Old 04-28-2015, 03:18 AM   #1
mjgord51
Help with Axle Swapping
I have a 68 C10 w/ stock 12 bolt 6 lug rear end. I have read in another Forum that when using the frt spindles (5 lug) let say from a 1996 Tahoe 5 bolt lug truck that it would be the right move to also get the rear axles being it is also a 12 bolt rear end to end up with a complete 5 lug conversion setup onto my 68 C10.
PS, I have the spindles & calipers from that Tahoe on my truck w/ after market 6 lug x 1 1/4" rotors already and other than the 22" rims & tires it seams to do OK with what little I have drove it. *** ? will that axle swap work or not. Thanks in advance, mjgord51
mjgord51 is offline   Reply With Quote
Old 04-28-2015, 06:30 AM   #2
PGSigns
PGSigns's Avatar
Re: Help with Axle Swapping
You sure it is a 96 Tahoe? I did not think they would even bolt up and the 12 bolt went away in the mid 80's.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-28-2015, 10:47 AM   #3
mjgord51
Here is the casting #'s for whats on my truck now 15649947 L & 15649948 R. While on other Forums reading other peoples ?'s the answers given back were identified as " His " sons Tahoe had the #'s used on his truck. Same post also said too get the rear Axles to make a 5 lug swap as long as it was a 12 bolt as is like mine is also a 12 bolt. An other post said the spindles were from a 92 - 02 Chevy or GMC truck. I am having no luck with the disc's hoses matching, they might be just some thing that just worked for the install. Maybe I need to go to the Dealer and have them run the #'s. I like going on these Forums and asking ?'s and getting more then one persons opinion. Looking up who & what back grounds they have well that's a judgment call you have to make your self. Thanks, mjgord51
Old 04-28-2015, 03:07 PM   #4
SCOTI
SCOTI's Avatar
A stock 12bolt truck 68 rear housing & axles are narrower than 73-87 housings by 1.5" & 3" vs the 88 & later rear ends.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-29-2015, 01:41 AM   #5
mjgord51
Well its back to the drawing board, maybe this Junk Yard miss matching of newer stock parts to older fitment is for the birds! I guess a rear end 5 lug Axle conversion sounds more easy to do than what I was told ( not this forum) that would work. Thanks for making up my mind for me LOL, mjgord51
Old 04-29-2015, 02:18 AM   #6
andrewmp6
You can buy 5 lug axles for 319 bucks from http://www.earlyclassic.com/catalog.aspx then just swap the drums over to 5 lug and the rear is done.On the front most use 73-87 spindles and brakes.
Old 04-29-2015, 02:46 AM   #7
SCOTI
SCOTI's Avatar
x2. Swapping in new, stronger.axles is the way to go.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
