Old 06-29-2016, 09:44 AM   #226
TJ's Chevy
TJ's Chevy's Avatar
Re: 1964 GMC 1500 "crustine" semi- build.
Originally Posted by Cape Codder View Post
Those old clocks are actually mechanical with an electric winder. Inside is a set of contact points that get dirty or corrode and may need a little filing . When the points close it creates a electromagnet that pulls the winder and opens the points the clack runs mechanically till the points touch and rewind again. Pretty basic ,I am no clock repair man but have fixed a few of those over the years. They usually have an adjuster to speed up or slow down as needed.
Thanks! That's some Great info!
Originally Posted by 66ChevyMax View Post
That is cool TJ!
Thanks man!
Old 07-20-2016, 10:54 PM   #227
TJ's Chevy
TJ's Chevy's Avatar
Well I have been driving Crustine Ever day. She's been running like a top! So....I figured I needed something to do on it and found this MSD box. It's an ignition control that gives off several sparks instead of one. Pretty cool, can't hurt to try it I don't think!
Old 07-21-2016, 10:53 AM   #228
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Nice... looking forward to see if you feel a difference in everyday driving.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 07-21-2016, 05:02 PM   #229
TJ's Chevy
TJ's Chevy's Avatar
Thanks, got some spiral core plug wires coming from O'reilys so I have to wait for those. Hoping it works well!
Old 07-24-2016, 07:24 PM   #230
TJ's Chevy
TJ's Chevy's Avatar
Hey guys! Wiring up my MSD box as I type. lol Quite a challenge wiring an MSD to a pertronix but I figured it out after a few hours of playing with it. She runs like a top! Can't wait to get it done so I can test run it!
Old 07-24-2016, 09:32 PM   #231
Old 07-24-2016, 09:56 PM   #232
Ta2Don
Ta2Don's Avatar
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 07-24-2016, 11:26 PM   #233
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by Ta2Don View Post
Thanks guyz!
Box is all wired in and loomed up an looking perrty! She runs perrty good!
Old 07-25-2016, 11:04 AM   #234
Johnny_Lamebridge
You're going to miss that "unburned fuel" smell coming out of exhaust pipes.
Old 07-25-2016, 06:38 PM   #235
TJ's Chevy
TJ's Chevy's Avatar
lol! Didn't do to bad before either! Checked the plugs awhile back before I had installed the box and they were burning pretty darn clean. Gonna check them now and then gap them wider.
Old 07-30-2016, 12:43 AM   #236
TJ's Chevy
TJ's Chevy's Avatar
Well Crustine is gonna have her first "long" trip tomorrow(Saturday). Heading 40 miles to be in an all day car show. Supposed to be over 100 degrees and there may be no shade accept what we have for coverage. lol I am well stocked up on tools and have 4 spare quarts of oil. Just drained a few quarts this evening and refilled with straight 30 and a quart of lucas. Also gonna have spare water just in case. She tends to run at a quarter on the temp gauge so I think we'll be fine on the way up for sure...way back...she may get a bit warmer. haha Leaving at 6 AM sharp and meeting a buddy of mine in his 48 stude half way...then we're meeting another buddy of mine in his 65 gmc one ton burb and heading to the show. Wish us luck! Should be a great day. Will try an get lots of pictures.
Old 07-30-2016, 02:01 AM   #237
scoot_mcgrute
Have fun at the show! I hope your trek goes without any issues.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 07-30-2016, 06:21 AM   #238
Fun times a comin!!
Old 07-30-2016, 06:29 AM   #239
Ta2Don
Ta2Don's Avatar
Enjoy your day Brotha!!! Crustine will do great...
DON
Proverbs 27:17
Old 07-30-2016, 06:42 AM   #240
TJ's Chevy
TJ's Chevy's Avatar
Fun times a comin!!
Thanks guyz! She should do fine. Gonna take it easy on the way up and back. I think it'll do the engine some good...get some of that carbon blown off the valves. haha
Old 07-31-2016, 03:09 PM   #241
Ta2Don
Ta2Don's Avatar
No update yet?
DON
Proverbs 27:17
Old 07-31-2016, 11:32 PM   #242
TJ's Chevy
TJ's Chevy's Avatar
No update yet?
Well here is your update brotha.
Old 07-31-2016, 11:42 PM   #243
Johnny_Lamebridge
Well... that doesn't look good.
Old 08-01-2016, 12:45 AM   #244
TJ's Chevy
TJ's Chevy's Avatar
Not as bad as you think. haha On the way back from the car show the engine lost power pulling a grade. My initial thought was ignition or fuel pump going out. Limped to the top and pulled over...sure enough it was vapor lock. The metal filter had fallen close to the exhaust manifold and was really hot. So I moved it away from the manifold and put a cold wet rag around it. Lucky I was half way home so she drove the rest of the way ok. It was over 100 degrees outside and she was running a tad bit hotter as it was her 1st long journey....but she never got past 190-200 the entire time. And while driving the engine was lower than 180. After I got home a freeze plug blew at the back head and drained most of the coolant on the ground. SO, since I needed to fix the plug which required the head to be removed I figured...Hell, Why not! Let's pull the darn motor and install new gaskets and reseal it. Boy was that a mistake...biggest pain in the butt I have had yet. I'm a find that engineer and kick him good. Anyhow, here are the pictures. The 305 will be resealed and painted either caddy red or detroit diesel green.
Old 08-01-2016, 12:47 AM   #245
TJ's Chevy
TJ's Chevy's Avatar
Gotta love idiot previous owners who can't drive a stick shift for their life. lol New clutch, pressure plate and hopefully a flywheel will be on their way as well. Notice the chunk of clutch missing...
Old 08-01-2016, 02:10 AM   #246
62stepside longbox
62stepside longbox's Avatar
Wow man that escalated quickly, sorry to about it. At least it'll give you a chance to freshen her up, she'll be running like a top again in no time
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 08-01-2016, 05:16 AM   #247
Hmmmmm....I have seen clutches do that with multiple hard lanuches off the line.
Sorry to see the mess, but least now you'll have the heart of Crustine back to gold.
Old 08-01-2016, 07:43 AM   #248
Ta2Don
Ta2Don's Avatar
From Car show to pulling engine, wow is appropriate!!! Will post update later today... Glad the V6 is getting a freshening up... ...and that clutch needed some attention, good timing on the issues... Nevertheless, hope the show was enjoyable even in the heat...
DON
Proverbs 27:17
Old 08-01-2016, 09:40 AM   #249
TJ's Chevy
TJ's Chevy's Avatar
Thanks man. Yeah, anything can happen with these old things! The engine could use a light rebuild, but it runs and runs well so I am stopping at a reseal.
lol. I drove that truck like a grandma. Never has done a burnout with me behind the wheel yet! haha!
lol. Thought ya might get a jaw drop out of it. But it should be worth it in the long run as it won't be slinging oil out the rear main and all over the place. Plus for the next car show I can saw I Did something! haha! Pictures of the show will be uploaded onto another thread soon man.
Old 08-01-2016, 12:47 PM   #250
61K10
61K10's Avatar
TJ--you were running out of things to do anyway. that new MSD 6a electrocuted that freeze plug and and clutch disc lol! Have fun---------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
