Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-18-2016, 12:09 PM   #401
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How To: Ruin a Perfectly Good K/5
In case anyone was wondering, yes, a Blazer will fit in the back of a C10...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-18-2016, 01:08 PM   #402
smbrouss70
smbrouss70's Avatar
Nice! Soooooo.... What's happening here?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-18-2016, 04:23 PM   #403
gringoloco
A guy with a truck
gringoloco's Avatar
This:
I wish it were something cooler/more fun...
-Chris
Old 09-18-2016, 04:58 PM   #404
smbrouss70
smbrouss70's Avatar
It's all part of it... Get that out of the way, then the fun stuff can start!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 09-18-2016, 08:04 PM   #405
SCOTI
SCOTI's Avatar
Originally Posted by gringoloco View Post
This:
Black??
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-18-2016, 11:14 PM   #406
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by SCOTI View Post
Black??
Haha, black is a pretty cool color, but it will hopefully end up blue like everything else.
Made some progress, if you can call disassembly progression. Inner rocker is very solid, as is the floor. I will have to decide which of those 'good' pieces of metal I want to cut out to repair the floor support and kick panel. There is little more gratifying than hearing the 'pop' of a spot weld giving up its grip...
-Chris
Old 09-18-2016, 11:15 PM   #407
Chulisohombre
Chulisohombre's Avatar
Nice new bucket seat you got there. Haha
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 09-18-2016, 11:17 PM   #408
gringoloco
A guy with a truck
gringoloco's Avatar
Shoddy previous repairs caused this area to be worse than it should have been. Yes, that's a lap weld and 1/4" thick plastic filler. Lesson of the day: do it right the first time, or do it again later. A pillar will need patched, B pillar is thankfully solid (it's the stuff behind it I'll need to work on).
-Chris
Old 09-18-2016, 11:20 PM   #409
gringoloco
A guy with a truck
gringoloco's Avatar
This is a kind of fun
I see what you did there! It almost matches the door panels
-Chris
Old 09-19-2016, 02:12 PM   #410
gringoloco
A guy with a truck
gringoloco's Avatar
Morning progress:
Cut out some offensive rot in the pass fender. First time welding in a while, but it turned out in the end. Patch was ok at best, shape was a distant approximation of a fender, but I beat/cut it into submission. Primed and back on the pile...
-Chris
Old 09-19-2016, 03:13 PM   #411
lks dcvn
lks dcvn's Avatar
Looks good!
lks dcvn is offline   Reply With Quote
Old 09-19-2016, 04:04 PM   #412
mcbassin
Still Learning
mcbassin's Avatar
Dang Chris, I thought this rig was without rust. I see you are making it right. Keep up the good work!
Old 09-19-2016, 05:30 PM   #413
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by lks dcvn View Post
Looks good!
Thanks guys! Nothing like what some people deal with, but there's a few spots. I'm slowly exorcising the demons
-Chris
Old 09-19-2016, 05:54 PM   #414
lolife99
67-72 parts collector,…
lolife99's Avatar
Shoddy previous repairs caused this area to be worse than it should have. Yes, that's a lap weld and 1/4" thick plastic filler. Lesson of the day: do it right the first time, or do it again later. A pillar will need patched, B pillar is thankfully solid (it's the stuff behind it I'll need to work on).
GMC Pauls and Wes at Classic Heartbeat have some of the hard to find repair panels specific to these year Blazers.
Yours looks pretty solid compared to mine.
Keith
Convert to disc brakes.
Old 09-19-2016, 08:38 PM   #415
gringoloco
A guy with a truck
gringoloco's Avatar
I ordered the pile of parts I have from GMCPauls. I appreciate that they won't sell useless junk and are not afraid to say so. I hope to not have to replace the Blazer specific (read:expensive) parts in the B pillar area. Without cutting it open yet, it looks like I can get away with patching. We'll see...
Your Blazer looked so solid. These things can sure hide it. I started poking the two spots I have at the rear of the bed and I'm a little worried about how far it has spread. Only one way to find out
-Chris
Old 09-19-2016, 08:48 PM   #416
gringoloco
A guy with a truck
gringoloco's Avatar
So, this morning was fender, this afternoon was rear quarter. Second verse, same as the first. I will need to body work the trim line, but otherwise I'm pretty happy with it.
-Chris
Old 09-20-2016, 09:27 AM   #417
aggie91
I'm just glad to be here!
aggie91's Avatar
The repairs are looking good.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-20-2016, 11:26 AM   #418
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! Getting deep, now:
-Chris
Old 09-20-2016, 12:17 PM   #419
Hewfil1
Hewfil1's Avatar
Luck be with you, I'm starting rockers, body mounts, and all kinds of body repair on my 1974 K10. It's gonna be a hell of a job.
Hewfil1 is offline   Reply With Quote
Old 09-20-2016, 02:52 PM   #420
mcbassin
Still Learning
mcbassin's Avatar
Nice progress Chris! Looks like you are into it deep now. What's the plan for paint? just gonna touch it up and blend it?
Old 09-21-2016, 12:35 AM   #421
gringoloco
A guy with a truck
gringoloco's Avatar
Hell is right, but it's a fun hell that's worth it in the end. Good luck to you!
Thanks, and yup, trying to keep it all below the trim, so there's little blending required and I can maintain the rest of the original patina, since that's so popular these days . Had to get the paint shop to remix, as their first attempt from the code was too light. Dropped the glove box door off for a match.
-Chris
Old 09-21-2016, 01:08 AM   #422
gringoloco
A guy with a truck
gringoloco's Avatar
Started out today after poking at the rust, being able to see the ground through the bed floor and rear cross sill. I cut it all out only to find that the good metal was under the rear stake pillar. At this point, I had two options, remove the bedside, or cut the post. I took the path of least resistance.
Made a patch for the cross sill and welded it in. Was nice to weld on something sturdy that I could actually stitch instead of using a million tacks. Coated it in weld through primer then fitted the ribs. The patch for this area is actually nicer than the original GM stamping with clean, crisp edges at the end of the ribs. Almost makes me want to use the whole thing. Almost. Lined up pretty good, with only minor massaging to get the peaks and valleys aligned. It will take a little extra body work to be perfect, or I might just leave it, as it will be under the carpet.
I'll have to button up the pillar tomorrow, as I got sidetracked with the quart of POR-15 I picked up while at the paint store today. I coated all kinds of stuff, and was actually having fun doing it (I think the fumes were getting to me )
Side note: POR does not come off of skin easily. I have heard this a number of times and it is true. Very true. I'm just glad I wear long sleeves to work...
The other side should be less involved, as the damaged area appears smaller and I don't have the gas filler/vent to contend with. We'll see tomorrow
-Chris
Old 09-21-2016, 11:35 AM   #423
jaros44sr
jaros44sr's Avatar
nice work. where'd you get that patch panel. reason,IMHO, they always rust out there is wheel splash. I suppose we should seal up that area with dum--dum
I can't see the seam
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-21-2016, 01:35 PM   #424
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! The patch is cut from the bed floor repair panel from GMCPauls. It's the entire width, and around 15" long. I'll end up throwing probably 90% of it away...
I plan on POR-ing the crap out of the area then sealing the leading edge of the crossmember where it meets the floor with flexible seam sealer.
That's the idea
-Chris
Old 09-21-2016, 01:37 PM   #425
gringoloco
A guy with a truck
gringoloco's Avatar
Welded up the pillar:
-Chris
