Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 01-13-2014, 12:52 PM   #126
robnolimit
robnolimit's Avatar
Re: No Limit Spy Photos
Originally Posted by 3li9 View Post
i love the rear rail kit...
how low would it go with shockwaves aired out? i looked a lot of pics but i can t find the it out... wich lenght of shockwaves would fit it?
thx
are there some pics?
Length of the Shockwave will have an impact, but the limiting factor is still the axle/frame rail clearance. Aired out the rocker will be appx 3" off the ground with a 28" tire. At this point the OETrialing arm and trans crossmembers are 1" above the dirt.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 01-13-2014, 04:03 PM   #127
CHRIS67GMC
CHRIS67GMC's Avatar
About like this.
CHRIS67GMC is offline   Reply With Quote
Old 01-14-2014, 05:42 PM   #128
3li9
3li9's Avatar
thx a lot for the anwers and the pics...
sounds great
Loving my Dolly
Greetings from Germany
Andy
3li9 is offline   Reply With Quote
Old 01-14-2014, 05:58 PM   #129
3li9
3li9's Avatar
does anyone have the link to the thread where the truck is in it which is in the c10 builders guide from street trucks? i mean the pro touring chassis illustrated in that magazine?that who has the no limit suspension all around...
i find it few days ago but don t remember where it is and can t find it;(
thx...
Loving my Dolly
Andy
Old 01-14-2014, 06:11 PM   #130
SCOTI
SCOTI's Avatar
thx...
Prob not the 'same' truck, but the one directly posted above hase basically the same chassis. It uses Shockwaves vs coil overs....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-14-2014, 06:13 PM   #131
3li9
3li9's Avatar
yes i saw that built thread the rear is raised 5.5 inches...
but i find a thread were that pro touring chassis from the builders guide was in and can t find it anymore...
Loving my Dolly
Andy
Old 01-14-2014, 06:34 PM   #132
CHRIS67GMC
CHRIS67GMC's Avatar
The height of mine is the same as the rear rail kit. I did raise my rails a little more but it was for how I did the sway bar and panhard bar.
Old 01-14-2014, 06:47 PM   #133
3li9
3li9's Avatar
Olay thx
Loving my Dolly
Andy
Old 01-30-2014, 02:12 PM   #134
Dobster
Originally Posted by robnolimit View Post
1) We use a Romic billit coil-over. They have worked with us for years to get the valving set correctly for the weight balance of a truck, not the average camaro. The lower mount is a 'trunion'. - These coilovers are display units, built to be at 'Ride Hieght'. The IFS will come with 5" stroke shocks, 12" - 17" and 12" springs. 2) The upper coil-over mount is part of the crossmember. 3)This is how get the track width without the bumpsteer. 4) The custom machined rack extension installs on the PASSENGER side only. Use red locktite. The factory rack boot will cover it just fine. 5) Bolt in the rack and tie-rod ends.
Can I ask why the offset on the rack? Why not just center the rack?
I am just wondering, i was going to center mine. "If I was to install my own" Would I lose travel?
Dobster is offline   Reply With Quote
Old 01-31-2014, 09:55 AM   #135
CHRIS67GMC
CHRIS67GMC's Avatar
You would have to put a extension on both side if you centered it. Then the steering shaft would probably be in the engine. You keep it all the way to the left for clearance.
Old 01-31-2014, 09:57 AM   #136
Dobster
Thanks Chris
Old 04-07-2014, 11:22 AM   #137
higXtech
higXtech's Avatar
... The motor mounts also act as bracing for the rails and upper A-arm mounts. Motor mounts will accept SBC, BBC, and LS motors using #31-2267 side mounts, and adapter plates for LS.
you have a LS adapter plate you like for this setup?
1968 fleetside - nolimit wide ride front and rear + ridetech
higXtech is offline   Reply With Quote
Old 08-25-2014, 09:56 AM   #138
PHATTIRE67
How wide is it from rail to rail? How wide of a back tire can be used? I think this may be exactly what I need.
