Old 05-08-2015, 05:39 PM   #1
Guy Dudebro
How do you know if your governor is bad?
I'm having shifting issues on my TH 400. It won't come out of 1rst gear. The RPM will go up and never shift, especially when going up hill, and there's a pop that comes from the exhaust.
I pulled the governor out and it seems to be fine. The nylon grooves look intact. Is that the only symptom of a worn governor?
I'm also replacing the vacuum modulator and changing the fluid and gasket while I'm at it. Anything else I should look at?
Guy Dudebro is offline   Reply With Quote
Old 05-08-2015, 05:42 PM   #2
Jonlopes
Re: How do you know if your governor is bad?
The last time this happened to me it was the vacuum modulator. One other symptom I had was it was sucking tranny fluid through the bad modulator , through the vacuum line, and into the engine creating lots of smoke.
If it is the modulator you should still be able to manually shift from L2 to L1 to D.
Jonlopes is offline   Reply With Quote
Old 05-08-2015, 06:15 PM   #3
First c10
First c10's Avatar
His last name is BROWN!!!!
Sorry I could not resist!! Cali guys will get it!!!
check the modulator like Jonlopes said!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-08-2015, 06:19 PM   #4
68bowtie
68bowtie's Avatar
we have a good running streak...
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 05-08-2015, 06:24 PM   #5
hugger6933
i thought you recalled that guy then he is running things again? The 400 ought to powershift as it used to be called that is when it holds first and then hop to second after the rpms get so high. or maybe I just dreamed that. Jim
hugger6933 is offline   Reply With Quote
Old 05-08-2015, 06:29 PM   #6
First c10
First c10's Avatar
That was another color Gray Davis was recalled. I just remember years ago where my vacuum line came off my modulator and it would not shift out of first gear
GO GO!!!
Old 05-08-2015, 06:48 PM   #7
rcrahn
rcrahn's Avatar
Paging Moonbeam....earth to Moonbeam....how's your bullet train to Coalinga coming along....Phase 1 projected costs - $68 BILLION making it the most expensive public works project in US history...
Let me apologize now for the outburst....just explaining why I'll be leaving CA
rcrahn is offline   Reply With Quote
Old 05-08-2015, 07:02 PM   #8
First c10
First c10's Avatar
That's funny. The bullet train to Coalinga. Smh
GO GO!!!
Old 05-08-2015, 08:55 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Check the vacuum modulator, same thing happened with mine a while back. The vacuum line was cracked.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 05-09-2015, 12:31 AM   #10
El Dorado Jim
XVIII. Posts regarding politics or religion are strongly discouraged. These posts tend to create pissing matches and will be closed.
El Dorado Jim is offline   Reply With Quote
Old 05-09-2015, 01:16 AM   #11
leddzepp
Moderator
leddzepp's Avatar
Please keep politics out of this, I do not want to close a thread in which the OP needs real help in fixing a problem with his truck. Thank you.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 05-09-2015, 01:29 AM   #12
First c10
First c10's Avatar
Sorry I was just cracking a joke. My apologizes to guy dudebro and the rest.
GO GO!!!
Old 05-09-2015, 02:37 AM   #13
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Your tranny is all over the map. Had that happen on a 78 Caprice. Amco said I needed a new tranny. The local replaced the governor for 60 bucks. But that was about 1980.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
