Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-20-2015, 11:28 PM   #1
Glenns66
Need help.
1 have a 1966 suburban factory 4x4 with no engine. It has factory ac and Clam doors.
I want to put in period correct engine. Doed anyone know what to look for?
~My guess would be a 327
does anyone know the proper casting numbers?
Any feedback would be great.
My Vin starts K1466
Glenns66 is offline   Reply With Quote
Old 10-20-2015, 11:53 PM   #2
Subdude59
Active Member
My Vin starts K1466
Subdude59 is offline   Reply With Quote
Old 10-21-2015, 12:10 AM   #3
Subdude59
Active Member
Re: Need help.
Hey Glenns66. I'm no expert, but I have a 66 4x4 Burb also. Mine currently has a 292 but I found a 66 327 I'm gonna upgrade to once I have it rebuilt. There are a couple sites. Outintheshop.com is a start. Depending on how original you want your build to be, some casting numbers were for cars and some for trucks. They were also specific to either automatic or manual tranny version pairings with engines. Post some pics of your truck. AC was a rare option. In dash or under dash version?
Old 10-21-2015, 12:16 AM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Need help.
if I remember right , 327 was only available in the camper special 3/4 ton in 66, basically all 60-66 light duty trucks with a v8 were a 283. maybe some were special ordered with a 327 , but if that could be done , those trucks are pretty few and far between.
your best period correct engine will be the 283, 292 was available, but I wouldn't even want to try to source the air conditioning equipment for that, the sbc stuff will be hard enough.
Old 10-21-2015, 12:21 AM   #5
Glenns66
Re: Need help.
Thanks guys for the info. I will keep hunting. The ac is factory in dash.
Old 10-21-2015, 12:28 AM   #6
jonzcustomshop
1961 crewcab
Re: Need help.
trying to find where I read about the camper special only part, and I see that (member)60-66 has a 327 in his low mile sub.... so not sure... check out this thread:http://67-72chevytrucks.com/vboard/s...870&highlight=
I still think the 283 would be the more common easier build, but maybe a 327 would work if you can find one....
Old 10-21-2015, 07:43 AM   #7
cg285
Re: Need help.
fwiw i have seen period correct 6 cyl a/c compressor brackets available for the a6 compressor.
cg285 is offline   Reply With Quote
Old 10-21-2015, 08:50 AM   #8
Glenns66
Re: Need help.
Thanks. I will be hunting for this stuff over the winter.
Old 10-21-2015, 09:46 AM   #9
pimpston65
pimpston65's Avatar
Re: Need help.
i have a 66 burban, i put a 292 in and also have the correct ac brackets. that being said, don't wait to look for parts. do it asap cuz parts are hard to come by at will cost you...
pimpston65 is offline   Reply With Quote
Old 10-21-2015, 11:21 AM   #10
Glenns66
Re: Need help.
So the things I need will be the following :
292
Any special casting # for a suburban 66 with ac?
Head correct #?
Any other components to look for?
Thanks ahead of time for everyone's feedback
Old 10-21-2015, 11:34 AM   #11
Glenns66
Re: Need help.
Also guys my VIN is a little confusing. It starts with K1466....
Any ideas what that means?
Old 10-21-2015, 02:11 PM   #12
padresag
Re: Need help.
I have a complete running 283 from a 65 suburban 4 x 4
ron
padresag is offline   Reply With Quote
Old 10-21-2015, 02:18 PM   #13
Glenns66
Re: Need help.
I'm trying to put in the right motor for the year. Which is a 66 4x4 with factory ac. What would you need for the 65 if I change my mind?
Old 10-21-2015, 06:33 PM   #14
Clyde65
Clyde65's Avatar
Re: Need help.
1966 was the first year with the 327 as a factory option from my research.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-21-2015, 08:35 PM   #15
pimpston65
pimpston65's Avatar
Re: Need help.
whats the vin? you can find if it came with an 6 or 8 that way as well as the motor mounts, if they are offset its a 292.
Old 10-21-2015, 08:46 PM   #16
Glenns66
Re: Need help.
I'm confused by my VIN.
K1466F..... I can't find any that makes sense.
Let's talk vaule/ resale
If you own this factory 66 4x4 with ac what would you do?
I've herd everthing from create, 350, period matching, BB.
Old 10-21-2015, 10:55 PM   #17
sodly
sodly's Avatar
Re: Need help.
327s weren't part of the Custom Camper package. They were available in C10s and C20s beginning in late '65 and for '66. No 327 4x4s, though, at least not in this generation. Additionally, the TH400 automatic transmission was only available in C20s.
I don't think I've ever seen an nice original-paint 327 in a half ton truck. Has anyone else?
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 10-21-2015, 11:02 PM   #18
Glenns66
Re: Need help.
Sodly, if you owned a a 66 4x4 with factory ac. But only have the frame and chassis what would you put under the hood?
292? I love to get you feedback.
