01-05-2015, 12:30 AM | #876 |
Re: 100's of misc parts from the last 6 trucks parted out
great, i'll await your response. The person in this thread below has some stuff for $60 ... but if you will combine shipping and have what he has, then I'll get it from you.
http://67-72chevytrucks.com/vboard/s...0&postcount=39
69' Chevy C10 383 Stroker / TH400 275 55 r20 Wheels Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=654751 |
01-05-2015, 08:07 AM | #877 |
01-05-2015, 04:54 PM | #878 |
Any sandlewood arm rest?
01-06-2015, 01:28 PM | #879 |
Tom, I want to install a HEI in my 71 GMC, would you have one ?
71 C-20 07 Magnum RT AWD |
01-07-2015, 12:59 AM | #880 | |
"Junkyard Dog"
What year? 45.00 for the 85-86 ones. The local dist-carb gu ru guy say's the 85-86 are the best. I'll have to make sure I have one. I'll check for you.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
01-07-2015, 01:16 AM | #881 | |
"Junkyard Dog"
I only have the standard pedal.
01-07-2015, 02:05 AM | #882 |
Hello
interested in a couple clean original 69-72 steering column intermediate shafts. Thanks Mike |
01-07-2015, 02:14 AM | #883 |
"Junkyard Dog"
Mike, sure no problem. Hot tanked, acid dipped and ready for paint. I have 20 plus of them to pick from. 60.00 on a pair plus shipping. Thanks, Tom
01-07-2015, 02:35 AM | #884 | |
Also black oem defrost vents |
01-07-2015, 09:14 AM | #885 |
that pedal is fine, do you have the 'bar' that hooks up too? I have a bar and a *nub* lol
If you have all of what that guy has in the pic, then i'll take it. (http://67-72chevytrucks.com/vboard/s...0&postcount=39) if not, let me know so i can purchase it from him
01-07-2015, 08:45 PM | #886 |
01-08-2015, 12:22 AM | #887 | |
"Junkyard Dog"
[TE=ScottieB;6989104]that pedal is fine, do you have the 'bar' that hooks up too? I have a bar and a *nub* lol If you have all of what that guy has in the pic, then i'll take it. (http://67-72chevytrucks.com/vboard/s...0&postcount=39) if not, let me know so i can purchase it from him[/QUOTE] There is no bar that hooks to it. The 67-70's have a throttle arm that the pedal simply rest against. I do have that mechanism as well. I should have all the ducts that he has. Somehow in my mind I thought you wanted the duct hoses. I will verify in the morning. Ok...I'll look. Thanks, Tom
01-08-2015, 12:13 PM | #888 |
Alright sounds good. Add it to my list. Can you show me the arm?
Can you tell me the list of stuff that I am getting from u and the cost + shipping cost so far? Thanks
69' Chevy C10 383 Stroker / TH400 275 55 r20 Wheels Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=654751 Last edited by ScottieB; 01-09-2015 at 02:17 AM. |
01-08-2015, 07:15 PM | #889 |
Tom, if you have a good Height bring it to Brian's when you come ok ? Don't forget the air filter stud and wing nut also.....
01-11-2015, 01:44 PM | #890 | |||
"Junkyard Dog"
67-68 std gas pedal 7.50 Hood release cable 15.00 W/S washer bottle with pump (unsure it you want) 20.00 Did I miss anything? Will have to get shipping cost on Monday. Quote:
Still looking for the armrest. Thanks, Tom
01-12-2015, 04:16 AM | #891 | |
Washer bottle and pump Do you have the fan and plug hookup for fan? Mine is all there, but I got in my switch today and nothing turns on. idk if my fan is broken or not. Please include whatever you have for the A/C / Heater setup and tell me the balance, I just want my heater to work already I have a new aluminum heater core, i do not need yours I need wiring and connectors that go to heater components if possible, if you sold the harness, that's fine. I need the glovebox handle thing ... on the front where you 'pull' to open it... mine is broken off. 2 of those if you have them I also need the back of the lock case (shell, i guess you would call it) for my 70 Do you have the 'tool bag' that goes behind our seat on the passenger side? is that where the jack went? or just tools? Trim that goes around rear taillights x2 passenger inner arm rest (mine is cracked) - one that is in driveable condition is fine (black preferred, or olive green) do you have newer shoulder + lap seat belts and mounting hardware? green if possible, black otherwise. If you don't have the new stuff ... do you have an extra lap belt for middle passenger? Need a dome lens that's not melted i need 2 amber and 2 red side marker lenses that aren't broken in 2. rubber too if it's good 2 fender bowtie / c10 emblems v8 383 badges x4 if you got em New rubber - if you have new rubber for any part of the truck, i'll need it... unless you know of a good quality (cost effective) rubber kit for our trucks? don't need old rubber at all. I have rubber, but it's going bad Do you have a conversion kit to make a non-tilting seat into a tilting seat? I need 2 knobs that will stop coming out when I tug on them... for Headlights and for Washer. Mine twist off 1970: I need a driver outside door button for handle... not the handle itself, but the push button. the one in my 70 is jammed in there.. so whatever i need to fix that I need a driver inner door handle too, the one that you turn to get out of the truck, that one is missing. proportion valve x2 if you got em master cylinder (from any year model) and brake booster. not leaking. rod too (bundle please) power steering gear box and any mounting hardware
69' Chevy C10 383 Stroker / TH400 275 55 r20 Wheels Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=654751 Last edited by ScottieB; 01-12-2015 at 04:55 AM. |
01-14-2015, 12:47 AM | #892 |
"Junkyard Dog"
ScottieB;
