Old 01-10-2014, 04:35 AM   #1
68ls1
68ls1's Avatar
Steering Box Upgrade - What are the options
Looking for am assist. As per title, wanting to quicken & firm up the power steering on my 72 C10 SWB. It is just being set up as a nice handling regularly driven truck. Will have a 4/6 drop on 19" wheels
What options are there out there?
Have done some web searches, but first hand knowledge is best.
cheers Roger
68ls1 is offline   Reply With Quote
Old 01-10-2014, 09:28 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Steering Box Upgrade - What are the options
Do you just want to restore original performance or do you want to indulge in a major upgrade, such as installing a rack?
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 01-10-2014, 12:36 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Check with our forum vendors to see if anyone is offers AGR steering boxes. I am told they work really well. LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-10-2014, 01:47 PM   #4
Low Elco
Power Steering Specialties, Springfield, MO. Ask for Chip. He can build 'em any way you want. around 200. Did a great job for me.
Ach, just saw you're an Aussie. Sorry! Ken's got it, AGR's probably a good bet.
Low Elco is offline   Reply With Quote
Old 01-10-2014, 02:56 PM   #5
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I like those AGR boxes... I need to pick something up as well...
http://www.summitracing.com/ga/parts...del/c10-pickup
chevyguy_72 is offline   Reply With Quote
Old 01-10-2014, 08:30 PM   #6
68ls1
68ls1's Avatar
A rack is not on the cards, due to the fact here I would have to have truck engineered for that modification, far too much mucking around
Does anyone know how many turns lock to lock the AGR box is?
Thanks to everyone for their responses
Old 01-11-2014, 09:09 PM   #7
theastronaut
theastronaut's Avatar
No Limit makes a bolt in rack kit. Fixes the bump steer issue, and there are less joints to wear out.
theastronaut is offline   Reply With Quote
Old 01-14-2014, 01:21 AM   #8
68c10airstream
68c10airstream's Avatar
Hi roger, in my 68 c10 i installed a factory c10 box from a 1985 chevy. 3 1/2 turns lock to lock and the best part is variable ratio, so this means the box reacts nicer and a little slower in the center area (about 17 to 1 ratio) and then firms up and reacts about 13 to 1 for the rest of the turn. My schooling in the 70's was that the corvettes with a very quick box were twitchy and over-react at high speed so gm designed the variable ratio in about 73-75. This is my favorite box as it's the best of both worlds. Look in the glove box lid as the build sheet will id it as such. If you doubt the feel drive a late model gm truck from about 1975 to 1995 and see what you think. 1996 went to an easy steer with too much assist and doesn't feel right, too light and easy. Newer boxes use different lines so get the junkyard lines and the fitting in the back of the pump also and install and enjoy. Good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 01-14-2014, 02:32 AM   #9
68ls1
68ls1's Avatar
Have ordered the AGR box, will report back when it arrives and is installed.
Old 02-11-2014, 05:23 AM   #10
68ls1
68ls1's Avatar
Well AGR Steering Box is installed, had one 25 mile drive today
The truck did drive very well before, but I'm very pleased after initial drive in improvement. Feels much tighter (old box could have been 40 years old?), no vagueness or wandering in a straight line. Turn in is much sharper. Has helped with turning circle, a good thing. Doesn't feel too heavy.
I would recommend this box.
Old 02-12-2014, 09:56 PM   #11
stomper
Junior Member
stomper's Avatar
I like these guys:
http://www.redheadsteeringgears.com/
"Probably the most unique and important thing we do is custom fit every single worm and piston assembly with new precision fit steel balls. This is a process not matched by any other company in the industry."
They can tune the box for steering effort and rebuild with a quicker ratio if desired. I have a high effort quick box in my 71 SWB and it totally changes the feel.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Gold White Fleetsides/Saddle
stomper is offline   Reply With Quote
Old 02-12-2014, 10:21 PM   #12
68ls1
68ls1's Avatar
Originally Posted by stomper View Post
I tried to contact them a couple of times, got no response
Maybe they don't deal with International buyers?
The AGR box is very good, maybe better than expected.
Old 02-12-2014, 10:34 PM   #13
bdiamond
Not sure about the inspection rules where you are but you may check into the "caster mod". More caster would definitely firm up turning.
bdiamond is offline   Reply With Quote
Old 02-12-2014, 10:44 PM   #14
68ls1
68ls1's Avatar
The steering with AGR box is now definitely firm. Tracks great.
Next is taller rims with lower profile tires, can feel it roll on tire sidewall now.
Old 02-13-2014, 10:06 AM   #15
chevyguy_72
Vintage Evil
Is the AGR box less turns lock to lock?
Old 02-13-2014, 05:19 PM   #16
68ls1
68ls1's Avatar
Yes, it is just over 3 turns lock to lock, so I would guess about a full turn less than the old stock box.
Old 02-13-2014, 09:41 PM   #17
chevyguy_72
Vintage Evil
Where did you end up purchasing it?
Old 02-13-2014, 09:53 PM   #18
68ls1
68ls1's Avatar
Summit
Old 06-05-2014, 05:11 PM   #19
kitsbeach
kitsbeach's Avatar
Does it bolt right in.? Summit's site has this note:
Application Notes:Fits model with after market crossover steering only.
kitsbeach is offline   Reply With Quote
Old 06-05-2014, 05:15 PM   #20
kitsbeach
kitsbeach's Avatar
Will the No Limit rack and pinion bolt in to a basically stock front suspension.?
I'm looking at doing a 5.5" drop (2.5" spindles and 3.0" coils).
Old 06-05-2014, 06:47 PM   #21
68ls1
68ls1's Avatar
Hi, was direct bolt in, had it fitted by my mechanic.
Old 06-09-2014, 12:34 PM   #22
aggie91
I'm just glad to be here!
aggie91's Avatar
Yes, did it on my son's '82.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-16-2014, 08:46 PM   #23
jeh
jeh's Avatar
I was getting ready to ask the same question. Thanks
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
