Old 08-10-2014, 07:35 PM   #151
1972 Jimmy
1972 Jimmy's Avatar
Re: What did you do to your Blazer/Jimmy today?
Originally Posted by DeadheadNM View Post
Thanks for posting. Very nice job on the roll cage! Not sure this applies to you but I've seen guys who often off-road in sand (dunes) weld plates across the top to keep from sinking in if the truck rolls.
Never really thought of that! I don't plan on doing any hard wheeling with it. If this thing rolls in the sand I'll have more problems than it sinking in!!! The main reason for the roll cage is to be able to go out with the family ( Wife and 2 little ones 3yrs & 6yrs) on the michigan state park dunes with no hard top on. Park rules state that behind every row of seating there must be support structure over head. Also the wife wants to drive it around town during the summer with the kids. Safety first!!!
1972 Jimmy is offline   Reply With Quote
Old 08-10-2014, 07:38 PM   #152
1972 Jimmy
1972 Jimmy's Avatar
Originally Posted by rckymtnhi View Post
Man, that cage looks awesome! Any chance you could post a couple of more pictures?
Here is some more pics for you!
Old 08-10-2014, 10:27 PM   #153
rckymtnhi
Looking GOOD! That's just what I need - I'm re-motivated!
rckymtnhi is offline   Reply With Quote
Old 08-11-2014, 09:18 AM   #154
orange72blazer
orange72blazer's Avatar
Is that a Bronco Bob roll cage? If so how do you like it? I have been thinking of getting one but wanted to see what one looked like installed in a Blazer, the pics on there website don't really show much.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is online now   Reply With Quote
Old 08-11-2014, 09:47 AM   #155
Wasted Income
Boosted Member
Wasted Income's Avatar
YES!! More pics/info on the cage! I have been trying to think up a design that would look good in my 2wd, and I think that might be it!
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 08-11-2014, 07:07 PM   #156
1972 Jimmy
1972 Jimmy's Avatar
Hey guys,
Yes the majority of this cage is from "Bronco Bob's" (BB's). Bob bends all the tubing (2" DOM .120 thick) up for you, all you have to do is cut and notch the tubes to length. The portion of the cage in the bed is all bent tubing from BB's. However, I ended up not using the front tubes going down the windshield frame. No fault of BB's. I was not specific when I ordered the cage stating that I needed clearance for the A/C vents in the dash. I could of used BB's front tubes they would have just come straight down to the into the door opening to allow clearance for the A/C vents. So, I had the front tubes bent (1.75 DOM .120 thick here in my home town) to clear the A/C vents and allow more foot clearance getting in/out of the truck. Also, I added two bends in the upper horizontal windshield bar to get more head clearance and also allow the use of the sunvisors.
Overall very happy with the BB's set up!!
Just a couple of helpful fab'ing tips....I ran into struggles trying to fit a cage under multiple tops (original double wall, original single wall and a Softopper)
I started out installing the cage with the plan of having it fit under a double wall and a softopper. So I started with the double wall on the truck thinking the cage would be a tighter fit. Which the sides were very tight!!! When putting on the softopper the cage was way to tall to clear the softopper support bows. I had to drop the middle hoop 2" in order to clear to Softopper front two bows. So everything was great in till I found a single wall top on craigslist. I bought it wanting to replace the double wall. Well.....believe it or not the single wall cage will not fit under the cage unless you significantly shorten the height of the hoops or have BB's bend the hoops to a lesser width. So when our ordering from BB's make sure you state if you have AC or a double vs single wall top!!
One last thing you might want to keep in mind when you fab'ing up the mounting plates, you might want to keep the outside edges within the bedside rails so that you can pull the entire cage out of the truck to paint it or remove it for any reason.
If you guys want any more specific pics let me know!!!
Hope this novel helps!!
Eric
Old 08-12-2014, 09:38 AM   #157
Wasted Income
Boosted Member
Eric,
Thanks for the info! Can you elaborate a bit more about what you've got going on with the cage to frame connections? I think I see what you're up to, but some pics of the finished product would be great when you get them.
fab'd up roll cage to fame connectors this morning for the four rear posts.
Attachment 1287697
Turbo diesel
Old 08-12-2014, 09:53 PM   #158
Dale99
Got a large summit order in. Finished putting my transcase back together after 3+ weeks of waiting on various parts from different places.
Dale99 is offline   Reply With Quote
Old 09-06-2014, 12:22 PM   #159
asolde
asolde's Avatar
TTT... I been working on my factory air conditioning. I replaced the POA valve, the expansion valve,the water control valve and the reciever dryer, servise the system back up with R-12. I am getting about 54* at best. That's all I am going to that system for awhile.
I put on some new front brake pads today semi easy job. Next I am going to put a new engine in it as soon as it cools down here in Houston TX.
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 09-06-2014, 02:49 PM   #160
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nothing recent on my Blazer. Not sure I'll have time before it snows but would really like to install the slider rear windows. I've been tinkering with a 1/2 ton LWB 1972 GMC 4wd I recently got: http://67-72chevytrucks.com/vboard/s....php?p=6801778
Old 09-06-2014, 06:31 PM   #161
Senorx
Senorx's Avatar
Are you able to roll up and down your windows? There appears to be clearance issues with the window crank on your picture or could just be the angle of the picture. @1972 Jimmy
Senorx is offline   Reply With Quote
Old 09-06-2014, 06:31 PM   #162
asolde
asolde's Avatar
That's a cool truck Pete. I'm always looking around for trucks. I like them 4x4's
Old 09-06-2014, 07:34 PM   #163
Dale99
Put my radiator in, lower hose. Then put cup on my replacement fender, filled all my welds up, sanded down and some rattle can primer on them to keep from rusting over night.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Old 09-06-2014, 10:12 PM   #164
1972 Jimmy
1972 Jimmy's Avatar
You are correct! that is the only downfall with the cage. It's really tight to the door. I need to open up the door to roll up and down the windows. not that big a deal for me, we will only be driving it in the summer.
Old 09-09-2014, 06:52 AM   #165
Rocketman72
Rocketman72's Avatar
Finally painted last week, new bumper and grille added yesterday.
Name:  Grille bumper LF.jpg
Don aka Rocket_Man
72 K5 Blazer 454 CI
2002 Honda VTX 1800C
Rocketman72 is offline   Reply With Quote
Old 09-10-2014, 03:07 PM   #166
Mefford7
Mefford7's Avatar
Smile Re: What did you do to your Blazer/Jimmy today?
Brought my pasture find home.
A lady I work with overheard me talking about wanting a 1st Gen Blazer or Jimmy and said "I think my husband has one of those out behind the barn. You can probably have it if you will just come get it'.
I picked it up today!:chevy:
Mefford7 is offline   Reply With Quote
Old 09-10-2014, 03:21 PM   #167
Custom 68
Custom 68's Avatar
that is so not right... lol, nice score.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-10-2014, 04:29 PM   #168
grillzy
Nice score!
grillzy is offline   Reply With Quote
Old 09-10-2014, 05:56 PM   #169
62 short step
62 short step's Avatar
Wow!! Nice score!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 09-10-2014, 07:12 PM   #170
Senorx
Senorx's Avatar
Why don't these things happen to me? Nice!! Congrats on your barn find.
I spy 3 things I'll buy from you if you are going to scrap them. The spare tire carrier, front buckets and that factory air cleaner.
Old 09-10-2014, 10:03 PM   #171
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice!! Are the shoulder belts listed on the SPID?
Old 09-11-2014, 04:17 AM   #172
jaros44sr
jaros44sr's Avatar
Can t beat the price with a stick....what are your plans for it? Nice find, ya never know where these things will turn up
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-13-2014, 08:57 PM   #173
Mefford7
Mefford7's Avatar
Not unless they are part of one of the packages.
Old 09-13-2014, 09:02 PM   #174
69chevytrucker
69chevytrucker's Avatar
you could always change to power windows
69chevytrucker is offline   Reply With Quote
Old 09-13-2014, 09:03 PM   #175
Mefford7
Mefford7's Avatar
I plan on using them. But if things change I'll let you know! (and as many times as I've already changed my dream/direction already, there's a good chance)
