Old 01-02-2014, 08:19 PM   #1
66farmer
66farmer's Avatar
Rear shock relocation
My shocks got in the way of my exhaust routing, so I removed them built the exhaust and know it's time to relocate the shocks, I'm thinking about to the rear of the diff. Anyone have any pros or cons?
66farmer is offline   Reply With Quote
Old 01-02-2014, 08:34 PM   #2
MisterC
MisterC's Avatar
Re: Rear shock relocation
I believe the No Limit relocation kit uses that approximate point. I've heard great things about them. They have a thread in the suspension forum.
http://67-72chevytrucks.com/vboard/s...d.php?t=444928
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 01-02-2014, 09:24 PM   #3
66farmer
66farmer's Avatar
Thanks, I will check them out.
Old 01-02-2014, 09:49 PM   #4
LVPhotos
LVPhotos's Avatar
Info note : the 60-62 frame had them outside leaned back like that. Sure there are pictures on my build thread.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-02-2014, 11:45 PM   #5
NEWFISHER
NEWFISHER's Avatar
Have them like that on several 4x4 rigs and work fine.
Make sure you compress the rear and load the axle into the notch then measure the compressed length and set up your brackets accordingly. You don't want the shock to bottom out before the axle does.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 01-03-2014, 03:16 AM   #6
pdxhall
pdxhall's Avatar
Here's the way member Frizzle Fry did it and I did the same with mine. Almost what you're talking about.
http://67-72chevytrucks.com/vboard/s...postid=4730005
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 01-03-2014, 10:20 AM   #7
66farmer
66farmer's Avatar
Thanks for the input. All get going on making new brackets today.
