Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 11-01-2014, 07:45 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Project "Man Pedal"
I figured I'd start a project thread for my manual tranny swap in my 86 K5. I'll get some pics this weekend. I believe I have all the parts collected to begin. Once I sell the 700r4/208 combo I will drop them.
I originally found a 1971 SM465/NP205 combo and bought the pedals and bell housing/hydro clutch from board members. Going to use them but I found another SM465/NP205 combo from an 1984 and will use them vice the 71 parts. I will be able to use my front driveshaft from the 700R4/208 but will need to fabricate one for the rear.
I am hoping to find some 8-lug axles(3/4 ton) before this is done so I can swap them in too.
Other plans:
-Raptor line the inside (interior is removed)
-new exhaust with ram horns purchased from a board member (currently has headers that prevent installing front drive shaft)
-has a small amount of lift via add-a-leafs front and rear (might replace with lift springs)
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-05-2014, 10:43 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: Project "Man Pedal"
My first update, sold the 700r4/208 combo. Dropping them this Saturday. Then I'll start putting her back together.
Old 11-07-2014, 09:44 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Got the headers off today. Tranny/TC will be gone tomorrow.
Old 11-08-2014, 08:06 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
700r4 and np208 removed.
Old 11-08-2014, 08:07 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
1971 SM465 and NP205 I was going to use. The 1984 SM465 is in the background as is the 1987 bell housing I am going to use.
Old 11-08-2014, 08:10 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The 1984 SM465 and 1984 NP205. Tomorrow I am going to remove the old pedal assembly and mark the firewall to mount the master cylinder and reservoir. I also need to look into cross members, not sure if the auto cross member will work, looks like it does not drop down in the center far enough.
Old 11-09-2014, 06:33 AM   #7
19silverado77
Your cross member may work I swapped a 68 465 into my 77 and it worked so I suppose it should.
19silverado77 is offline   Reply With Quote
Old 11-09-2014, 07:26 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have the 71's cross member, I will try it too.
Old 11-10-2014, 10:17 PM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Looks like I need a pre 85 cross member to work with my 84 SM465/NP205. The nice thing is I found one locally on craigslist. Going to get it tomorrow!
Old 11-16-2014, 06:43 PM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I went to pick-up the cross member I found and come to find out the truck he was parting out was an 86, not an 84. Oh well, still looking for a pre 85 cross member.
Old 11-17-2014, 01:24 AM   #11
argonaut
argonaut's Avatar
Looks like you're making good progress. I must say I'm a little surprised to see you swapping an overdrive trans with a non-overdrive unit. What motivated the auto to manual swap?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 11-30-2014, 08:12 PM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have always enjoyed driving the manual trannys. This vehicle is more for fun, I have a Tahoe I drive for day to day stuff.
No update, but I have everything I need to install the 465/205 into my K5. Might be another week since the clutch went out in my K25 and I want to get it back on the road first.
Old 12-08-2014, 08:58 AM   #13
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Well. My K25 clutch issue was not the clutch. Turns out the power sleeve splines were all stripped out. Ordered a new one on ebay. Also, the last few odd and ends are coming in, tranny hump and shifter for the K5. Probably replace the power sleeve in that one too.
Old 12-26-2014, 07:03 PM   #14
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Lots of progress today. The tranny is in! Also, have the adapter bolted to the transmission and the cross member installed. No more jack-stand holding up the engine!
Going to swap pedal assemblies and install the clutch master cylinder tomorrow. The slave cylinder needs to be replaced or rebuilt too.
Also going to install the ramhorns and looks like a custom dual exhaust or maybe a heartthrob exhaust. Not sure yet.
Old 12-27-2014, 07:55 PM   #15
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Started to remove the pedal assembly and drill the holes. Also mounted my "new" exhaust manifolds. You can see the dimples on the firewall next to the brake booster where the clutch master cylinder mounts.
Old 12-27-2014, 07:57 PM   #16
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
manifolds and tranny installed:
Old 01-19-2015, 08:17 PM   #17
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Started prepping for pedals.
Old 01-19-2015, 08:20 PM   #18
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Couple more.
Old 01-24-2015, 09:49 PM   #19
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Got the steering column out of the way. Easier than I thought. Also, started putting the pedal assembly in. Here's a couple update pics.
Old 01-25-2015, 09:04 PM   #20
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I got the steering column in.
Old 01-25-2015, 09:35 PM   #21
argonaut
argonaut's Avatar
Nice progress! Real men drive stick!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 01-25-2015, 10:59 PM   #22
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thanks Jason. Before I put the gauges back in I need to make sure I have the clutch pedal attached to the master cylinder correctly. Looking for some pics/info now.
Old 02-12-2015, 01:22 PM   #23
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Quick update. I should be all done by March 1st. I have ordered an exhaust kit and the drive shafts are at the driveline shop now. Worked out my clutch hook-up issue and the interior is almost all back together.
Old 02-13-2015, 10:29 AM   #24
argonaut
argonaut's Avatar
Awesome! You must be excited to drive it.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 02-13-2015, 10:17 PM   #25
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I am, this has been 2 months longer than I planned.
