06-22-2016, 10:46 PM | #851 |
Re: Mesquite 1966 C10 - LS3 W/Air Ride
Thanks man!
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
06-23-2016, 11:41 AM | #852 |
Awesome Truck. I love it. The color is awesome. Man that thing is quick.
06-23-2016, 12:04 PM | #853 |
Thanks man, the color took a lot of time to find, internet searches then going thru endless books at the paint store then painting actual samples.
Actual samples is the only way to go in my opinion. She is as quick as I will ever need her to be. Thanks again!
06-25-2016, 12:06 AM | #854 |
Did some more cruising tonight at higher speeds, 6th gear is 77mph at 1500rpms. 3.08 rear end, I'm happy with that.
License plate and bracket with light installed, I'm officially street legal.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 Last edited by 66ChevyMax; 06-30-2016 at 10:04 AM. |
06-27-2016, 10:32 PM | #855 |
Here's a video of the evidence of her first burnout and yes I crossed the line.
https://youtu.be/zW86k7MEr30
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 Last edited by 66ChevyMax; 07-07-2016 at 11:19 AM. |
06-30-2016, 10:02 AM | #856 |
Still working out the bugs, speed controller for A/C fan went out, new one is on the way, bought the unit from vintage almost 4 years ago, they are sending free of charge, props. From the start I have had some issues with the throttle body, High Idle Code, a short rev up or it would die during coasting, then a dirty throttle body code and I knew that was wrong. So replaced the throttle body and all is good.
On to whatever comes next, HA! Will pick up speakers and amp today to start the stereo install which is greatly needed so I can't hear every little noise the truck makes. Have made several hard breaking runs and all is good, she stays straight and the pressure and touch required to make the tires squeal isn't bad at all. Also put her back on the lift and gave everything a once over, anyone think I'm paranoid?
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 Last edited by 66ChevyMax; 06-30-2016 at 10:14 AM. |
06-30-2016, 10:53 AM | #857 |
quote: anyone think im paranoid?
no cautious and responsible |
06-30-2016, 11:18 AM | #858 |
Thanks, you would think since I put every single bolt on this truck I could relax but it's just the opposite .
From the start I never just snugged anything that was important, I always torqued it down and if it need adjusting later I would loosen and re-torque. So I feel confident I haven't forgotten anything I'm just nervous about the unknown. It doesn't help that each test drive something comes up I for sure don't want to hurt myself or anyone else so I think I'm proceeding with this truck the right way!
07-05-2016, 09:51 AM | #859 |
Hope everyone had a great 4th of July, I have a little less hair on my arms and ringing in my ears which is typical after the 4th at my house, so it was a good weekend
Drove the truck quite a bit this weekend, truck has about 500 miles counting the test drives during pre-assembly. Installed the stereo system this weekend, 6 1/2" rounds in kick panels, 6x9's in boxes behind the seat, amp and sub under the seat, will post pictures later. Drove it for an hour Saturday about 55 miles total with no issues. I was a little concerned that the tranny and diff combination was going to be a little tall but I'm pleased with the final results, below is the numbers: Rear end: 3.08 Posi Rear Tires: 285/50 R18 T56 6th Gear: .63 2,000 rpms - 4th 60mph, 5th 70mph, 6th 80mph Vintage Air is now sending a new ECU as the A/C fan is still not working, this should do the trick.
07-05-2016, 10:12 AM | #860 |
3.08 gear...any idea how fast it'll go topped out in 6th?
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram |
07-05-2016, 10:20 AM | #861 |
No but she would be air born by then
07-05-2016, 10:21 AM | #862 |
318mph
07-05-2016, 10:43 AM | #863 |
Does that mean your going to add wings to the sides?... maybe hide them so they fold out at a certain speed?
07-05-2016, 11:03 AM | #864 |
I would back off at 300
With her aerodynamics and the West Texas winds, wings would not be required, the air under the hood alone would get this thing air born!
07-12-2016, 09:47 AM | #865 |
Had my oldest Son make this negative space vinyl sticker from this photo, it turned out pretty cool I think.
07-12-2016, 09:49 AM | #866 |
wow that is such a thoughtful touch. You just made the truck 10x better!!! Now you'll always be thinking about him when you see the truck. What an awesome tribute! Best upgrade yet bud.
07-12-2016, 10:07 AM | #867 |
Thanks brother, I like the way it turned out and it gives some ownership to my oldest who worked very hard to make it look good.
07-13-2016, 07:27 PM | #868 |
Very nice work on the sticker and a fitting tribute!
07-15-2016, 09:50 AM | #869 |
Thanks Doug!
07-16-2016, 11:05 PM | #870 |
Went for a drive today and came across this beauty, not sure why she was parked out by the street, looks like it was purchased at Barrett Jackson:
07-20-2016, 10:22 PM | #871 |
Turn it up, a little burn out, also made my first 0-60 run - 5.9sec!
https://youtu.be/q_l2Ig_7wrU https://youtu.be/q_l2Ig_7wrU
07-21-2016, 02:28 AM | #872 |
Rollin' Old Skool
Sounds like you're having fun!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
07-21-2016, 09:05 AM | #873 |
The 60-66 GMC/Pontiac guy....
I believe I have watched your build since the day you made your first thread post. Nice to see one done.. Maybe one day I'll finish one of my own..
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
07-21-2016, 09:45 AM | #874 |
Thanks Phillip, yes I am
Thanks Chris, there was many days even years that I thought how and when will it ever be done. Truth be known it's still not completely done but I can drive it anytime I want so maybe it is . Keep at it the day will come!
07-21-2016, 09:23 PM | #875 |
. Truck looks and sounds great, again - awesome job building this one! I always look forward to seeing new pics in this thread! . .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
