Old 01-16-2016, 05:40 PM   #1
daddyjeep
daddyjeep's Avatar
Daddyjeep Hauler - 85 K30 crew cab short bed
So I finally drug the truck into the shop so I can get started on this project. I picked up this truck about a month ago and it is in need of a little love. It hasn't been registered since 2003 so I'm going to have to go through everything. I'm going to cut it down to a short bed and eventually drop in a 6.0. For now I have to focus on the short bed conversion and replacing the rockers and front floors. I go to the Bantam Jeep Heritage Festival every year with my YJ so I need the truck functioning by June to use it to drag the Jeep there. Lots to do.
[IMG][/IMG]
[IMG][/IMG]
daddyjeep is offline   Reply With Quote
Old 01-16-2016, 05:49 PM   #2
MTCK
MTCK's Avatar
Re: Daddyjeep Hauler - 85 K30 crew cab short bed
Cool rig and sounds like a good plan. Going to keep it a dually or go single rear wheel? What's the specs on the truck? June will be here before you know it!!! Looks like a nice shop to work in.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-16-2016, 05:58 PM   #3
daddyjeep
daddyjeep's Avatar
You are right MTCK, I need to put my signature together. It is a 454, auto, D60/D70, A/C, power everything. The interior is really clean aside from the rust. I plan on single rear wheel. Yes, I am spoiled with my shop. The lady we bought the house from said nobody wanted the place because of the 40×80 shop. I agreed and asked her to drop the price.
Old 02-03-2016, 12:12 AM   #4
daddyjeep
daddyjeep's Avatar
So I finally messed with the truck and little tonight. I took the two, yes two, bolts that held on the fifth wheel hitch on out so I could yank it out of the bed. I can't believe someone hauled trailers with two 1/2 inch bolts. I also investigated things a little and got a pic of this.
[IMG][/IMG]
The bed is really nice for this part of the country. Just look at that floor.
[IMG][/IMG]
Here she is in all her rusty glory. Hopefully I can make some steady progress now.
[IMG][/IMG]
I tried unbolting the bed mounting bolts and to my surprise they actually turned...for a little while. The head started turning in the bed. On to plan B. What is the best method to remove them? I was thinking drilling out the heads would probably be the easiest.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
Old 02-03-2016, 11:07 AM   #5
slotard
Will you be finding new axles or using single wheels in dually offset?
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-03-2016, 11:21 AM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
I would tack weld the head to the bed floor....unbolt, then cut the small tacks off. MUCH easier than drilling out the carriage bolts.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-03-2016, 11:35 AM   #7
daddyjeep
daddyjeep's Avatar
Not sure yet. I am trying to make a deal on a 3/4 ton suburban or a 3/4 ton truck with the 6.0 I want. If either of those deals works out I will have the right axle too. That could cost me more in the long run though if the gear ratios don't match up. Worse case, I will just run wheel spacers for the time being.
I thought about that, or welding nuts to the head. That way I could clean up and re-use the carriage bolts.
04 1500 crew cab
Old 02-05-2016, 05:35 AM   #8
wildwilly4x4
Ive got a crew short bed I built for hauling my jeeps too. Im running an 8.1/4l80e combo though.
wildwilly4x4 is offline   Reply With Quote
Old 02-05-2016, 11:17 AM   #9
Wasted Income
Boosted Member
Me too, but I didn't build mine. My UAW pals in Flint did
Turbo diesel
Old 02-05-2016, 01:41 PM   #10
daddyjeep
daddyjeep's Avatar
somehow I screwed up and move the original pic of the Jeep so here is another.
[IMG][/IMG]
04 1500 crew cab
Old 02-05-2016, 05:26 PM   #11
slotard
I thought dually axles were significantly wider than SRW, so spacers would do the opposite of what you'd want if trying to mount SRW wheels.
The donor trucks will be IFS so unless you're going 2WD you'd need more.
1973 C20, 350/350
Old 02-05-2016, 05:29 PM   #12
daddyjeep
daddyjeep's Avatar
I haven't measured anything yet, but it was my understanding that the dually rear axle is 4" narrower than the front. I'll know more when I get things torn apart...hopefully this weekend.
04 1500 crew cab
Old 02-08-2016, 08:44 AM   #13
wildwilly4x4
Heres my jeep hauler
Old 02-08-2016, 08:46 AM   #14
wildwilly4x4
Old 02-08-2016, 12:14 PM   #15
MTCK
MTCK's Avatar
I thought I had read of folks using H1 rims with squally axles since they have a ton of back spacing.
Willy do you have a build thread for that thing? I want to see more but not hijack...
-Marcus
Project Plow Truck
Old 02-08-2016, 01:33 PM   #16
daddyjeep
daddyjeep's Avatar
This worked beautifully, Thanks.
So obviously I got the bed bolts out. I even got the bed off after that.
[IMG][/IMG]
I then started fighting with the rusty hitch and bumper bolts. Luckily all but three of the bolts broke. Those last three took a 3' cheater all the way off.
Before
[IMG][/IMG]
After
[IMG][/IMG]
I removed all of the unnecessary brackets and started wire wheeling the frame. To my surprise, the frame has very little pitting under the scale.
[IMG][/IMG]
close up of the frame.
[IMG][/IMG]
Here is what has been taken off, including about a 20 pound pile of rust.
[IMG][/IMG]
04 1500 crew cab
Old 02-08-2016, 01:37 PM   #17
daddyjeep
daddyjeep's Avatar
That's a good looking TJ there WildWilly. I thought I saw somewhere that you have a 2A as well. I have a 2A that will eventually become an active project. Your hauler is very nice too.
04 1500 crew cab
Old 02-08-2016, 02:10 PM   #18
wildwilly4x4
Ive got an m38, and 3a. M38 is heavily modded, and the 3a just has a granny tranny and lift.
Old 02-08-2016, 02:27 PM   #19
wildwilly4x4
I never did make a build thread on it, Im too lazy to keep up with those. I did a build thread once on pirate4x4 on my willys jeep, but im just not good about remembering to take pics. If you have any questions about it I'd love to help though.
Old 02-08-2016, 06:26 PM   #20
Chevy_mud_truck
Chevy_mud_truck's Avatar
I might be interested in the section of frame you cut out if you want to part with it
Chevy_mud_truck is offline   Reply With Quote
Old 02-08-2016, 06:27 PM   #21
daddyjeep
daddyjeep's Avatar
Keep watching and remind me when I cut it.
04 1500 crew cab
Old 02-08-2016, 06:34 PM   #22
Chevy_mud_truck
Ok how much are you cutting out and what type cut are you going with (the front section)
Old 02-08-2016, 07:09 PM   #23
daddyjeep
daddyjeep's Avatar
I'm going to do the "z" cut I guess it's called.
I-----,___I. Kinda like that. 14"
04 1500 crew cab
Old 02-08-2016, 07:16 PM   #24
Chevy_mud_truck
I like the z cut to I I was asking I wasn't sure on how much you had to cut out to do a short bed I just know I you had to cut some out of the middle and some off the very end thanks
Old 02-08-2016, 07:28 PM   #25
daddyjeep
daddyjeep's Avatar
From what I understand, 14" in the middle and 6" in the back.
04 1500 crew cab
