02-23-2015, 07:15 PM | #10 |
Re: Project Screamer - '72 GMC K2500 + DD 4-53T
I was in a fooling around mood so I fitted the Jake brake switch and engine stop lever:
I also took a first pass at the gear shift lever. It was originally a bit too long and bent in the wrong direction: Here's what it looks like after a little time with a saw and rosebud: I will have to complete the fitting after I put the seat back into the cab. I started patching the holes that I cut in the firewall. I've found that it takes me a week to repair an afternoon's worth of cutting. I've tacked in the sheet metal for the driver's side. The throttle pedal will be about 1-1/4" closer to me thanks to the "shoulders" on the DD. I mocked the pedal up, it has full travel. The repair clears the engine so all is good. |
