#51 |
Re: 72 chevy modern swap
I ordered the advance adapter kit a day before christmas eve and yet the company hasn't opened back up. They sent a messaged that they would be open on the 5th so haven't did a whole lot on the pickup. Going to order the a ram 1550 flywheel, wilwood master cylinder, and a set of 309-C Doug Thorley Headers once the kit gets here.
Have to thank cmabolt for finding out what set of headers work best on his reno project.
Lance Modern 72 k20 4wd http://67-72chevytrucks.com/vboard/s....php?p=6954551 67 c20 2wd http://67-72chevytrucks.com/vboard/s...d.php?t=669589 |
#52 |
Got the fuel tank hanging in the frame. Im going to order the straps on monday. I dont feel like notching the box at all to clear the pump so going to make straps for over the top as well.
#53 |
Haven't been doing much on the truck other than wiring up the fuel tank and running fuel lines. I need some help, want to use russell connectors from my fuel line to tank and fuel rails. Anyone have some number for me? Lines are 5/16 and 3/8.
#54 |
Pulled everything off the firewall, plan on cleaning the it up. Only thing i want on the firewall is the brake booster and throttle cable.
#55 |
So I have been pretty disappointed in advance adapters. Ordered it on the 24th of December and they still haven't shipped it out. I made a purchase on summit last night and it will be here monday. Kinda mad but picked up some other things for the truck.
#56 |
Junior Member
Subscribed...whose crossmember did you end up buying?
72 K5/10/20 Hybrid 350, 465/205 44/14 bolt 35s, Detroit locker 89 XJ Pioneer, 4.5" 32s. 98 ZJ DD. Parting..87-01 Cherokees I bore throttle bodies-PM me for details! |
#57 |
I ended up buying pacific fabrication's, but there isn't a whole lot there for the money. Could've fabed my own, but didnt want to mess around with getting it lined up right.
#58 |
Never been so ticked off. The builds on hold again, emailed advanced adapters when the kit would be here that i order in december they emailed back saying they wouldnt have it out till january 23
#59 |
![]() Join Date: Nov 2007
Hey Lance, how goes the progress? Get them plumbing supplies in yet?
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! ![]() |
#60 | |
Vintage 4x4s
Do you still have the Eaton? I may be interested in the third member or maybe whole thing depending on price and if we could meet up somewhere sometime. It would be a spare for me, so not a rush thing by any means. Keep up the good work!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#61 |
Yes chris almost everything should be here by the end of the week! I ended up deciding to go braided the whole way to avoid the numerous connection like you were saying. Ill post some progress tonight!
#62 | |
Yes i do! Im sure we could work something out on the eaton.
#63 |
Cool build! subscribed
#64 |
Thanks Puller! Sorry been pretty busy but got a lot of goodies in the mail. Ill post some pictures soon
#65 |
Lance, here are the pics your requested. There are 4 shots that show the frame clearancing and proximity of header outlet to hydraulic clutch slave.
Let me know if you need anything else. This first pic is header outlet to slave distance from looking to from of truck view. This pic is above frame looking forward. This shows frame clearancing. There is a lot of frame removed here. I am probably going to modify the collector angle to remedy this. This shot is rear facing showing the slave proximity to header outlet. It looks a little closer than it is in this pic. The slave is directly in the middle. Hope this helps
#66 | |
![]() Join Date: Dec 2012
I am debating on the Pac Fab or Dirty Dingo and would like your thoughts when you get a second? Thanks Scott
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
#67 |
If you have looked at Chris' reno project he had trouble with his motor mount not lining up i had the same problem ill do a write up later. Id go with dirty dingo or build your own. I would've built my own pretty simple.
#68 |
If you don't mind me asking why did you go with the pac fab crossmember over DD?
I have a thread going regarding which crossmember to use. LA Crossmember thread
#69 |
[QUOTE=cmabolt;7075815]Lance, here are the pics your requested. There are 4 shots that show the frame clearancing and proximity of header outlet to hydraulic clutch slave.
Chris thank so much for the pictures! I would jump right on the big block hugger but im curious if the factory flange bolted to them as well?? I'm just trying to get away from cutting the frame and spending another 70.
#70 |
Well boys im back with a lot to say. I have never been so fed up with a company in my life. Advanced got my adapter to me about a month ago and i was every impressed when i seen everything. It wasn't till my transmission got back from being rebuilt that the guy told me my bellhousing was wrong... And of course it was. The bellhousing they sent me was for a 96-03 nv4500, and i thought mine was. Little did i know that the top housing of my transmission had been switched. When it was being rebuild i had the rebuilder write down any numbers. Turns out i have a 94 nv4500. So i waited a week for advanced adapters to get back to me. I sent the bellhousing there, they sent one back no problem.... I left the clutch fork attached to it figuring they would send one with the different housing well of course not. So i waited for the fork, and it finally came. without the spring in the back of it but i start to assemble everything anyways. It was all quite simple with the assembly other then i had to oval out a hole in the rear housing and modify the dust cover because it was quite modified for this project. Oh well check out the progress though.
#71 |
Here the advance adapters kit. The coupler is really impressive, and i had people tell me dont go with a 10 spline tcase. Well i have four of them and that coupler was quite tight on all of them.
#72 |
With our tcase you have to take out the old bearing and replace it with the that is installed in the first picture, just keeps the oil from escaping. Got the transmission back and it looked pretty fricken sweet if i do say so.
#73 |
I decided to go a different route with the fuel tank. And no not boyd, I dont hate on boyd but it was 840 for a 19 gallon tank with a pump that only support up to 400hp and my engine comes out this summer to get bored out and possibly a turbo not for sure on anything but i needed something better and cheaper. I also wanted it to be an intank fuel pump. More to come....
#74 |
Threw the tcase up to the trans just to see how it looked and it looks pretty cool. Shifter arm needs to be shaved down a bit but other then that it looked good.
Well you guys get commenting and asking question. ill post more tomorrow.
#75 |
Hey lance I got the same gas tank with an walbro in pump tank I got it ready to go once I get the bed off the truck.
Looking good on the t case.