PHATTIRE67 is offline   Reply With Quote
Old 08-25-2014, 01:27 PM   #139
skeeterbug
skeeterbug's Avatar
Size:  33.7 KBhey rob thats what i need for my 71 c10 lwb dedicated drag truck (no street), you us racers are all about weight and weight is King. I just dont need everything that comes in the package, like sway bars and power steering (whats that) lol. Can you sell just parts of it? And a manual rack would be nice.
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 08-25-2014, 01:29 PM   #140
skeeterbug
skeeterbug's Avatar
And the ZG spindles seperate....mabey?
2013 best 7.39
2014 best-7.38
Old 08-26-2014, 12:01 PM   #141
robnolimit
robnolimit's Avatar
The raised rail kit (long/short) stays at 34 3/8" wide O.D. all the way back. The inner fender lip is 73 1/2" I.D. So, inner lip to frame rail is 19.5". Out FatBar 4-link sits outside the rail, and takes up 3 1/2", So with that suspension you have 16". Plenty of room for a 345 tire or a 12" slick.
Old 08-26-2014, 12:24 PM   #142
robnolimit
robnolimit's Avatar
Originally Posted by skeeterbug View Post
Attachment 1293545hey rob thats what i need for my 71 c10 lwb dedicated drag truck (no street), you us racers are all about weight and weight is King. I just dont need everything that comes in the package, like sway bars and power steering (whats that) lol. Can you sell just parts of it? And a manual rack would be nice.
For our WideRide IFS, yes, we can do a manual rack. This is a flaming river billit rack, and adds +$200. We can drop the sway bar, -$175. The ZG spindle is avail separately, $380 pr, but really won't fit any OE suspension. - but, we can drop the 12" OE brakes (23 lbs per side) -$250, and you can use a Wilwood 12" dynalite drag brake (11 lbs per side). The standard WideRide is 180 lbs lighter that the OE IFS. Man rack saves 6 lbs, + pump and hoses. No sway bar saves you another 18 lbs. Do the brake swap and save another 24 lbs. That 228 lbs. off of the front. Should be worth .250 sec.
Old 08-28-2014, 09:18 AM   #143
skeeterbug
skeeterbug's Avatar
Thanks rob sounds like a drag setup to me, i will get w/ you after the season about this. Sub seven sec. range here i come!
2013 best 7.39
2014 best-7.38
Old 09-12-2014, 12:39 PM   #144
kitsbeach
kitsbeach's Avatar
Can that top mount rear sway bar be mounted while the bed is on the truck.?
Also do people do their C-notches with the bed on..?
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is offline   Reply With Quote
Old 10-09-2014, 12:40 PM   #145
BigDaddyV
BigDaddyV's Avatar
Rob,
I'm building my 72 c10 short box to lay frame.
Will the rear rail kit allow me to achieve this or will I bottom out before laying out?
Thanks in advance.
I'm just checking my options and I really like the rear rail set-up,
But It appears to not be what I will need.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 10-09-2014, 02:44 PM   #146
CHRIS67GMC
CHRIS67GMC's Avatar
BigDaddyV
With the raised rail kit and a 26 inch tall tire the frame will be 1.75 inches off the ground roughly. If you put in a small c notch you could get there. What rear suspension are you thinking?
Smitty
Old 10-09-2014, 02:48 PM   #147
BigDaddyV
BigDaddyV's Avatar
If I were to go with the Rail Kit, I was gonna do the no limit Fat bar 4 link. with bags.
Old 10-09-2014, 02:54 PM   #148
CHRIS67GMC
CHRIS67GMC's Avatar
With bags I think you will be ok going lower you might have lower mounts a little.
Old 10-09-2014, 03:12 PM   #149
BigDaddyV
BigDaddyV's Avatar
I'm sure I could make it work, and I'm no stranger to Fabrication. I may go that route....
But then again, I just realized you said 26" tire.... I won't run anything smaller that 29" on the rear so it may be a problem...
Old 10-09-2014, 03:36 PM   #150
CHRIS67GMC
CHRIS67GMC's Avatar
You could probably get to .75 of the ground with a 29 tall tire.
