Old 01-23-2014, 12:10 AM   #1
LS-K
'87 tank/fuel pump supplier
I've hung around reading all your great threads on fuel and electrical. I figured this weekend I'm taking the plunge into fuel system set-up. I have two questions and I hope someone can help. I've read threads where a lot of you have ran the '87 fuel tank for its direct fit into the K10 trucks and because it was the first year Chevy went to in-tank fuel pumps and EFI.
I've also read about folks utilizing a Tahoe's fuel pump assembly. Questions are as follows:
1)What supplier is the best and easiest to get the '87 tank from? Exact Part Number? I have seen some on RockAuto for the R/V series trucks, the part numbers I've found are listed below in the pic.
2) Regarding the in-tank fuel pump, whats the best route? Get the complete assembly from an early thousands Tahoe, or go with an '87 sending unit and but a Walbro 255 lph fuel pump or similar LS capable pump? Theres a pic of an '87 sending unit I found that I'm thinking I can install a good LS rated(capable) fuel pump.
http://www.classicparts.com/1987-91-...tinfo/23-546/#
Your help is VERY VERY appreciated!!
LS-K is offline   Reply With Quote
Old 01-23-2014, 12:26 AM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: '87 tank/fuel pump supplier
Well here is how I did mine. It's not exactly want you have really asked for but you can do the same thing. This works great in mine.
I bought a 93 Suburban tank for TBI back several years ago, I pulled the sendor out and installed the 305 TPI pump in it. Now I plan to install the LSx pump in it. So far though the old pump is meeting the 58lbs of pressure required so it maybe awhile before I do it. I will perform this before the Power Tour for sure just for good insurance it want go out on the tour.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-23-2014, 12:36 AM   #3
LS-K
Any idea how that '93 tank fits into my '82 Short bed K10?
Old 01-23-2014, 02:19 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: '87 tank/fuel pump supplier
Wasn't meaning for you to use the 93 tank. Use the tank you have and just swap out the fuel pump on the sendor unit with a LSx motor pump. You may even be able to get a whole sendor to swap out out of a junkyard truck. Most GM sendors are interchangable now.
Fuel pump assemblies for the LS1 engines with dual lines. The fuel pump assembly on the right has had the fuel sending unit removed for installation in a retrofit LS1 project. Even though it is possible to use these assemblies from the GM FWD cars from 1996 up, you will need to replace the fuel pump for proper pressure and volume requirements. these can be installed in a tank with a flat top and it will require ingenuity to mount and seal. Always use a gasket (cork/rubber) for a seal and you can use small sheet metal screws to install the pump to the tank. These is also possible if you have a single line fuel pump assembly from a 2002 and later vehicle.
Old 01-23-2014, 03:23 AM   #5
Classic-Steele
Classic-Steele's Avatar
I used an 87 blazer tank and sending unit, but but just reworKed some of the wiring and ran am Aeromotive 340 pump. It dropped in, and should work like factory except with the ability to support 800 HP.
Classic-Steele is offline   Reply With Quote
Old 01-23-2014, 04:15 AM   #6
Andy4639
Old member
Andy4639's Avatar
That's what I'm talking about. Good old injunutee if thats a real word!
Old 01-23-2014, 07:37 AM   #7
LS-K
Thank you both for the info, its all very useful!
C-S,
I think I'll roll with the sending unit and pump you went with, any chance the part numbers I listed in the top pic are the correct "87" tank I need for my short bed truck? Also, that 340 pump, whats its regulated by?
Old 01-23-2014, 10:40 AM   #8
Classic-Steele
The 2002 trucks still had the regulator and return on the fuel rails.
Old 01-23-2014, 12:11 PM   #9
solidaxel
solidaxel's Avatar
I used a 87 Doreman tank for my 78 SWB single tank on pass. side
The sending unit for the same year 87 (matched my gauge in dash)
the pump was a stock over the counter for a 2002 Camaro and has 52# pressure, I don't know what the GPH rate is but it ran the Camaros so it "better" work with this 5.3.
It starts and runs but I do not have it on the street
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-23-2014, 12:13 PM   #10
solidaxel
solidaxel's Avatar
Are both the fittings supply and return, on this sending unit 37* flare?
