Old 06-20-2016, 12:07 PM   #76
Kim57
Kim57's Avatar
Re: New 1958 Project
Looks real good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-22-2016, 08:56 PM   #77
corvettruck
corvettruck's Avatar
Yes I did measure the Corvette specs prior to disassembly, however, after the move, I have no idea where they are!!
Found an old picture with 26 degree reference for the rear mounts, pretty sure I made a cut in the frame for the front K member to sit in, welded it back at 13 degrees with the frame rails level.
Be happy to measure anything you need
corvettruck is offline   Reply With Quote
Old 06-25-2016, 09:20 PM   #78
corvettruck
Back on all fours!! Couple of hang ups getting the rear end back under it, all good now, a few photos
Old 06-25-2016, 09:42 PM   #79
Kim57
Kim57's Avatar
Very nice.
Kim
My build thread
Old 07-10-2016, 07:48 AM   #80
corvettruck
Driveshaft will be done Wednesday, exhaust to follow, started blasting the cab, got some epoxy primer on some parts, slowly but surely!!
A few photos
Old 07-10-2016, 08:14 AM   #81
dug224
dug224's Avatar
Great progress...dug
dug224 is offline   Reply With Quote
Old 07-10-2016, 10:54 AM   #82
Kim57
Kim57's Avatar
Looks real good.
Kim
My build thread
Old 07-10-2016, 01:47 PM   #83
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Love the TPI!!
ChuckDriver is offline   Reply With Quote
Old 07-10-2016, 08:06 PM   #84
joedoh
joedoh's Avatar
I missed a tuned port corvette engine on craigslist a couple weeks ago out of sheer stupidity. yours looks so good I may just kick myself a few more times.
Old 11-27-2016, 07:22 PM   #85
corvettruck
Back to working on the truck, got a start on the front sheet metal, terrible fitment, but we will get there, got the doors blasted, bottom of cab blasted, got a few parts in epoxy primer, will start on the cab patch panels this week, trying to get the cab all in primer before the end of the year, a few photos
Old 11-27-2016, 07:23 PM   #86
corvettruck
Couple more
Old 12-01-2016, 12:08 PM   #87
Scottish58chev
Looking good. Some really nice work
Scottish58chev is offline   Reply With Quote
Old 12-14-2016, 10:23 PM   #88
corvettruck
Got a little work started on the lower hinge pocket, door has a good start to fitting, step,cab corner, and cowl parts to follow, them both left and right side floor patches
Old 12-15-2016, 03:38 PM   #89
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Old 01-01-2017, 08:51 AM   #90
corvettruck
Happy New Year all!
Got a full day in the shop yesterday, drivers side lower hinge mount area an absolute mess, got all of the rot cut out and lower hinge mount landed, will finish inner and outer hinge pocket patches today, a few photos
Old 01-01-2017, 12:05 PM   #91
Kim57
Kim57's Avatar
Repair is looking good.
Kim
My build thread
Old 01-01-2017, 03:39 PM   #92
ChuckDriver
Nice work!
Old 01-01-2017, 05:47 PM   #93
svr
svr's Avatar
Hi Corvettruck, I'm working on a simular set up for my '57 useing an '86 suspension that i didnt get to take off from the corvette so I'm guessing just what angles ect everything was on the car. I see you built your own mounts for your corvette suspension. Would you do it again or go with purchased brackets and cross member? It doesnt look that hard just have to get things in the right spot. You are useing the vette leaf springs instead of coil overs, your setup does save a lot of money. Talk to me about how it all is working out for you and what if anything you would do different, Thanks, Blake
svr is offline   Reply With Quote
Old 01-01-2017, 09:48 PM   #94
corvettruck
Would definitely do it again to just build the brackets myself, the K member is a very good fit in the frame, all the other brackets are simple measurements.
I'd be happy to measure anything you need, the rear has a large amount of ride height adjustment, the front not so much.
Looks like the front will be where I want it when all of the weight is on the front
Good luck with yours
Old 01-01-2017, 11:27 PM   #95
svr
svr's Avatar
Thank you im sure ill have a bunch of questions, getting the frame stripped now, weather crappy, temps in the teens and wind to 40 with light snow blowing around.
Old 01-05-2017, 08:55 PM   #96
corvettruck
This truck has not had 2 doors on it since 2007 by previous owner!!
Gaps are not too bad to start, hope to finish metal work on cab this weekend, a few photos
Old 01-05-2017, 10:24 PM   #97
svr
svr's Avatar
Hi Corvett, if you wouldnt mind a question or 2, what do you have for a measurement from the center of the batwing to the center of the tires or drive axle? Also once the bat wing is located and pinion angle set to same as engine/trans angle the dog bones fall into place? Or is there an angle i need to figure out. Thanks for your effort when ever you get time. Blake
Old 01-06-2017, 06:31 PM   #98
BIGglaSS
BIGglaSS's Avatar
Sorry to hijack a build thread...
Blake, the dog bones should intersect and land on the instant center. Check out this link that shows how to find instant center on IRS.
http://www.corvetteforum.com/forums/...so-much-4.html
You can lay it out on the floor in full scale, then build your brackets off of that. Here is how I did it.
http://www.trifive.com/forums/showpo...6&postcount=55
BIGglaSS is offline   Reply With Quote
Old 07-28-2017, 11:42 AM   #99
corvettruck
Back at it finally, have the bed completely mocked up, took me forever to land the rear bumper brackets and roll pan, happy with the result, pass door fitted now, still plugging away on the cab, could not get the front fenders close enough for me to be happy, going to try a set of AMD fenders, should be here next week.
Everybody likes pictures, here's a few
Old 07-28-2017, 06:51 PM   #100
Kim57
Kim57's Avatar
Looks good.
I really like the bed wood.
Kim
My build thread
