Old 01-21-2015, 11:39 PM   #2726
Sac
Re: Project "What was I Thinking" 68 SWB
Little fyi also. Friend of mine had a very clean LQ4 with 220K miles and it still had crosshatches in the cylinders and it was never rebuilt. So if its been taken care of, 90K miles ain't nothing.
Green Survivor Father/Son Truck
<SeveredTies>
Sac is offline   Reply With Quote
Old 01-22-2015, 01:53 PM   #2727
GAc10boy
GAc10boy's Avatar
Yes for LS!! Very clean motor.
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 01-22-2015, 11:33 PM   #2728
Bennett68C10
Bennett68C10's Avatar
Originally Posted by raull View Post
hey bud sorry ive been away a bid, great progress but I see u set your self back a little by going with ls , cant go wrong with that, im glad I did
Great to have you back buddy, you didn't miss much just bodywork and another motor swap. Really wish I would have gone this direction when I put the big block in but I was scared to do the swap being I'm an LS noob. After driving my GMC for a little over a year it became a no brainer for me and this motor will be a lot more fun to drive and make way more power then my little 5.3 makes.
Thanks, that's what I have been reading everywhere about these motors. Glad I chose to finally go this route.
Thanks, can't wait to get it between the frame rails. I have some work I would like to do to it first so it will be a few months.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-25-2015, 07:42 PM   #2729
Bennett68C10
Got the motor stripped down yesterday, now it's ready to get cleaned up, painted and do a cam swap. Still need to purchase the cam and spring kit along with a fbody oil pan. Going to do a new oil pump and timing chain too, makes sense to do it while I'm in there.
Keith
66 Suburban
IG: bennett68c10
Old 01-25-2015, 07:45 PM   #2730
Bennett68C10
Today I got my LS6 intake cleaned up and painted. I sprayed on 3 coats of Duplicolor plastic adhesion promoter and then sprayed it with Duplicolor Semi Gloss Black engine paint. Turned out really nice.
Keith
66 Suburban
IG: bennett68c10
Old 01-25-2015, 07:53 PM   #2731
slowcpe
slowcpe's Avatar
Looking good as always. I also got springs, lifters, trunion upgrade, pushrods, timing chain, and ported oil pump. I'm going to go ahead put a new water pump and thermostat in as well.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 01-25-2015, 08:45 PM   #2732
Bennett68C10
Yeah I'm doing a new water pump and Holley accessory brackets to clear the LS6 intake. Most likely going to run a 2010 and up Camaro water pump so that the inlet matches my radiator and I can run my truck balancer. I'm going to wait on the lifters for now, I'm not going to pull the heads until I can afford to do a set of ported ones, so I'll wait and do the lifters then. I have been talking with Martin at Tick Performance about a cam for my LQ9. I'm looking at his SNS TorqueMax line of cams and he suggested I run the LS2 stage 2 cam. I want a cam that makes good torque and power without losing to much on the low end and what I have seen from these cams on the dyno it is exactly what I'm looking for. Plus I want a cam that has a nice lopey idle. Should be fun to drive now I just need to get my tax return money back so I can order everything
http://www.tickperformance.com/tick-...r-ls2-engines/
Keith
66 Suburban
IG: bennett68c10
Old 01-26-2015, 12:11 AM   #2733
Sac
Looking good man. Just picked up my LS, going to strip and clean it this week.
<SeveredTies>
Old 01-26-2015, 10:30 AM   #2734
slowcpe
slowcpe's Avatar
I've looked into Tick but went with Brian Tooley since he's somewhat local and Hubbard Racing for the ported oil pump as they are out of Indy. All good companies from what I've seen.
I wouldn't be looking into a head change if I had the LQ9. Biggest reason for 243/799s is to bump compression a bit with my LQ4.
Ryan
Old 01-26-2015, 10:55 AM   #2735
Hart_Rod
Hart_Rod's Avatar
Nice score. Welcome to the LS family....
Hart_Rod is offline   Reply With Quote
Old 01-26-2015, 06:51 PM   #2736
Bennett68C10
Thanks and congrats on your LS purchase.
That was the same plan I had when I was looking for an LQ4. What cam are you going with from Brian Tooley.
