Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 02-16-2009, 03:42 PM   #126
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Re: Color Wiring Diagram FINISHED
Originally Posted by bac1755 View Post
does anyone know if there is a diagram out there showing what amp fuses go in what spot? for some reason my fuse block doesn't say. i think its been replaced.
Does it look like the one from Krue?
If you look real close you can see the ratings next to them.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline
Old 02-16-2009, 03:49 PM   #127
bac1755
bac1755's Avatar
it does look like the one from krue without any markings.
bac1755 is offline
Old 02-16-2009, 04:01 PM   #128
blukangoo
blukangoo's Avatar
I donīt have my users guide here at home but the ratings should be in there.
Maybe someone has one at home and they could scribble them down real quick? ;-)
If I have time tomorrow I will get a better picture up from mine.
By The Way:
I changed the links again so they will work. Here they are:
Filedropper didnīt work so I changed the link to Boomspeed. I tested it and it should work now.
A window should pop up asking if you want to open the PDF or save it.
Engine
Bulkhead (Part 1)
Bulkhead (Part 2)
Rear Lighting
Master Plan
Good Luck!
My C10 Diary
Our cars:
Old 02-16-2009, 04:36 PM   #129
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I too can post them on my sites, the more the coverage the better!
Pm me and I'll get to it right away.
Drew
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline
Old 02-20-2009, 08:40 AM   #130
rick1956
rick1956's Avatar
I've got plenty of space on my website as well, and no ads. Give a holler if you'd like me to post it for you.
BTW, for anyone that needs a reader, there is a much better alternative than using the standard reader from Adobe. The Adobe version takes forever to load up on some people's machines.
The better alternative is Foxit Reader. It's fast, it's free, and it works great!
And no--I don't get anything for tooting their horn... ;-)
I may be old, but I still enjoy the feeling
of the earth rotating beneath my wheels...
rick1956 is offline
Old 02-25-2009, 06:12 PM   #131
72blue
72blue's Avatar
Justin, thanks for your help. Very very helpful.
James
72blue is offline
Old 02-26-2009, 03:39 AM   #132
blukangoo
blukangoo's Avatar
Like I said, here is a picture of my fusebox. << Click for a bigger picture.
My C10 Diary
Our cars:
Old 03-05-2009, 04:08 PM   #133
70gmcpickup
70gmcpickup's Avatar
need daigram for starter on 68 c10 250 6 cylinder PLEASE SOMEONE HELP ME THANKS
70gmcpickup is offline
Old 03-25-2009, 03:30 PM   #134
69time
69time's Avatar
Originally Posted by farside847 View Post
Here are some higher rez versions to view online:
Does anyone still have a copy or link to the hi/rez version of these available?
69C25
69time is offline
Old 03-25-2009, 05:04 PM   #135
blukangoo
blukangoo's Avatar
69C25
Welcome to the board.
Go check out post #117 in this thread. I think you will find the answer there.
My C10 Diary
Our cars:
Old 03-31-2009, 02:36 PM   #136
CSGAS
optomistic ah-so
CSGAS's Avatar
I need to start by thanking everyone who's put time in on setting these diagrams up...I thought I'd be able to make a contribution, but the Master diagram by itself is a work of art, and the other 4 pieces have made it easy to carry around exactly the diagram I need for the place I'm standing at--or laying on the ground under.
I have come to a sudden realization though. The truck i bought has been converted from the generator spec'd in the diagram, to a later internal regualted alternator and the back wired into itself with the single sensing wire run, in what I've come to know as the "right way" for a one-wire daily driver system...but I'm more familiar with installing those from scratch than with viewing someone else's retrofit into a factory harness...what circuit paths get cut out when the external regulator gets bypassed? Anything I need to look at patching back in, or to double check the previous owner's work? The ignition system is currently staying points for a while...HEI &/or adding an MSD box will be one of my summer projects.
My reason for finding the discrepancy came from a "crank but won't run" issue along with headlight and brake light circuits out, and low battery charge...found an hidden break (no burnmarks or heat, just apparently folded back on itself too much in the last 40ish years) in the positive lead to the junction block (and great I haven't used my soldering iron's for so long it's decided to have a similar problem!) so I'm catching a ride to the local parts store tonight for a cable. Man, I'm gonna give that smiley playing the violin a workout...somebody fill his tip jar, please!
