Old 01-02-2014, 11:40 PM   #1
Razor454
Razor454's Avatar
Project remove my sunroof
Well, ever since I bought my truck in 1995 I've hated the sunroof in it. It never seemed to fit this type of truck (or any trucks for that matter). So I've decided to put my welding and fabrication skills to work and finally remove it once and for all! So here we go.....
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi
1997 C2500 Ext Cab 5.7 Liter
1955 3/4 ton 1st series w/ 235 straight six Sold it
Razor454 is offline   Reply With Quote
Old 01-02-2014, 11:42 PM   #2
Razor454
Razor454's Avatar
Re: Project remove my sunroof
First item on the list was getting a donor top, which I was able to acquire from a local board member (thanks again Bob). I removed it by drilling out each of the spot welds around the edge and cutting the back section of the cab to expose the spot-welds along the back.
Old 01-02-2014, 11:45 PM   #3
Razor454
Razor454's Avatar
the next step was to get my roof ready, so I used a wire brush attached to my 90 degree die grinder and polished away. This seemed to work the best to expose the spot welds.
Old 01-02-2014, 11:53 PM   #4
Razor454
Razor454's Avatar
Using a spot weld drill bit and some good ole elbow grease I was able to remove the top section.
Old 01-02-2014, 11:58 PM   #5
Razor454
Razor454's Avatar
Tonight I decided to cut and weld in the lower roof section. This was no easy task, as warp and mismatch are possible at this point. I just took my time and match everything up and spot welded until the cows came home...
Old 01-03-2014, 12:20 AM   #6
Mike's money pit
Looks great! I will be watching with interest because I have some rust to replace in my roof.
Mike
Mike's money pit is offline   Reply With Quote
Old 01-03-2014, 12:40 AM   #7
Razor454
Razor454's Avatar
Thanks Mike. Yeah, this is a unique opportunity to clean up the rust and paint this section.
Old 01-03-2014, 12:53 AM   #8
Leroy-B1
Good info I've never saw it done this way...I've saw the post cut and a complete top install...thanks for this
Leroy-B1 is offline   Reply With Quote
Old 01-03-2014, 01:19 AM   #9
Terry Crist
Have you ever tried these, http://www.eastwood.com/intergrip-pa...-set-of-4.html. to help keep everything flush.
Terry Crist is offline   Reply With Quote
Old 01-03-2014, 01:21 AM   #10
Razor454
Razor454's Avatar
I've never used them before, but I should pick up some and try them out. One of the biggest issue I had was with the "crown" of the roof, as its not flat.
Old 01-03-2014, 01:45 AM   #11
swamp rat
swamp rat's Avatar
Harbor freight has them a lot cheaper... are they worse or better i don't know but i have a set and they seem ok.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-03-2014, 11:27 AM   #12
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Subscribed!
I have to replace my roof top due to previously done poor repair job. I will watch how you are getting this done, but am curious about the rear spot welds along that seam.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 01-03-2014, 08:25 PM   #13
Razor454
Razor454's Avatar
I've pondered this idea for some time and I believe the best approach is to use 3M automotive panel adhesive. I'll have to either tack weld a few areas along the seam to keep it in place while it cures, or figure out a way to "clamp" the panel so it has the proper force to keep it in place.
Old 01-03-2014, 08:46 PM   #14
hugger6933
This time of year is the wrong time to think about using the panel bonding stuff. It needs to be pretty warm to work well I learned that the hard way putting a roof on a 04 C2500. With all the guts out [int.] the welder is still the best way to go. I had one of my body guys use some of the 3M bonding stuff on his bed skins on his truck [i was letting him build at my shop on the weekend on his time] it failed soon as we lifted the bed to place it on the truck. I can't atest to his proper use of the product , but I do know I used it right with the exception it got cold the night I used it and it failed. The work progress is looking real good, there is a new skin out now for those needing to do this and not able to find a donor. I have done this many times using used panels and it does make the labor twice as much and at some point you may have to consider the amount of labor, but I always figure mine is cheap. Jim
hugger6933 is offline   Reply With Quote
Old 01-03-2014, 08:51 PM   #15
BugzC10
BugzC10's Avatar
Looks like your outer skin would be a good candidate for the 3M Panel Bonding, but like you said the clamping in place could be an issue. Maybe weld temporary brackets on each side of the seam around the back and back corners to give you a clamping points. You should be able to use C clamps in the front and the sides. I'm no expert...just an observation.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 01-03-2014, 08:51 PM   #16
hamjet
hamjet's Avatar
I used a product by Lord Corp. called Fusor for applying rockers and cab corners on a 1990 pickup 6 years ago. its still holding, but I used pop rivets to hold it till it cured then ground them off....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 01-03-2014, 09:18 PM   #17
Razor454
Razor454's Avatar
hugger6933, I agree with you on the temperature. I'm kind of at a stopping point until the temp increases, as I also need to paint the inside with an expoxy paint. Also, I know that this stuff will work, but I need to make sure I have four things correct: Temperature, pressure, cure time and bond gap. If I miss anyone of these items my bond will prematurely fail.
Old 01-03-2014, 10:46 PM   #18
black_sheep454
3m panel bond is some very strong stuff. I've glued a ton of bedsides and roof skins on with it. Just make sure it's prepped well and you'll have no problems.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 01-03-2014, 11:16 PM   #19
chipflyer
chipflyer's Avatar
I plan to replace my roof with one that has hockey puck style marker lamps and plan to do what you have done to remove the roof. The only way to put the roof on and make it look right along the back seam is to use panel bonding adhesive. The front and sides could be plug welded but there is no way to weld the back and have it look correct. I've had good luck with panel adhesive too, not a bit afraid to use it.
Take a look at this older thread, lots of great info.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 01-03-2014, 11:56 PM   #20
Terry Crist
Cool, I did not know they had them. I'll have to check them out.
Old 01-04-2014, 12:47 AM   #21
SCHRUMGMC
SCHRUMGMC's Avatar
Thank God...I don't know why in the hell people put sun roofs in these things
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 01-04-2014, 01:49 AM   #22
sduckworth13
sduckworth13's Avatar
Cool Mark, glad to see you tackling the roof repair. I removed the inner and outer panels recently after I botched a antenna hole repair in the roof. Good luck on the repair.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-04-2014, 07:35 AM   #23
Elliot949
Dan Johnston
Elliot949's Avatar
Nice work man...
Elliot949 is offline   Reply With Quote
Old 01-04-2014, 09:27 AM   #24
69SWB4X4
69SWB4X4's Avatar
I am about to do the same repair on my truck. My thought was to flange the sunroof opening and cut a patch from my donor skin. Could also flange the patch if room is an issue.. On the inside I plan to use dyna mat in the old sunroof hole and add a headliner.. Thoughts??
69SWB4X4 is offline   Reply With Quote
Old 01-04-2014, 09:46 AM   #25
67 chevelle
67 chevelle's Avatar
3m panel bond is great stuff , I have never had a problem using it , for quarter panels and other things , I do live in Florida though , I use small self tapping sheet metal screws to hold it and then just fill them
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
