#501 |
Re: 53 Surburban "Family Truckster"
unfortunately it wont work with a m/t and I have an m21. oh well, back to the drawing board.
#502 | |
![]() Join Date: Mar 2007
Thank you. yes, I thought so too.
I like the idea of the MC being out of sight. On my 48 it is on the firewall. Quote:
Marc
...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#503 |
Well following Doug's lead I too went with a 67-68 Camaro EFI tank. I found one used on Ebay for cheap. It took the seller over a week to ship it. I thought I bet he was having a hard time finding a box big enough. Well when I saw the tank sitting on my front stoop I realize I was wrong. I can believe USPS shipped this tank looking like this. Look at the wires, it looked like a bomb....
I started mocking up the tank today. It took a while but I think I came away with something that will/should work. I had two challenges. 1 - The tank had to be removable from the bottom. 2 - I wanted to mount it in such a way that I don't need straps and the whole thing would bolt in because I want to be able to full dissemble the frame to paint it. I notched the factory brace allowing me to drop the tank low. I will make a bolt in brace (shown with the piece of wood) that will support the front of the tank. I then will box the frame rails. This is give me something to attach some side mount brackets the bolt the tank to...It felt good to get back out in the garage. Here are the pics Marc
#504 |
![]() Join Date: Jul 2012
Following my lead...now I feel so responsible. And I followed dwcsr. Anyway, good ideas Marc. And nice score on the Tank...bet all the UPS folks were giving that shipment the eye.
#505 | |
Marc
#506 |
Lol, you mean if we discount my rear floor redo or the 4 sets of engine mounts that aren't done yet, possibly going a fifth version...? Nope, I never misstep. It is all good though.
#507 |
![]() Join Date: Mar 2011
Marc, glad to see you at it again. With UPS you never know...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#508 |
Wow I can't believe they shipped it like that!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#509 |
Tonight I got back out in the garage and cut all of the metal for my lower tank brace. I also made the mounting tabs for the brace...
All that is left now is to burn in some welds... Marc
...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 Last edited by youngrodder; 04-25-2016 at 10:54 PM. |
#510 |
![]() Join Date: Mar 2010
Nice work... Looking at your ideas so keep posting the little details.
#511 | |
I should receive my trans crossmember on Friday, so that will allow me to set up my drivetrain and figure out my driveshaft length. Marc
#512 |
Egads...you will be catching up to me soon. Nice work on those cuts Marc. They fit really well.
#513 | |
Marc
#514 |
I received my Porterbuilt tranny mount. I mocked it up on Saturday for a few minutes. On Sunday I spent that first 1/2 of the day at an area car show with my 48 truck..the weather sucked but it was good to get it out.
Later on Sunday I got back out in the garage to drill the holes for the tranny mount. Then the bad news....after checking my drive shaft length/angle, I realized that my rear end is 1" off from center. This required me to cut away a my bag mounts, and trailing arm pads. The old 2 steps forward 3 back. At least I found it in advance and since I only tacked the brackets on it was not too difficult to remove. Marc
#515 |
Marc, engine tranny set up look good...Jim
#516 |
Good find on the diff, That would suck if it caused a problem driving, then you found it. Also very nice 45* cuts.
#517 |
Glad you caught the issue Marc. Guessing now the axle ends are equal distance from the frame rails? Good looking trans mount. Packaging in that area gets tight, especially with the under floor master. Looks like PB has a good solution.
#518 |
Your tank is a nice fit behind the Watts
![]() Don't we all make small mistakes sometimes ![]() Glad you found it in this early stage!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#519 | |||
Thanks Jim...
Thanks on the drive shaft dimension. I will check my notes. It sounds close to what I think I wrote down. Quote:
Marc
#520 |
Well this post will be picture heavy...On Sat I took the 48 to a local show that I have not attended in 7 yrs or more and I have never taken my 48 there. I took a few pics of some odd ball stuff that caught my eye. Who has seen or heard of a Marlin? it was cool and I loved the original interior...
#521 |
Mothers day and soccer games for my boys ate up most of the weekend. I did get out in the garage yesterday after 7. I finished welding up my tank brace.
On Monday I got back out and drilled the mounting holes for the brace. I made mounting tabs and I tacked in the backing plates as well as the mounting tabs. I wanted to make sure that I can drop the tank from the bottom which I confirmed that I can. I just need to finish weld the various brackets. I'm pretty happy with how it turned out. On Sunday Cooper (my oldest son - 11 yrs old) was board so I said you want to learn how to weld. He said OK....He didn't do bad screwing around welding together some scrap pieces. Thanks Marc
#522 |
I told you I had a lot of pics......The tabs I tacked to the frame boxing plates I made. I took it all apart and started to burn it in...
Marc
#523 |
Nice!! My boys 12 & 13 just learnt how to weld a week ago, building a off road trailer with me. Your 48 is great.
#524 |
Wow, you made a lot of progress for after 7 on a Sunday. Nice work on the brackets and tabs. And it is very cool your son was learning to weld.
Your truck looks really good out at the show and yes, I remember the Marlin. Not many around. |
#525 |
Marc,
I've been following your burb build. You sure are doing nice work. I really like your 48 pickup. Maybe I'll be able to see it at Kalamazoo hot rod show. I do remember seeing some Marlins: back in the day. AMC didn't start making power until they came out with Javlins and the AMX. Some of those were really quick. Anyway, thanks for all your posts, helps me out a lot. Jeff |
