03-14-2015, 03:47 PM | #1176 |
Re: Restoring Rusty
ok so feet shoulders width apart, relax your grip, make sure you don't get tangled in the air hose (joking) and here we go with Coat Numero Uno... for those of you joining us from Latin America
FYI: depending on the surface area, weather conditions, gravitational pull, etc... you may find that one coat = one can of material, which is what this is turning out to be see you in 30 minutes... |
03-14-2015, 03:50 PM | #1177 |
Re: Restoring Rusty
03-14-2015, 03:56 PM | #1178 |
Re: Restoring Rusty
As Cordless's goes I would not use anything but Makita. I had one that I used at work dropped it off hoists, cars, into drain pans totally soaking it in ATF etc. and it never gave up. The only reason I retired it was batteries were dying and replacements were hard to find and expensive.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
03-14-2015, 04:13 PM | #1179 |
Re: Restoring Rusty - Painting the Fender
OK, second verse, same as the first, but a whole lot greener, and a whole lot worse, hee hee
03-14-2015, 04:16 PM | #1180 |
and then it was on to the third coat of the regular mixed paint (the last coat will be the semi flat finish)
03-14-2015, 04:19 PM | #1181 | |
Re: Restoring Rusty
Rich Weyand 1978 K10 RCSB DD. |
03-14-2015, 04:34 PM | #1182 | |
Re: Restoring Rusty
I have a bunch of Milwaukee stuff too that I really like.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
03-14-2015, 05:00 PM | #1183 |
Re: Restoring Rusty
Nice work Ski! Taking a break today, enjoying some skis... brewskis.
03-14-2015, 06:30 PM | #1184 |
Re: Restoring Rusty
03-14-2015, 06:33 PM | #1185 |
Re: Restoring Rusty
fourth coat overall and first semi flat coat (front only)
03-14-2015, 06:35 PM | #1186 |
Re: Restoring Rusty
fifth and final coat, this is the second semi flat finish coat to get the shine toned down a bit
I hope its flattening it out, took the pic while still wet so it should get even flatter |
03-14-2015, 06:43 PM | #1187 |
Re: Restoring Rusty
welcome back to the College of Truck Knowledge aka CTK
heard a bit of a valve lifter / rocker arm / valve chatter so decided to take a deeper dive ol' school style - always wanted to see the oiling action of the push rods in real time, so it was time to fabricate some custom cardboard splash shields, ... [10 seconds later] done at first (using a long breaker bar against my ear) I thought it was one of the 8th cylinder valves but then I couldn't tell where it was coming from so decided to play doctor |
03-14-2015, 06:45 PM | #1188 |
Re: Restoring Rusty - Removing the Hood
next thing you know I got the hood off
so much nicer working on the truck with the hood off, you have light, you have access, if I ever invent anything it will be a break away hood, LOL the wood is there to server as a windshield bumper in case my son and I decided to slide the hood through the windshield, but it went well NOTE TO SELF: Hood removal not a one man job! |
03-14-2015, 06:47 PM | #1189 |
Re: Restoring Rusty
***edited sent pm***
03-14-2015, 06:48 PM | #1190 |
Re: Restoring Rusty
Nice to see that my hood isn't the only one with "patina".
Fred 1974 C-20 Fleetside White/Crimson Red 292/SM465 4.10:1 open 1976 AMC/Jeep CJ-5 Lime Green 258/T150 3.54:1 open 1972 C10 Suburban - SOLD White/Medium Spruce Metallic/White Avocado Highlander Pkg 402/TH400 3.08:1 open |
03-14-2015, 06:48 PM | #1191 |
Re: Restoring Rusty
well shoot since we got the hood off might as well give it the good ol' rust treatment
03-14-2015, 07:02 PM | #1192 |
Re: Restoring Rusty - Rusty Hood
ok, so here is the hood after the first rust treatment, looks like a missed a few spots, oh well that's expected on the first pass, this took about an hour, not bad at all
I think two more washes and we'll be able to eat off of it |
03-14-2015, 07:28 PM | #1193 |
Re: Restoring Rusty
Wow ,that looks amazing ,what did you use and how much was it diluted ?
03-14-2015, 07:31 PM | #1194 |
Re: Restoring Rusty
That's pretty amazing with the hood. Did you use CLR? It looks dang good.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
03-14-2015, 07:35 PM | #1195 |
Re: Restoring Rusty
I'm betting on mineral spirits
03-14-2015, 07:59 PM | #1196 |
Re: Restoring Rusty
Entertainment and motivation...
Thanks. |
03-14-2015, 08:07 PM | #1197 |
Re: Restoring Rusty
03-14-2015, 08:09 PM | #1198 |
Re: Restoring Rusty
03-14-2015, 08:12 PM | #1199 |
Re: Restoring Rusty
03-14-2015, 08:14 PM | #1200 |
Re: Restoring Rusty
Greg, the new fender looks great for a driver. The hood cleanup is amazing. Are you going to do some paint on it as well?
And I'd agree that the hood is a two man job.