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline
Old 04-02-2009, 12:39 AM   #137
CSGAS
optomistic ah-so
CSGAS's Avatar
UPDATE: I discovered the 67's were the last year for the generators in the diagram, my 70 was supposed to have an external regulated alternator. Still working on it.
Rubbing is Racin'
CSGAS is offline
Old 04-11-2009, 08:46 PM   #138
thedon769
great work , can you please send a copy of the diagrams it wolud be very much appreciated
email : juliusfranklin06@aol.com
thedon769 is offline
Old 04-11-2009, 08:48 PM   #139
thedon769
Old 04-12-2009, 04:57 AM   #140
blukangoo
blukangoo's Avatar
You can get them yourself.
Go up to post #128 and download them.
My C10 Diary
Our cars:
Old 04-21-2009, 01:33 PM   #141
69time
69time's Avatar
Can anyone tell me of another wire that supplies 12 volts (only when ignition is on) other than the ignition wire? Trying to connect my holley 600 autochoke wiring without stealing the power from my distributor..
69time is offline
Old 04-22-2009, 04:39 PM   #142
blukangoo
blukangoo's Avatar
I would just leave it like it is. The choke doesnīt use that much power.
The only other spot in the engine compartment is from the starter but thatīs where the coil gets itīs power too.
My C10 Diary
Our cars:
Old 04-22-2009, 04:46 PM   #143
blukangoo
blukangoo's Avatar
Tried to get a picture in but I canīt edit after 5 Minutes.
Here it is.
I have an Edelbrock and I get the power from the coil too and she runs fine.
My C10 Diary
Our cars:
Old 04-22-2009, 05:13 PM   #144
fixit-p
fixit-p's Avatar
On my 69 I got my power from the hot side of my TH400 kick down if you have a turbo 400 with electric kick down you could do the same I stayed away from the coil because the heater element is a resistive load.
fixit-p is offline
Old 06-11-2009, 09:19 AM   #145
RootBreaker
RootBreaker's Avatar
anything like this for the late 70's early 80's truck????
Chrome dont get you home and looking at my truck is definite proof!!!!
http://www.supermotors.net/users/RootBreaker
RootBreaker is offline
Old 09-08-2009, 02:39 PM   #146
Primed67
Primed67's Avatar
ok, I'm re-wiring my truck with a painful, I mean painless kit. i have figured most of the stuff out with the help of the diagrams on here. Much thanks for that but I still have a question. It shows the cluster with dummy lights installed and higher up on the page, the layout of the cluster with guages. There are 2wires i'm confused on the blk/brn ones; one says to the alternator and the other says to the terminal by the battery. I imagine i will have to run a few new wires. I have done the changeover to an internaly regulated alternator so what post does this wire need to be run to or where do I tie it in? The wire to the terminal by the battery, does it just run to the junction box? Thanks in advance and great job on the diagrams!!
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline
Old 09-21-2009, 03:39 PM   #147
ka24deroadster
On my truck and the wiring diagram there is a black wire that runs from the firewall junction block to the junction block next to the battery. There is a black/white wire that runs from the firewall junction block and splices into the red Power wire that runs from the battery to the firewall. The diagram for the cab does not have anything shown for the terminal to the black and black/white wires. What do these wires do? Where do they go to under the dash?
ka24deroadster is offline
Old 09-30-2009, 11:45 PM   #148
SAILOR-ERL
is the diagram the same for the 73 c10 as well?? im looking for it im still cant find it.
SAILOR-ERL is offline
Old 10-01-2009, 09:57 AM   #149
Twisted78SS
Wide n'Low
From another thread, CaptKaos posted these from his site
http://forum.73-87chevytrucks.com/sm...?topic=11766.0
Air Force Retired
Old 10-18-2009, 04:05 PM   #150
blukangoo
blukangoo's Avatar
Iīd say that these wires have been put in by a previous owner. The wires in Fransiscos Diagrams are Factory. I have found a few things missing in the diagram but havenīt had time to change them or let Fransisco know.
My C10 Diary
Our cars:
