Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-03-2015, 09:47 AM   #1
ranger danger
ranger danger's Avatar
14 bolt swap questions
I have a HO52 in my sub. I want better gear options so I'm looking to swap in a 14 bolt. I have coil spring suspension. What do I look for when locating a 14 bolt? I plan on having it gone thru before installing it. I'd like a direct bolt in if possible. If not how close to direct bolt in can I get?
ranger danger is offline   Reply With Quote
Old 02-03-2015, 10:58 AM   #2
ranger danger
Re: 14 bolt swap questions
Specifics would be great. Can I use leaf spring axle. Will the e break cables direct connect etc.
Old 02-04-2015, 05:41 PM   #3
elJefe
I have the same setup and desired swap. Thank you for posing the question and I too, look forward to the advice of knowledge guys on here
elJefe is offline   Reply With Quote
Old 02-04-2015, 07:42 PM   #4
Mike C
Mike C's Avatar
There is no "bolt in" option as the 14 bolt never came in a coil spring truck. You will also get better traction on this if you move it from the "Builds" section. Probably in the main forum you will get the most action.
Buy aftermarket perches and build a jig off the HO52. Weld perches and shock mounts to the 14 bolt and then swap into truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-04-2015, 07:56 PM   #5
ranger danger
Thanks I reposted it in the drive train section.
