07-15-2016, 07:34 PM | #101 |
Re: 1978 Russet Metallic 4x4
. Awesome job w/ this one - looks really sharp! Think your Dad will drive it a lot again, or will it see limited use? . .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
07-15-2016, 07:36 PM | #102 |
Not sure, but if he doesn't, this guy will.
07-15-2016, 07:55 PM | #103 |
. That interior and front end accessories look great! . .
07-16-2016, 11:10 AM | #104 |
07-28-2016, 01:10 PM | #105 |
Dad had only one complaint. The sloppy steering from the original rag joint. So Tuesday I installed a Borgeson unit with u-joints at both ends. Nice upgrade. Ended up sawing the original in half to get it out. I had to cut 8" off the Borgeson unit to get it to fit right. And it was damn hot outside.
Here are me and the boys heading to a car show a couple weeks back. We're not very cool. Last edited by buffydores; 07-19-2017 at 03:08 PM. |
07-28-2016, 01:17 PM | #106 | |
http://www.americanfloormats.com/pyramid-rubber-mats/ |
07-29-2016, 07:11 PM | #107 |
That's a great picture!
07-29-2016, 07:13 PM | #108 |
Did you get the mirror to stay? Mine do the same thing at highway speed. I was thinking of taking it apart and wrapping a motorcycle rim strip around the post and putting the locking plate back on. But wasn't sure.
07-30-2016, 08:28 PM | #109 |
I installed a new one. The answer is no. Once you hit 70, they start to creep. I tried adding rubber to the post. Didn't work. I'm sure something would work, but I didn't figure it out.
07-30-2016, 10:06 PM | #110 |
I know the pieces fit
The rubber grommet is just to seal the housing where the post goes into the base. There should be a friction sleeve wrapped around the mirror post where it clamps into the base. I'll see if I can find a picture from when I rebuilt and painted mine.
07-31-2016, 09:05 AM | #111 |
John: I know, that's what we're talking about. There just doesn't seem to be enough friction at those surfaces to matter, even tightened. I added several layers of rubber and it would still rotate.
07-31-2016, 12:41 PM | #112 |
10-4. Mine did the same thing, they were original to the truck though. When I had them apart to paint them, I soaked the base gaskets, grommets and sleeves in hot water and Dawn dish soap then cleaned them. They stay put now. If yours are new, dirt probably isn't the issue - maybe take the sleeves off and tape some skateboard tape in place instead? That should grip good.
08-02-2016, 03:50 PM | #113 |
Here's the Borgeson shaft:
Packing stuff out at the lake: Last edited by buffydores; 07-19-2017 at 03:11 PM. |
08-02-2016, 10:37 PM | #114 | |
You can remove the screw at the bottom of the cover over the base of the mirror, and slide the cover up over the rod closer to the mirror head and there are 2 bolts you can access under the cover the gently tighten down on those, test the mirror head to make sure you can still move it. Then just slide the cover back down over the mounting hardware and replace the screw.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
08-02-2016, 10:48 PM | #115 |
Lol. Folks, even when you tighten, they still creep. I drive this thing at 80 on interstate. Those big Dumbo's move.
08-02-2016, 11:15 PM | #116 | |
BTW, that is THE nicest Blazer I think I have ever seen!! Great job! I just LOVE that interior, sweet!
08-02-2016, 11:30 PM | #117 |
08-03-2016, 12:26 PM | #118 | |
What I did was take mine apart, and then transfer the GM rubber, and the GM base plate over to my LMC mirrors. They now work fantastic and do not move at all on their own! I will post a few pictures over in my blazer thread, but I couldn't be happier with the results. It seemed like the rubber that GM used was a completely different product. It was also about 1/2 the size of the LMC rubber which was surprising. The GM base plates also fit the shaft much better and have more of a "wrap" on the mirror stem. Phillip |
08-10-2016, 12:35 AM | #120 |
Are you running r12 or r134a?
08-11-2016, 05:54 AM | #121 |
08-15-2016, 04:17 PM | #122 |
Slots go on anything!
1974 Jimmy- 5.3/4L80e/NP241 |
12-04-2016, 07:27 PM | #123 |
Just being awesome.
12-05-2016, 11:13 AM | #124 |
I'm just glad to be here!
Love this blazer. I hope to see it around town one day...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-05-2016, 11:40 AM | #125 |
