01-09-2016, 04:45 PM | #26 |
Moderator
Re: New 64 Stepper Project
Christmas was good to me. We are still in California.
I just posted one pic even though I have two of each steps, lower cab mud guard, CaptainFabs power steering bracket etc: Bunch of "stuff" lower A-Arm u-bolts, rear axle brake line clamps (CPP), Trailing arm bushings . . .: Fuel Line parts: Master brake parts, line and CaptainFabs bracket:
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 01-09-2016 at 05:06 PM. |
01-09-2016, 04:48 PM | #27 |
Moderator
15" Steering Wheel:
Eaton 30 Spline Posi, Richmond Gear Ring & Pinion, Master install kit: Mossier 30 Spline Axles, lugs:
01-09-2016, 04:50 PM | #28 |
Moderator
I had a great set of hood hinges, sent them to Cadilac plating to get them Yellow/gold zinc plated, then clear-coated:
01-09-2016, 05:05 PM | #29 |
Moderator
Almost forgot - the front of the hood has some pin holes in it after blasting and epoxy priming, so I bought the upper and lower front hood sheet-metal so that should take care of that.
01-11-2016, 12:45 PM | #30 |
Moderator
Trying to locate the two seals that are top of the front fenders at the firewall cowl area.
02-06-2016, 01:50 PM | #31 |
Moderator
Update - I went with a POL Trac Bar as the Early Classic would hit the frame when it was all the way lowered (just in case)
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 12-03-2016 at 10:27 AM. |
03-06-2016, 12:13 PM | #32 |
Moderator
Got my rear disc brake kit in, came with most everything needed (one side shown).
04-22-2016, 04:20 PM | #33 |
Moderator
Also bought an electric emergency brake set-up.
06-04-2016, 09:57 AM | #34 |
Moderator
Still working in Cal. but found Ricks Radiator in Azuza and bought a Aluminum Desert Cooler by US Radiator - at a KILLER price.
07-30-2016, 07:22 PM | #35 |
Moderator
"Finally" got the powdercoating work back (almost four weeks) and began assembling the goodies. Upgraded to the larger lower control arm U Bolts as well.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 12-03-2016 at 10:22 AM. |
08-18-2016, 06:20 PM | #36 |
Moderator
Installing the rear end, trailing arms, track bar, sway bar etc. Got the fuel and brake lines installed.
08-18-2016, 07:50 PM | #37 | |
Looks good. John |
08-19-2016, 08:14 AM | #38 | |
Moderator
You need help?
08-19-2016, 08:53 AM | #39 |
Very nice truck
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
08-19-2016, 09:14 AM | #40 |
Wow, Gauges and Chassis looks great, glad to see the purple gone!
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
08-19-2016, 12:00 PM | #41 |
Man, you're serious on doing this truck right.
08-19-2016, 12:42 PM | #42 |
Moderator
It's a sickness.
08-26-2016, 11:19 AM | #43 |
Moderator
Getting Ready to send it to paint.
08-27-2016, 10:24 PM | #44 |
Very cool
63 C10 65 Chevy Custom Cab w/ Big Back Window 66 C30 72 skylark w/ 454 65 K10 May the bridges I burn light the way.... |
08-27-2016, 11:19 PM | #45 |
Gonna be a sweet ride!
09-20-2016, 09:33 AM | #46 |
Moderator
At the paint shop now.
09-25-2016, 04:30 AM | #47 |
Epic build!
Looking forward to seeing the color |
09-25-2016, 08:24 AM | #48 |
Very Nice. Where did you find the steering wheel?
09-25-2016, 08:40 AM | #49 |
Moderator
They're called American Retro steering wheels. Got this one from Speedway.
09-25-2016, 01:33 PM | #50 |
Thank you. That is really good looking
