![]() Join Date: Aug 2010
WANTED: Orig 66 TH400 dipstick.
The end of my trans filler dipstick broke off at the kink. Luckily, the end piece flaked off just after I extracted it from the tube. Now I'm looking for an original/correct one in good shape.
![]() Join Date: Oct 2013
Re: WANTED: Orig 66 TH400 dipstick.
Can you post photo of the one you need? Application is SBC?
This is a common problem, often they crack and leak. Les |
Chevy guy
![]() Join Date: Mar 2015
Why do they do that? Mine is broke off too and unfortunately is sitting in the bottom of the tube in the transmission. I guess I will drop the pan and retrieve it and find me a new dipstick.
Not sure about the year! I believe it was 67 or older 26 1/2" long (Top ring to tip). I will try for better photo's if this looks close...Ed
#5 | |
They crack and/or break because of vibration. The metal develops stress cracks, then failure. Probably the wrong type of metal was used.
Les |
Here's the subject dipstick. 23-1/4" inches from stop to end. I didn't measure the handle, but it's about 3" or a little more.
![]() ![]() Join Date: Apr 2012
Heres an NOS one Bruce so you can compare GM Part number. Original number was 3905449 changed to 1387568 and again to 1239014
http://www.ebay.com/itm/NOS-1968-73-...ZWeEGb&vxp=mtr http://www.ebay.com/itm/NOS-1968-197...1UREK4&vxp=mtr They are the same as Cars with TH400 so I have several extras used if you need one
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Thanks for the info, Jon. Message coming.
Thanks for the early response. So, that stick looks like it's an inch longer than mine from the stop to end, right? (23-1/4")
Bottom of stopper to tip 23 5/8...Top of metal cap over stopper to tip 24 7/16.....$48.00 for the whole thing tube and dipstick...Ed
#12 | |
Why's it look more like 24-5/8 in the photo? Thanks |
Photo's distorted, cloth tape to give you rough idea! More recent measurements are with a steel tape. Can mic the width and thickness if you want. Also some minor surface rust pitting front and back.
Great, So helpful! ..While you are at it, would you mind weighing it and having some filings analyzed for carbon content? Just kidding. I found one. Thanks anyway. Cheers!
