#576 | |
![]() Join Date: Mar 2007
Re: 53 Surburban "Family Truckster"
I'm sure with your help you aren't too far behind. Yes, I can list the fittings. Someone else asked as well. I should see if I can screen shoot my Summit wish list...That would save some re-typing. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#577 |
Here is my fittings and hose part number list. Your quantity and type of fitting might be different based on how you are designing your system. Remember I will be going from rubber flex hose to metal tube back to rubber flex hose
Russell Performance 640863 - Russell Fuel Rail Fitting Adapters RUS-640863 Fuel Rail Fitting, Aluminum, Black, Straight, 5/16 in., -6 AN, Each (Mfr. #: 640863) 1 Russell Performance 660443 - Russell ProClassic AN to NPT Adapter Fittings RUS-660443 Fitting, Pro Classic, Adapter, Straight, -6 AN Male to 1/4 in. NPT Male, Aluminum, Black Anodized, Each (Mfr. #: 660443) 2 Summit Racing SUM-240615BP - Summit Racing® Premium Braided Nylon Hose SUM-240615BP Hose, Premium Braided Nylon, Black, -6 AN, 15 ft. Length, Each (Mfr. #: SUM-240615BP) 1 Summit Racing SUM-221330B - Summit Racing® Fuel Rail Fittings SUM-221330B Fuel Rail Fitting, Aluminum, Black Anodized, 3/8 in. Male Spring Lock to -6 AN Male Threads, Each (Mfr. #: SUM-221330B) 1 Russell Performance 640853 - Russell Fuel Rail Fitting Adapters RUS-640853 Fuel Rail Fitting, Aluminum, Black, Straight, 3/8 in., -6 AN, Each (Mfr. #: 640853) 2 Summit Racing SUM-220690B - Summit Racing® Hose Ends SUM-220690B Fitting, Hose End, Straight, -6 AN Hose to Female -6 AN, Aluminum, Black Anodized, Each (Mfr. #: SUM-220690B) 6 Earl's Performance AT165006ERL - Earl's Performance AN to Tube Adapter Fittings EAR-AT165006ERL Fitting, Tube Adapter, Male -6 AN, to 3/8 in. Tube, Aluminum, Black, Each (Mfr. #: AT165006ERL) 2
#578 |
![]() Join Date: Jul 2012
Marc, thanks for taking the time to share! I copied and saved for future reference.
#579 | |
Marc
#580 | |
Turned so hot out still haven't made it to the shop so that doesn't help. |
#581 |
Well I have been working on the Suburban. I decided as much of a pain as it is to put the body back on the frame that it would be best to continue the mock up process. I found myself staring at the frame wondering it this will fit here or if that will fit there. Putting the body back on did prop beneficial to figure out where stuff will fit.
I hade to clearance the flange of the rear wheel tubs to clear the frame notch. I was surprised that the notch didn't stick up any higher then it does. I was able to clearance the firewall to clear the brake pedal. I also confirmed that I don't need a tranny tunnel like I thought so that was a pleasant surprise. Thanks Marc
#582 |
To clarify the hole for the brake pedal looks huge but the pedal has a larger mount for the pedal than shown in the pics. I plan to make a small plate that screws to the floor to cover the hole.
I'm heading to Columbus to the Goodguys show this weekend and I'm driving the 48. Looking forward to seeing some people from this site and grabbing some parts for the Suburban. Marc
#583 |
![]() ![]() Join Date: May 2015
Looking good marc...that thing has a killer stance..I know you said those wheels wernt what your going to run but they look killer on the burb
#584 |
Looks GREAT!!
#585 |
Good work Marc, body is fitting really well. It sure helps to see it coming together.
Have fun at GG. I have to be in Columbus Friday and we discussed staying over. Decided to head for home after my meeting instead...too much to do. |
#586 | |
Thanks Mike.... Marc
#587 | |
Marc
#588 |
looking very cool, glad you are dodging some bullets!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#589 |
![]() Join Date: Mar 2011
Looking good Marc, I would rather have the body on two or three times, than get it painted, etc and then find the problem. Of course I don't have to lift it two or three times...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#590 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Looking good marc.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#591 | |
yes, its good to catch a break every now ands then
Thanks man....
#592 |
That looks amazing sits just right. Have fun at the Good guys show.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#593 |
The GG show was a success for many reasons. I decided to drive my 48 this year instead of trailering. Driving is mush more fun. Over 600 miles round trip with no issues. I got to see Bob's (OldNSlow) truck. Man is it nice. The paint turned out great. He has decided to sell it. Oooops did I let that slip.
I did a fair amount of research on wheel and tire sizes for the Suburban., I picked up some Delmo LS1 valve cover adapters from Travis or Pro Performance. Travis is great to deal with and he delivered the parts to me at the show and provided a show discount (win/win/win/). I also found a nice set of script valve covers for CHEAP.....Score. I got to check out and talk with the owner of Delmos latest truck build. It was a very cool truck. I also picked up the trim piece I needed to fix the one inner trim from the Suburban.. All in all it was 4 days filled with cars and hanging out. Marc
#594 |
Very nice! Good stuff!
#595 |
Here are a few more pics..
Marc
#596 |
Marc, great about the drive to the event, your truck looks great as always...Jim
#597 |
![]() Join Date: Mar 2010
Suburban is looking sick...... and the truck, well we all know its one of the nicest and most recognized AD's out there. Nice work as always.
#598 |
Thought you might like to see this marc is that your truck in the background pretty cool
https://www.good-guys.com/ggn-2016
Just Cruzin Through Life |
#599 | |||
Marc
#600 |
I like those adapters with the covers. And your truck! Thanks for sharing the pic's.
Wife and I were in Columbus that Friday for work. Marc was being a good guy, texting me to convince us to join in. Yeah, We should've...just too much to do at home. Thanks again Marc! |