1969: Washer bottle and pump...as mentioned a 85-up type. 20.00 Do you have the fan and plug hookup for fan?.....20.00 on AC fan. I have to pull the AC stuff. Let me get it out and see what all I have. I need wiring and connectors that go to heater components if possible, if you sold the harness, that's fine..... We'll see after I remove the assy. I need the glovebox handle thing ...There is no handle on the glove box door. I have the lock retainer on the back side of the button. 3.00 Do you have the 'tool bag' that goes behind our seat on the passenger side? is that where the jack went? or just tools?....... I'll check for a bag. The tool kit goes in the bag and the jack mounts to the cab floor in the RH corner. Trim that goes around rear taillights x2...no good ones right now passenger inner arm rest (mine is cracked) - one that is in driveable condition is fine (black preferred, or olive green)....Black or olive 25.00 each for nice ones do you have newer shoulder + lap seat belts and mounting hardware? green if possible, black otherwise. If you don't have the new stuff ... do you have an extra lap belt for middle passenger? No belts Need a dome lens that's not melted....I'll check i need 2 amber and 2 red side marker lenses that aren't broken in 2. rubber too if it's good...Yes on both but no gaskets. 40.00 fronts will have some fade. 2 fender bowtie / c10 emblems....69's didn't have the the bowtie. Do mean 67-68 emblems? v8 383 badges x4 if you got em....none of these. Your going to have to buy these new. New rubber - ....Brothers, The Truck Shop, Golden State and etc. could help you out on this. Also some vendors here on the site. Do you have a conversion kit to make a non-tilting seat into a tilting seat?...nothing I need 2 knobs that will stop coming out when I tug on them... for Headlights and for Washer. Mine twist off ....Yes, std or deluxe? 5.00 for each either way. 1970: I need a driver outside door button for handle... not the handle itself, but the push button. the one in my 70 is jammed in there.. so whatever i need to fix that...you will need a new or used handle assy. Your handle is bad where the retainer plate is secured. 25.00 for a handle assy. I need a driver inner door handle too, the one that you turn to get out of the truck, that one is missing....7.50 proportion valve x2 if you got em.....67-70 type 25.00 each master cylinder (from any year model) and brake booster. not leaking. rod too (bundle please)...75.00 for booster assy with brackets and rod. power steering gear box and any mounting hardware....2wd P/S gear 65.00 with mounting bolts.
01-14-2015, 01:12 AM | #893 |
Any chance you would have any of the following for my 67 step side. 1) working cigarette lighter 2) white nylon, spring and pin for a door striker 3) emergency cable guide hooks (need 2). Shipping to nashville
01-14-2015, 02:01 AM | #894 |
Hello Tom, any chance of having two round door mirrors? Look to be about 5-6 inches in radius. Thank you for your time, Ben.
01-14-2015, 02:20 AM | #895 | |
No on the 80s bottle / pump. I recently picked up a 68 c10 without A/C and i'll need some more parts
Let me take a gander through the 3 trucks I have and get a more accurate list to you Update: https://www.dropbox.com/sh/xxztpz7s2...uhyfnhDEa?dl=0 Click each truck folder --> interior cab --> vent system Tell me what i'm missing and what I need. It looks like the blue 68 has heater and new hoses, just not the A/C setup. It looks like the 70 has a complete A/C system, is it missing anything? The 69 looks like it has most of what I need, but I'm missing a couple of things because they're duct taped off and have rags in there, too. What am I missing? I need the 69 to be perfect, as it will be my 'new' main truck. The 68 and 70 I just need to make sure they have whatever stock air they have that works. I'll worry about them later. The 70 is missing an ignition ... if you have an ignition for it (with key), great. If not, I'll pick up one from LMC I see now that these trucks don't have 'pull' things for their glove boxes. I have a push button lock, but not the 'shell' for it, is what I meant when I asked. Inner arm rest - hold a black one for me, not green. As long as it's got no tears / rips / cracking. I have one there, but it's cracked bad at the edges (passenger) I'm going to hold off on the front side markers for now Fender emblems - what came stock on the 69 in the fenders just in front of the door? I have holes there for a badge The headlight / windshield washer ones ... mine are plain black, but i'd like black and chrome or black and silver if they are in OK condition. I can always paint part of it chrome, but ehhh... the stuff you listed for the red 70 is fine. What is that thing in the cab of the 70 that has vents in it on the passenger side ??? For the 70, i need a steering wheel lock nut (and washer, i guess?) The 68 ... I want a regular ebrake pedal like the 69 has ... that handle looking thing is stupid Quote:
69' Chevy C10 383 Stroker / TH400 275 55 r20 Wheels Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=654751 Last edited by ScottieB; 01-20-2015 at 12:23 AM. |
01-14-2015, 05:31 PM | #896 |
PM sent about E brake cables
01-15-2015, 12:14 PM | #897 |
tom,
do you have a green cigarette lighter(not sure if they made it but my radio is green) if not i will take black one. one window crank- passengerside one back up lens for passinger side 71 c20 one telescoping antenna do you have front bumper amber turn/parking lenses? need two let me know about these parts. i will use paypal |
01-16-2015, 10:13 AM | #898 |
tom,
i am also looking for dark olive arm rests for passinger and driver doors. cant find your ad today- not sure why. let me know how much for both. havent found your response from my first inquiry... thanks. Todd |
01-16-2015, 10:27 AM | #899 |
Tom,
I need the dark green arms rests to fit a 71- if you still have them. thanks. Todd |
01-16-2015, 12:21 PM | #900 |
Tom,
I need a metal fuel line, pump to Qjet with side entry.thanks
