11-08-2016, 08:54 PM | #276 |
Re: Buried to Bagged 1972 2wd
Lookin good!
I assume there's room for the column by that 90 degree brake bracket--the pic is deceiving. Whose bracket is that? |
11-14-2016, 10:13 PM | #277 |
Sofa King Crazy!!
It will be extremely close. I may have to make my brackets to move it to the side a little and make adjustments to the pedal arm itself. I got the bracket off of the FleaBay close to 2 years ago and cannot remember who it was from.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
11-22-2016, 02:21 AM | #278 |
Sofa King Crazy!!
Did a little something different. I faux boxed the frame to house all the wires and lines. They will be approx 1 1/8 off the frame. Definitely makes it look a little different. I bead-rolled and dimple-died them for a little extra fancy.
11-22-2016, 06:52 AM | #279 |
Collector of Projects
I wouldn't mind seeing a picture of the door closed to see the top edge of the door and the bedside....
11-22-2016, 09:25 AM | #280 |
Still Learning
Awesome choice of wheels! Chassis is looking great too. I have been dead set on Racelines, I sure hope they don't screw up on mine when I'm ready to order.....
11-22-2016, 10:49 AM | #281 |
Looking really good, nice touches.
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
11-22-2016, 06:19 PM | #282 | |
Sofa King Crazy!!
11-22-2016, 06:22 PM | #283 |
Sofa King Crazy!!
Hey buddy! Thank you, so much happier with my new choice. Raceline wasn't much help through the whole process, everytime there tried to fix something they made it worse. I would save the extra 400 to 500 and step up to a Boyd. Totally worth it in the end.
11-22-2016, 06:23 PM | #284 |
Sofa King Crazy!!
Thanks Mark! I am trying to go all out on this build. Hope I hit the mark!
11-22-2016, 06:32 PM | #285 |
Sofa King Crazy!!
Hoping there are no clearance issues. I may have to cut a little more out of the side to make sure. There needs to be about 1.5 inches of clearance on each side.
11-23-2016, 06:55 PM | #286 |
Looks like I found some new reading material!! Just discovered this thread... Haven't forum'd in a while.
11-27-2016, 11:27 AM | #287 |
Sofa King Crazy!!
Now you are one of the cool kids! 😂 Glad you are back on!
11-27-2016, 08:16 PM | #288 |
Cool build. Im looking forward to seeing the finished product.
12-01-2016, 12:38 PM | #289 |
I love the new choice in wheels. I had a very similar problem with billet specialties but I was so frustrated I gave up on billet wheels all together!
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
12-02-2016, 01:13 AM | #290 | |
12-07-2016, 12:58 AM | #291 |
Sofa King Crazy!!
12-07-2016, 01:00 AM | #292 |
Sofa King Crazy!!
I almost did. Raceline..........what a headache! Reconsider if it's not too late!
12-16-2016, 03:24 AM | #293 |
Sofa King Crazy!!
Three pics to fit it all in. 61 pieces I took to the powdercoater last weekend. Can't wait to see this back together!!!!
12-16-2016, 08:52 AM | #294 |
That'll Look awesome Once it's all Back Under the body.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
12-16-2016, 11:17 AM | #295 |
A guy with a truck
Funny seeing all those parts after being exposed to humidity
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-16-2016, 01:24 PM | #296 |
Where does the big nut go???
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
12-17-2016, 02:45 AM | #297 |
Sofa King Crazy!!
All nice and hidden. Lol. I'm excited for sure!
Yeah, that's the good ole Texas weather. 😕 😂😂😂 That's a drink holder for my buddy. It's an 18lb nut. It doesn't slide on carpet and your beer status safely inside.
12-26-2016, 08:53 PM | #298 |
Sofa King Crazy!!
Trying to figure out how to get this 90 degree hydroboost set up correctly. Seems to be off center and probably needs to have the arm cut and welded in a new position. Anyone got pics??
12-26-2016, 10:51 PM | #299 | |
There's an old build thread that has one installed, but it will take me some time to dig it out. In the meantime here is the thread where Scott's showed an install after they made them available for sale:
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
12-27-2016, 10:30 AM | #300 |
I have noticed that alot of Guy's are going the Hydraboost direction.
(I'm NOT telling anyone how to build their rig) but in my personal experience I had a Hdraboost system go out while driving and you not only lose you Brakes but your Steering as well at the same time! It was the scariest thing I've had happen in along time. JMO Guys! I wouldn't want to see anyone get hurt or worse. Mark...
