Old 07-19-2015, 10:56 AM   #1
RB72
Parking Brake Light Stays On
Does anyone know why my brake light on my dash stays on even after I release it?
RB72 is offline   Reply With Quote
Old 07-19-2015, 11:18 AM   #2
geezer#99
geezer#99's Avatar
Re: Parking Brake Light Stays On
Maybe that brake light isn't for your park brake!!
It's for your prop valve! Tells you you have a failure in your master cylinder.
Old 07-19-2015, 11:36 AM   #3
franken
Pull up on the parking brake pedal and see if it goes out.
It could also be an indication of brake problems.
Old 07-19-2015, 12:59 PM   #4
leftybass209
leftybass209's Avatar
These trucks were not equipped with a parking brake indicator. The light you are seeing, as geezer said, is to indicate a fault in the hydraulic aspect of your braking system. Sometimes it comes on due to an incorrectly bled system, or it could be reading that you have a leak and have lost pressure somewhere.
On a side note, there is a diy thread on the forum on how to make the brake light function with the e brake. It's a really cheap and easy mod.
leftybass209 is offline   Reply With Quote
Old 07-19-2015, 01:16 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
As the others have said that light has nothing to do with your parking brake. Take the cover off of the master cylinder and I will bet that one of the fluid chambers will be dry. That means you have a leak in either the front or rear brake lines or wheel cylinders.....
LockDoc
Leon
Old 07-21-2015, 09:51 PM   #6
RB72
LockDoc
You were right my chamber closest to the cab was dry!
Old 07-21-2015, 11:08 PM   #7
LockDoc
LockDoc's Avatar
If you don't see any fluid leaking from any of the rear lines you will have to pull the rear drums off to see which wheel cylinder is leaking and replace it.... Wait! Is this a C-10 or C-20???
LocDoc
Leon
Old 07-26-2015, 10:55 AM   #8
RB72
LocDoc
It is a K10!
Old 07-26-2015, 12:17 PM   #9
LockDoc
LockDoc's Avatar
It is a K10!
OK, I'm not sure which chamber is the front and which chamber is the rear on those. Some of them are the opposite of what you think they would be. I'm still thinking the front one is for the front brakes and the rear is for the rear brakes on the 10's.....
Let us know what you find out on it.
LockDoc
Leon
Old 07-26-2015, 05:09 PM   #10
tommys72
tommys72's Avatar
My light is one too, rear reservoir is almost empty. Investigated a little more, both rear wheel cylinders are leaky! Not so good...thanks guys
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
