Old 03-12-2015, 10:07 AM   #26
marvgarr68
marvgarr68's Avatar
Re: 77 gmc c35 dually 4-53t detroit
Originally Posted by burnin oil View Post
I love that aux box. They always are down low. When you moved it up it didn't mess the driveline angle up to much did it? Not a lot of guys even know what they are anymore. I have a 6x4 in my Dodge 5500. People always look at it weird with the 2 levers sticking up. Anymore most people get lost seeing 3 pedals.
The driveline angles were bad when it was hanging low. Now all the angles are great. Most people think "o is that for your two speed rear end". When you tell them it's another transmission there minds are blown. I like it when I get asked what is in it and I say just a little 4cyl.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 03-12-2015, 12:52 PM   #27
burnin oil
I always get asked about the exhaust brake switch on the shifter. This thing have a 2 spd rear?
burnin oil is offline   Reply With Quote
Old 03-12-2015, 06:19 PM   #28
meatwagon83
meatwagon83's Avatar
i have toyed with the idea of putting a 4-53t in mine, but they are a pain to find and expensive when you do find them
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 05-18-2015, 01:49 AM   #29
jbclassix
Junk Yartist
jbclassix's Avatar
How's the 2-stroke running?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 05-18-2015, 10:09 PM   #30
marvgarr68
marvgarr68's Avatar
I drive it everyday. I have 9 vehicles and I only drive this one. I just filled up today haven't got fuel for over a week held a whole 23.00 dollars. I need to get a video but with two sticks its a little hard to hold a camera. I put in some 9a90 injectors it had 5a60 injectors in it. It is a lot more fun to drive it plain hauls butt gets better mpg and a lot less throttle is needed to get moving or stay moving. If you don't watch the go pedal and get a little to far in it no one behind you can see where they are going.
Old 06-07-2015, 10:34 PM   #31
chrapladm
Any chance for a Gopro camera mount for the video?
chrapladm is offline   Reply With Quote
Old 06-12-2015, 12:46 AM   #32
marvgarr68
marvgarr68's Avatar
I do need to do a video I will try.
Old 06-18-2015, 02:58 PM   #33
burnin oil
Just thought I would share this. I was driving the 5500 up the interstate the other day and I had an 18 wheeler pull up next to me. He hung right there for a couple of miles and motioned me to open the window. The guy wanted to know if the truck was really a twin stick. When I motioned to him that it was it made his day. Its pretty cool running past a trucker that remembers the earlier days.
Old 06-24-2015, 11:36 PM   #34
marvgarr68
marvgarr68's Avatar
I get some of those who cant believe it is really a two stick.
Old 06-25-2015, 09:31 AM   #35
nsulacountry
Subscribed!
I'm torn between a 6.0L/TH400 or a DD 4-53T/Allison for my 79 C20. I like the fact that it fit in a 2WD square.
Keep the pictures flowing!
CT
nsulacountry is offline   Reply With Quote
Old 07-06-2015, 10:44 AM   #36
OutlawDrifter
this thread needs pictures and a video!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 07-11-2015, 08:24 PM   #37
marvgarr68
marvgarr68's Avatar
Here are some videos for you guys.
https://youtu.be/1tQiLkBmIkI
https://youtu.be/eFQVZICNvI4
https://youtu.be/98lhgfgyqEE I scratched a couple of gears and it slipped out of direct climbing the mountain.
https://youtu.be/PT1Er8T0sD0
Old 07-12-2015, 03:07 PM   #38
jbclassix
Junk Yartist
jbclassix's Avatar
So freakin sweet
-Jeremy
Rebuilding an NP205
Old 07-13-2015, 11:02 AM   #39
OutlawDrifter
thanks for the ride!
1991 Z/28, 6.0L/T56
Old 07-16-2015, 05:51 PM   #40
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice! It's definitely gettign enough fuel!
Ryan
1969 Chevy milk truck
Old 07-17-2015, 08:55 AM   #41
gerfunken
gerfunken's Avatar
ya, I'm not sure that I'd want to spend too much time in city traffic with that thing.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 07-18-2015, 12:54 AM   #42
marvgarr68
marvgarr68's Avatar
It's very controllable that video was floored. I hardly never drive it like that. With in town driving it just slightly hazes. I do need more turbo down lower in rpm I'm contemplating compound turbos.
Old 11-26-2015, 11:26 PM   #43
marvgarr68
marvgarr68's Avatar
Well she decide to drop all her oil on the ground. One of the oil filter lines broke at the fitting and poured oil out. I also found the oil cooler and adapter plate leaking so I pulled everything off the side of the block for reseal. I tell you its not easy working on in the truck but once you pull out the inner fenders and everything else its not bad.
Old 11-30-2015, 02:35 PM   #44
marvgarr68
marvgarr68's Avatar
Some pics I have to remove the oil cooler adapter again due to a seep some where.
