. Did the older 70's trucks have any dummy indicators?
03-13-2013, 10:08 PM | #4 |
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
03-14-2013, 12:47 PM | #5 |
thats a sweet setup u have there tr65... but I think I have other plans for my radio slot either this
http://www.ebay.com/itm/300802649516...84.m1423.l2649 or number one on this page http://www.lmctruck.com/icatalog/cb/full.aspx?Page=102
03-14-2013, 12:49 PM | #6 |
bohmankid my truck may have had the option for a brake and something else as a dummy light but my particular truck doesn't have them, i can see where they may have gone though
03-14-2013, 03:44 PM | #7 |
My Dakota Digital gauge setup has a light built in.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-14-2013, 11:36 PM | #8 |
This pic didn't turn out the greatest, but what I did was took the "service engine soon" part out of a '90 suburban dash and put it in the unused spot in the gas gauge. The opening isn't big enough for the whole thing, so it just says 'service engine'.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-15-2013, 08:12 AM | #9 |
eric thats cool i really like that
10-01-2013, 11:50 PM | #10 |
What's the yellow light at the top left of your fuel gauge? Low fuel light?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
10-02-2013, 06:02 PM | #11 |
I've been looking into this as well. Mine is throwing the code for low voltage on the MIL haha. I switched all of my gauges to autometers so I'm going to make a panel in the center gauge spot with all of the indicators; blinkers, high beam, and check engine. I'm looking at using a few of these in different colors
http://www.superbrightleds.com/morei...ed-light/1494/
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
10-02-2013, 06:50 PM | #12 |
Yes. It's a low fuel light. It works, but doesn't have any kind of buffer in the circuit, so when you start to get low it will go on and off as the float moves, so it's not as accurate as a new car, but oh well!
10-12-2013, 12:33 PM | #13 |
The guy that wired mine in used the original check engine light and its currently on for i think 3-5 codes. Emissions code that didn't get deleted out yet, tranny code because i haven't finished that yet, oxygen sensors because i haven't put exhaust on it yet and 2 other codes i can't remember
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
10-15-2013, 04:06 PM | #14 |
For anyone interested, I did a full autometer swap for my gauges and couldn't figure out what to do about the blinkers/ high beam/ and MIL. Turns out those LEDs I posted earlier are literally the perfect size to go right into the stock dash with no modification whatsoever. It is essentially a bolt and nut with an LED on the head. Slide the front through the dash, tighten the nut snug up to the back of the dash and you're good to go. Unfortunately when they blink it's like staring into the sun, so I'm trying out a few different resistors now. You could also use a pot if you want to be able to dim them, but the rest of my cluster doesn't so I wasn't worried about it. Also, you don't have to, but I think they would look better without being able to see the diodes through the polymer on the head so I've scuffed up the face a little bit. That also diffused a bit of light. I'll try to get pics up tomorrow.