Thanks Rob, I just wish I would have done this a lot sooner. I talked myself out of doing the swap twice previously, should have just went with my initial instinct but at the time I was unsure if I could handle the swap being an LS newb.
Keith
66 Suburban
IG: bennett68c10
Old 01-26-2015, 07:14 PM   #2737
slowcpe
slowcpe's Avatar
Not sure yet. Either the Stage 3 or 4. Going to wait until I get heads and go from there. There's a slight chance I may change my mind once or twice on things between now and then.
Ryan
Old 01-27-2015, 09:30 AM   #2738
mcbassin
Still Learning
mcbassin's Avatar
Congrats on the LS! It's going to be so cool to drive with that setup
Old 01-28-2015, 12:25 AM   #2739
texasld
texasld's Avatar
To reference post #2728. My LS had 216,000 and still had the cross hatches had no lip too. I crammed it, and replaced gaskets. I'm ready to get It started. I'm getting closer.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 01-28-2015, 07:04 AM   #2740
Bennett68C10
Oh I think I know a thing or two about changing my mind
Thanks Mike, now I just have to focus on actually finishing this truck so I can drive it at some point in my life.
Awesome, it will be a long time before I get to fire this motor up.
Keith
66 Suburban
IG: bennett68c10
Old 01-28-2015, 10:18 AM   #2741
Shady Chevy
Shady Chevy's Avatar
I saw the comment about ported heads. I have quite a bit of porting experience, although it is mostly on Mopar heads. www.shadydellspeedshop.com Note: my brother Ryan is the one who runs the shop now, and builds the engines there, not me. I started the shop with my brother and worked at it in the past. But anyhow, I am thinking about putting an LS motor in my next project, and would love to port a set of LS heads to see what I could do with them. If you are interested, we might be able to work something out. Talk to me offline if you want. dkj103@psu.edu
Dave
Shady Chevy is offline   Reply With Quote
Old 01-28-2015, 10:47 AM   #2742
Justin@EntropyRad
Justin@EntropyRad's Avatar
Looks awesome! Solid cab!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 01-29-2015, 09:17 AM   #2743
Bennett68C10
Dave
I appreciate the offer but that's a little more then I want to do to the motor right now. I don't plan on pulling the heads off at this time.
Thanks Justin, I have a question for you. When I ordered my Entropy Rad, I just ordered the radiator without the fan kit. Do you guys sell just the fan kit to fit the radiator, I didnt see it listed on your site or maybe I missed it.
Keith
66 Suburban
IG: bennett68c10
Old 02-01-2015, 07:40 PM   #2744
Bennett68C10
Got the grime cleaned off the 6.0 and decided to mock up my valve covers and intake to get an idea of what it will look like. I plan to paint the block, heads and valve covers body color with the black intake and accessories. Should look pretty good.
Keith
66 Suburban
IG: bennett68c10
Old 02-01-2015, 07:40 PM   #2745
Bennett68C10
One more
Keith
66 Suburban
IG: bennett68c10
Old 02-02-2015, 01:01 AM   #2746
sduckworth13
sduckworth13's Avatar
Your engine looks great Keith. I really like the valve covers those look cool.
Scott
sduckworth13 is offline   Reply With Quote
Old 02-02-2015, 08:22 AM   #2747
mooseknuckles
mooseknuckles's Avatar
motor looks awesome!
mooseknuckles is offline   Reply With Quote
Old 02-02-2015, 09:26 AM   #2748
Sac
Looking good.
<SeveredTies>
Old 02-02-2015, 09:48 AM   #2749
texasld
texasld's Avatar
Motor looks Stellar, Bud! Going to look even cooler with some liquid color...
I'm glad I'm not the only one with those valve covers. If I'm seeing correctly, I think we have the same coil pack mounts. They are sitting on the HF hose reel box in the back ground. Have you figured out where you are going to mount them?
1999 Jeep TJ
Old 02-02-2015, 11:42 AM   #2750
slowcpe
slowcpe's Avatar
I like the valve covers. Where are planning on mounting the coil packs?
I'm currently leaning towards the Holley coil covers.
Ryan
bbc, dropmember, intro wheels, porterbuilt
