11-06-2014, 09:25 PM | #1 |
Drum to disc swap? - Camaro rear end
Any leads on what is needed to swap my drums to discs on my 2nd Gen Camaro 10bolt rear?
The drums aren't going to cut it for my project |
11-06-2014, 11:22 PM | #2 |
Re: Drum to disc swap? - Camaro rear end
Check Summit Racing. They have kits for that.
11-07-2014, 12:39 AM | #3 |
Speedway also sells kits this one has no "E" brake, but they also offer one with "E" brake...Jim http://www.speedwaymotors.com/GM-75-...Kit,14021.html
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
11-07-2014, 01:44 AM | #4 |
That was easy. Thank you guys!
11-07-2014, 09:10 AM | #5 |
Be very careful about the calipers with the E brake function. I've had zero luck making them actually function with the Lokar E brake. Doesn't have enough travel + those brakes are hard to adjust and keep adjusted on a specialty car, at least in my experience. I'll NEVER buy those calipers again. Instead, I'll spend the extra bucks and get the system that has the drum style E brake in the rotor when I do the 9" in my 55.
11-07-2014, 09:49 AM | #6 |
polishing a turd
I used 98-02 f-body rear discs. 12" rotor with dual piston aluminum calipers and drum style ebrakes. You just have to mount them on opposite sides as the car they come on and it should bolt up. It did for me on my '77 nova 10-bolt
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
11-07-2014, 10:49 AM | #7 |
Thanks speedbump I'll keep that in mind.
1TonFun, we're the brackets a direct bolt on application after swapping sides or is there more to it? |
11-07-2014, 11:58 AM | #8 |
if your still in the gathering parts stage...
does the 2nd gen trans am have the disc brakes like the 3rd gen? i bought the 86 trans am rearend for $200, less than the cost of the kits you don't say what year truck your working on, check out the link in my sig
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-07-2014, 04:22 PM | #9 |
Mine is a 56.its got a Camaro rear under it already
11-07-2014, 07:09 PM | #10 |
I just got this #140-5237 kit from no limit. wilwood also has a calipers for the front called a D-52 #120-10937. Rob at nolimit helped me with the part#s to get the correct balance front to rear.
11-07-2014, 11:44 PM | #11 |
Does anyone know if the 98-02 f body front calipers will fit the 2nd Gen spindles?
