11-19-2015, 09:53 AM | #426 | |
Re: My 52 GMC Build
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
11-19-2015, 08:42 PM | #427 |
6>8 Plugless........
Re: My 52 GMC Build
As far as I've ever seen, those IDI's only had belt driven air compressors. I've never seen one driven off the gear train. Finding a bolt on one may be a real feat now a days. But making the brackets wouldn't be too bad for you to do. A comp off an early DT360, 466, or 408 would work too. Then modify brackets etc accordingly.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-20-2015, 08:18 AM | #428 | |
Re: My 52 GMC Build
I got my batteries hooked up and got air working again. My air tanks don't leek at all and I have one small leek on the drivers front. It's on the back of the gauge. I looked this morning, so 12hr drivers front 20 psi down. I'll get that fixed.
11-20-2015, 09:39 AM | #429 |
Re: My 52 GMC Build
Put my bed on last night well whats left of a bed, more like a tonneau cover. I'm going to use ply wood for now. Then I screwed on some old signs I have. Looks neat, I also have an old home made galvanized cooler that was given to me it will go near the front between the signs. In the last pic you can also see the red main power dual batt disconnect sw. It's for a boat.
11-20-2015, 03:37 PM | #430 |
Re: My 52 GMC Build
Nice!
Not much of a bed left, but I like what you do to it, with the signs!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
11-20-2015, 07:05 PM | #431 |
Re: My 52 GMC Build
Howdy! I just wanted to let you know that while I saw waiting for my forum account to get activated, I noticed your thread and read the whole thing from the beginning to current day.
I really like what you did with your truck, and have enjoyed watching the videos, seeing the pictures, and hearing about the work you have done! I'm subscribing so I can keep up with any updates you make. Question: You said you were planning for a long time. Did you draw out all this stuff on paper, use any computer programs to work out what you wanted, etc? What was your process for the planning phase? I'm an engineer, and always like to hear about the design phase that people go through, because I know how much work goes into that part that nobody actually sees except in the execution of the final product. |
11-20-2015, 09:36 PM | #432 |
Re: My 52 GMC Build
Lower, that is a great looking bed floor / tonneau cover!
11-21-2015, 08:38 AM | #433 |
Re: My 52 GMC Build
Sweet lowers!!
SHAKE N BAKE BABY, SHAKE N BAKE.... http://67-72chevytrucks.com/vboard/s...d.php?t=686729 |
11-21-2015, 03:17 PM | #434 |
Re: My 52 GMC Build
Impressive... Just read this from start to now. I have similar ideas for my build with the bed floor being hinged, back halving the rear and air ride suspension. One day it will will be a diesel but now the plans are for a gas motor.
How do you like the accu air vu4 i am looking at that same controller/valving? When you built your controller box did you order a wire harness from them and it appears that you cut and spliced theirs to meet up to yours. Great build and highly inspired to get mine half way done. Biggest issue is $$$ |
11-24-2015, 01:08 AM | #435 | ||||
Re: My 52 GMC Build
Thanks Quote:
11-24-2015, 01:29 AM | #436 |
Re: My 52 GMC Build
Friday eve my friend Joe brought his works mobile alignment van over so we could get that done. The alignment heads will not fit on when the fenders are on.
After 4 hrs and beers we had the rear end and front end all in the green at my normal ride height of 3.5". Track, caster, camber, toe. We also looked to see what changes at 1" and 6". I had to put the duals on for alignment. This is what we started with. Sorry no after shot computer shut down when we tried to print.
11-24-2015, 09:59 AM | #437 |
Re: My 52 GMC Build
Lowers, what are the dimensions or your rad and innercooler? Do you think there is enough cooling there should you work the truck? I ask cuz I will use my truck for some towing here and there or road trips in mountains and what not. I know I can put in smaller rad and cooler just for easy cruising but am stumped how I can fit OE stuff in my Coe front end. I'm sure that engine will be similar in its cooling needs as mine. I can't move the engine back anymore to put innercooler there or vise versa. This doggone rad and cooler issue is eating me up mentally. Once I get this outta my hair it'll be smooth sailing.
I went all manual on my bag setup. Kinda wishin I went e-level. Saved a ton of coin though, to sacrifice the cool factor.
11-24-2015, 10:39 AM | #438 |
Re: My 52 GMC Build
Getting closer..
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
11-24-2015, 11:06 AM | #439 |
Re: My 52 GMC Build
that's a cool setup. I had to find a specific place to align mine too.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
11-25-2015, 12:20 AM | #440 | |
Re: My 52 GMC Build
http://derale.com/products/fluid-coo...0897141-detail I have a smaller 3 core in my Jeep that works really hard on the highway and its fine. Time will tell. Ya you can always go E-level later.
11-25-2015, 12:32 AM | #441 |
Re: My 52 GMC Build
Today I picked up some dually chrome hub covers from a friend. Not sure if I'm going to put them on but there hard to come by and FREE.
I also got the Hydro boost installed made up an adjustable peddle link using 1/2" threaded rod.
11-29-2015, 04:38 PM | #442 |
Re: My 52 GMC Build
dam that looks great
11-30-2015, 07:02 PM | #443 |
Re: My 52 GMC Build
Saturday Joe finished up a sweet job on the inner fenders and rad support. Several coats of primer and gloss black paint. Should make under the hood really pop.
Today I made some stainless brackets to hold my Wilwood proportioning valve and line lock. Then got my first line attached.
12-01-2015, 12:30 PM | #444 |
Re: My 52 GMC Build
Looks good!
12-01-2015, 01:26 PM | #445 |
Re: My 52 GMC Build
nice work on the adjustable pedal rod! hydroboost is great, never bleed your brakes ever again!
12-02-2015, 06:31 PM | #446 |
Re: My 52 GMC Build
Thanks I made the same type of rod for my Jeep years ago just no hydroboost.
12-02-2015, 06:36 PM | #447 |
Re: My 52 GMC Build
Got the axle hard lines made up today. They are not fastened down yet because on my way to work I picked up all my fittings and stainless flex lines. I hope to have it all together tomorrow.
12-03-2015, 08:49 PM | #448 |
Re: My 52 GMC Build
Brake lines are 99% done. I have to find the right fitting to go from the master to the line lock. I used stainless braided at the wheels and from the frame up to the master.
Also got the rear all put together.
12-03-2015, 10:00 PM | #449 |
Re: My 52 GMC Build
Very nice! It's getting real close now!
12-04-2015, 09:40 AM | #450 |
Re: My 52 GMC Build
Looks great, that is the same valve I'm gonna use for bias. Can't wait for some vid of your first burnout!!
Tags |
bagged, build, diesel, gmc, hot rod |
