Old 01-18-2015, 04:51 PM   #51
rusty76
rusty76's Avatar
Re: 1965 C20 fleet side longbed DD low budget build.
Looking forward to it.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-18-2015, 11:37 PM   #52
Joe Pass
Joe Pass's Avatar
I better keep up with this thread since I might run into you in town.....
Joe Pass is offline   Reply With Quote
Old 01-20-2015, 01:56 AM   #53
mattbert56
mattbert56's Avatar
it was running and driving around for 2 years. reason i stopped driving was i shattered the clutch racing by the round table. hah. do you have a build thread of your own? i may have seen your truck once or so.
mattbert56 is offline   Reply With Quote
Old 01-20-2015, 01:57 AM   #54
mattbert56
mattbert56's Avatar
and i live in windsor. i just put santa rosa for mailing adress.
Old 01-20-2015, 09:27 AM   #55
Joe Pass
Joe Pass's Avatar
I didn't do a build thread just an album....I wish I did though
I just finished this 62 so I hadn't been out much lately other than trying to dial in the engine. I'm on Gumview rd if your in the area let me know...You can check it out...
Joe.
I might have ran into you at Thumb's Up when it was a flat bed about a year ago ?
Old 01-21-2015, 12:45 AM   #56
TJ's Chevy
TJ's Chevy's Avatar
Subscribing to this thread to keep getting the updates! Liking where this build is going cause its unique..so many people under estimate the inline 6 and do what EVERYONE else does.....throw in a 350. Nice to see yer being unique! lol But yes...I understand about budget builds. lol Mine is one, but I'm also stubborn...I'll save as long as it takes to get what I want. lol Cause if you don't restore your truck that way you want it you'll never be happy.
Old 01-21-2015, 12:47 AM   #57
mattbert56
mattbert56's Avatar
Exactly! Fewf someone gets it. Iv learned that building my truck the exact way I want it is the best way. Anyone else who doesn't like it. We'll go build your own.
Old 02-10-2015, 01:26 AM   #58
mattbert56
mattbert56's Avatar
Talking Re: 1965 C20 fleet side longbed DD low budget build.
Little up date. Picked up some 66 hubcaps. Pretty rusty but nothing a little tig and silicone bronze couldn't fix. I cheated n used a little Bondo. There on a 4x4 so I left a few dent. Gives it character. Hope yall enjoy.
Old 02-10-2015, 01:30 AM   #59
mattbert56
mattbert56's Avatar
primed and painted. going to clean up the bow tie with a detail brush.
Old 02-10-2015, 01:38 AM   #60
mattbert56
mattbert56's Avatar
Lots of updates. I'm like the scatter brain of all build threads sorry for the out of order. frames primed and painted with industrial enamel. Trans done. Transfer case in middle of repair. Rear axle just needs bearings and seals.
Old 02-10-2015, 01:46 AM   #61
mattbert56
mattbert56's Avatar
So the t case had a bad idler shaft. The helical cut gear was where the bad wear was. So I filled In the shaft splines with a hardened stainless rod and re machined it. That stainless s@#t is tough stuff. I'm putting the re machined splines in the straight cut gear. That gears seems to just Hum when driving. Looks like the helical gear took alot more abuse. So by flipping the shaft, problem solved. Took 50 years to get this way..figured I'll be 70 by the time it's that bad Again. Annnnd my buddy's say I'm crazy for fixing that. Pfffff.
Old 02-10-2015, 02:06 AM   #62
mattbert56
mattbert56's Avatar
All of these are seek peeks of what's to come. Part of my job. Is doubling as a machinist so I have access to vertical mills and such. early 60s c80 grill insert with a 62 gmc grille. Going on the 65 and just scored a 61 apache hood today.my favorite Hood on these trucks.
Old 02-10-2015, 02:09 AM   #63
mattbert56
mattbert56's Avatar
But forgot. 292 head being ported and ready for port lumps. Doing all the work myself. Running 1.94 intake. And 1.5 exhaust. Thinking of up sizing the exhaust tho. Custome side covers. Doing the 292 power in the early Chevrolet script. And front axle is 90 percent done.
Old 02-10-2015, 02:42 AM   #64
mattbert56
mattbert56's Avatar
and the grille. Well the Chevrolet portion had to be shortened about 5 inches from stock. I wanted it to look stock but with a twist. Love the gmc twin headlights. They just look mean. Either way. I'll put up the welded pics. i Ended up Using steel rod to fill. And silicone bronze on the thin edge. just gobed it on at about 20 amps. Worked great. After finish sanding just needs primer n paint. And nothing puts my mind at ease like the lake. Just me the fish and gods country hope everyone enjoys.
Old 02-10-2015, 05:36 AM   #65
Joe Pass
Joe Pass's Avatar
Nice Job, can't wait to see...
Old 02-12-2015, 03:16 PM   #66
61K10
61K10's Avatar
your doing a beautiful job!! my extra t/f case has the same problem as yours had. you can take the idler gear and rock it back and forth on the shaft. must be a common ware point.
and again very nice job.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-12-2015, 03:32 PM   #67
mattbert56
mattbert56's Avatar
Thank you very much! It is definitely encouraging to have someone say that. I'm hoping that the splines hold up on the road for a while. I know at low speeds it will be fine. But not sure about 50-55 mph Or when towing I'm planning to pull a goose neck now and again. I'm just so happy to keep the original running gear. Makes it a 1965 Truck. Not a 1965/1978/1988 ect ect hahaha but thank you.
Old 02-14-2015, 11:02 PM   #68
Jeff La
Great work, following along
Jeff La is offline   Reply With Quote
Old 02-15-2015, 06:57 PM   #69
mattbert56
mattbert56's Avatar
oh yea. Booyah. Scored this gem from a guy in town, still hands down my favorite hood on ghese trucks. ever. He had 2 for his 61 panel he's selling. I'm liking the height on this truck so far As well.
Old 02-15-2015, 11:16 PM   #70
mattbert56
mattbert56's Avatar
I think it's cleaning up Good. took her down to the local wishy wash n scrubbed her up. Started sanding down with 220. Polish and waxed. I'm going to keep it like this for a little.
Old 02-23-2015, 12:38 AM   #71
mattbert56
mattbert56's Avatar
Little update.put on the restored locking hubs. And Got the GMC grill fitted to the grill support I like the fit. Looks like the headlight housings may be a tad close to the Sheet metal. Oh well nothin I can't work with. Hopefully after I get over this darn cold I will make an attempt to get the 292 motor yanked and on a stand to start rebuilding.
Old 02-23-2015, 11:10 AM   #72
chevyrestoguy
chevyrestoguy's Avatar
I love this build! I like the fact that you're using what you have available and making it better. I really like the GMC grille with the Chevy script, too. You're putting together a truck that'll look so factory that even the experts will stop and scratch their heads.
You and I have the same mindset. It's more fun to cut and modify factory stuff than it is to open up a catalog and order a part. A lot cheaper, too. It also means more when somebody looks at your stuff and they do a double-take because they've never seen a part like that before and they think it's factory. It's fun to mess with people!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 02-26-2015, 11:49 PM   #73
mattbert56
mattbert56's Avatar
Sand blasted the backs to the grill and shot gloss black. Turned out awesome.
Old 02-26-2015, 11:53 PM   #74
Joe Pass
Joe Pass's Avatar
Good work
Old 02-26-2015, 11:55 PM   #75
mattbert56
mattbert56's Avatar
Thanks man. I'm hoping to only have to build this truck once like this. Figured do it right.