LS 3 4L70E
Old 01-23-2014, 01:30 PM   #11
Classic-Steele
No. unfortunately they are the metric bubble flare type. I'll either haFta run an adapter to -6 an, weld a bung on. Or cut and flare it. Kinda undecided at this point still... probably end up going with whatever is easiest.
Old 01-23-2014, 01:32 PM   #12
Classic-Steele
Thanks Andy! I love trying to just "make it work"
Old 01-23-2014, 02:30 PM   #13
LS-K
I just ordered the '87 sending unit. I'll either go with what you did or a Walbro 255. Now my question is, what regulates the fuel? Do I need an inline regulator or?....
Old 01-23-2014, 04:14 PM   #14
Andy4639
Old member
Andy4639's Avatar
Depending on which year model LSx motor you have it should have a regulator on the drivers side fuel rale.
If not you can buy the fuel filter with built in regulator and the return line hookup back to the tank.
Old 01-23-2014, 05:38 PM   #15
aggie91
I'm just glad to be here!
aggie91's Avatar
LS-K
Since your truck is the short bed, you need the 16 gallon tank, part number GM11C. I purchased the Spectra Premium tank listed above in your rockauto.com list. I got a better price on Amazon.com at the time I purchased mine.
Amazon.com: Spectra Premium GM11C Fuel Tank for... Amazon.com: Spectra Premium GM11C Fuel Tank for...That tank can be mounted on either side of the truck. The sender is side specific for the '87 tank with fuel injection. I mounted ours on the driver side and used a spectra premium sending unit for an '87, part number FG05F.
Spectra Premium FG05F Sending Unit for General... Spectra Premium FG05F Sending Unit for General...
I used a Walbro 255 intank pump. The Aeromotive pump that Classic-Steele used might be a better choice depending on the power you are going for now or later...
The regulator depends on the LS engine fuel system. If it is a return style (2 lines at the engine) it has the regulator built into the rail. If its a single line system (returnless), then in need the Corvette Filter/regulator shown above.
Hope this helps.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-23-2014, 06:53 PM   #16
dec010974
dec010974's Avatar
On my 1987 c10 LSx swap, I used a fuel pump from the vortec trucks. 1996 thru 1999 gen1+ Engines. The part EP381, ACDelco. It work very well.
dec010974 is offline   Reply With Quote
Old 01-23-2014, 08:01 PM   #17
LS-K
I have an LS6 engine from a 2005 CTS-V. its the return-less system. heres a pic of my fuel rail.
Old 01-23-2014, 08:03 PM   #18
LS-K
aggie,
thank you for the info. I went ahead and ordered both Walbro and tank right before this reply. This is an awesome group of people on this board.
Old 01-23-2014, 08:06 PM   #19
LS-K
DEC,
So that newer style assembly was a direct fit? ring nut and all?
Old 01-23-2014, 08:40 PM   #20
truckdude239
truckdude239's Avatar
i used an 87 surbuan tank and sender and used an ac delco ep381 pump
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-23-2014, 08:58 PM   #21
Andy4639
Old member
Andy4639's Avatar
Here is the regulator per your picture. Also found this on the net. Check the link.
http://www.counterman.com/Article/74...supernova.aspx
Old 01-23-2014, 11:44 PM   #22
LS-K
Andy I read the article, now the regulator on the fuel rails, I was under the impression that the regulator on the rails is to regulate(even out) the pressure that flows to each side of the fuel rail, so that each side get the correct and same amount of fuel?
Old 01-24-2014, 12:00 AM   #23
Andy4639
Old member
Andy4639's Avatar
Correct. That's all your system needs. As mine it's all there is to regulate it. Mine just has the return line as did my TPI setup. Why I can't say but I'm sure some one can.
Old 01-24-2014, 12:07 AM   #24
LS-K
Right on! Yea my rail only takes on two lines, one is the evap and the other well, we already know.
Old 01-24-2014, 12:34 AM   #25
ls1nova71
ls1nova71's Avatar
You will need the Corvette filter/regulator. That rail you have is returnless, there is no regulator on it, that thing that looks like a regulator is a pulse damper, does nothing to regulate pressure.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
