Old 06-21-2015, 03:45 PM   #1
Red-Hawk
Rear frame damage. Can I hammer out?
Soooo. After removing bumper and body mounts it appears that she's been tagged in the rear. Looks like PO tacked some weld stock to compensate for the damage.
Problem is rear body mounts are bent too.
It looks like it's fairly minor and the rest of the frame is solid and straight.
I'm not a metal or frame expert. Can i just hammer out bends? Or am i making it worse?
Notice the kids pool tube....You never know when that will come in handy during the build.
Red-Hawk is offline   Reply With Quote
Old 06-21-2015, 11:26 PM   #2
GMC-YA68
GMC-YA68's Avatar
Re: Rear frame damage. Can I hammer out?
You mean notice "YOUR" pool tube!
Does it look ok on the other end of the x-member??
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 06-22-2015, 10:00 AM   #3
turp mcspray
turp mcspray's Avatar
You will most likely need a little heat, but it shouldn't be much of a problem to fix.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 06-22-2015, 10:29 AM   #4
Red-Hawk
Ha! Yeah my 220 lbs would put that underwater faster than the when Jaws took those barrels under. "He can't go under with 3 barrels on him!"
......but I digress.
Stupid question alert...Where -is the x memeber?
Old 06-22-2015, 10:31 AM   #5
Red-Hawk
Will propane handheld do the trick with BFH or full acetylene/oxygen torch. I only have a propane.
Old 06-22-2015, 11:30 AM   #6
jaros44sr
jaros44sr's Avatar
Be careful, a lot of fuel lines in the area, could you get a porta- power in there
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-22-2015, 11:35 AM   #7
Red-Hawk
Yeah, thanks. I already removed gas tank. Should I remove fuel lines too? tanks been removed for several months now.
Old 06-22-2015, 11:49 AM   #8
jaros44sr
jaros44sr's Avatar
That's a tough call, because you won t be able to remove them without damage, I don t think. If it was me, I would err on the side of caution and get rid of any fumes. At least get rid of the lines up to the rubber hose under the passenger seat, and do the work outside
Don t forget the vent canister mounted in the bed topside
Good luck!
SAFETY FIRST
AS usual, off topic
Jim
Old 06-22-2015, 12:24 PM   #9
Red-Hawk
Never used a porta power? How would it be used to straighten frame tails in my situation? Their both crunched in from rear end collision.
Or are you recommending heating and then somehow using pump to straighten? Sorry for the newbie questions.
Old 06-22-2015, 12:35 PM   #10
Red-Hawk
[QUOTE=jaros44sr;7217678]That's a tough call, because you won t be able to remove them without damage, I don t think. If it was me, I would err on the side of caution and get rid of any fumes. At least get rid of the lines up to the rubber hose under the passenger seat, and do the work outside
Good luck![/QUOTE/
Okay thanks, I'll do that. The vent canister in the DRside qtrpanel was removed too for repair. Thanks for the safety tip!
Old 06-22-2015, 02:32 PM   #11
turp mcspray
I see a fair amount of stretched metal there. You're going to need a regular torch. I don't think doing it cold, will net you much success.
Turp Mcspray
Old 06-22-2015, 04:09 PM   #12
jaros44sr
jaros44sr's Avatar
You would have to be creative, build a immovable wall, the bottom of the frame would be easy, since you could use the floor to push up on. But as Turp says ( he's the pro) use a torch first and see what results you get. Last resort, buy a frame section, and have that welded on. There s one for sale, on the parts board. Keep us posted on your progress
SAFETY FIRST
AS usual, off topic
Jim
