Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Old 09-22-2015, 07:29 PM   #1
c10ironhead
turbo 350 problems
Hello, new to the site. I own a 72 c10 shortbed. It has a 350, turbo 350, 9" rearend w/ 350 gears. I had transmission rebuilt about 6 months ago. Everything has been good. I drive 100 miles a day, back and forth to work every day. The other day I was leaving McDonald's and as the truck was gaining speed it was like it hit the brakes. I tried to take off again slowly and it did it again.I shifted to 2nd gear and it still felt like it down shifted hard. I put it in 1st gear and drove it the rest of the way home.
I climbed under the truck the next day and noticed Trans fluid around modulator. The hose was real soft and fluid was in modulator so I replaced it. Tried to drive truck in parking area, and it did it again so I parked it.
My questions are, could it be the governor? Or is it something internal?
Any imputed will be appreciated.
c10ironhead is offline   Reply With Quote
Old 10-02-2015, 11:42 AM   #2
cheyennesr
cheyennesr's Avatar
Re: turbo 350 problems
i guess it would be internal cross leak causing two gear to apply at one time . i would remove and have a trans guy tear down and check
cheyennesr is offline   Reply With Quote
