Old 12-29-2016, 06:31 PM   #1
Curt - TN
1950 Radiator Selection LS 5.3 (2 or 3 core)
I am looking for recommendations on radiators with electric fans for a 1950 Truck. I am doing a 5.3 LS/Vortec swap so I will need to work around adding a steam pipe connection.
I just ordered a lower swivel water inlet and thermostat so I can mate up to most any lower outlet direction. I think I can make the center top hose work fine. I will be adding vintage air to the truck.
I did some searches on the forum and it seems Champion is quite popular but I see very few people adding steam pipes to the radiator. I have seen one drill and tap the water pump.
I called Champion and they were trying to get me to do a 3 core instead of a 2 core along with the 2100 CFM SPAL fan. I am also waiting on a quote for the steam pipe bung to be installed.
This is a fairly stock engine with under 400HP, are you all running a 2 or 3 core set up?
I had a 56 Corvette with an LS6 and it worked fine with a 2 core.
Curt
Brentwood TN
1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260
1957 GMC 100
Curt - TN is offline   Reply With Quote
Old 12-29-2016, 07:03 PM   #2
Advanced Design
Advanced Design's Avatar
Re: 1950 Radiator Selection LS 5.3 (2 or 3 core)
Curt, I was looking at going with this company for the radiator. Iceburgh used one in his LS build and had good luck with it.
http://www.rndfabrication.com/ChevyGMC47-54.html
They build in the steam vent.
Another option I've used on my last LS build was PRC radiator. It has worked well for a number of years. http://www.prchotrod.com/products/ch...-radiators.php
I am going to have them include Spaal fan and shroud as well whichever one I finally choose.
Advanced Design is offline   Reply With Quote
Old 12-29-2016, 07:54 PM   #3
b00sted
b00sted's Avatar
I have the fan, shroud and radiator in my 49 and the truck stays at 185 all the time. Summer in GA is hot.. Never an issue with temps... I have had great results with the Champion radiators in many different cars.
No steam pipe and no issues at all.
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 12-30-2016, 08:23 PM   #4
47 Fasttoys
47 Fasttoys's Avatar
The steam pipe is basically only used for burping the air from the top of the heads after refiling the cooling system or changing out a system components. In the early engines they had steam ports at the front and rear of both heads, later only at the front. Many guys plug them all and have no issues. The last LS swap I did I had a friend weld in a bung for the steam line at the local tech collage. They did it for free. As for 2 or 3 core? I run a 2 core with no cooling issues at all. In my case AC, 4.8L hauling 2.5 tons around.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 12-31-2016, 12:01 PM   #5
Hampshire
Hampshire's Avatar
I installed the PRC radiator with a Spal fan a couple years ago (though with a 350 SBC). Nice folks to work with & made in the USA. Perfect fit and excellent operation.
Hampshire is offline   Reply With Quote
Old 12-31-2016, 11:02 PM   #6
torchlight
torchlight's Avatar
I used a direct fit option for my 53 (with a 5.3) from US Radiator. Did the same as you are planning with a swivel neck for the lower radiator hose, etc. Has worked nice. However, if I had to do it all over again, I would call Walker. I have heard that they offer a direct fit radiator for our trucks that looks stock but has the outlets in more convenient locations for LS motors. Also available with built in transmission cooler and A/C condenser. Not show on their website though - something you have to call and ask about. Or so I've heard.
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 01-02-2017, 06:53 PM   #7
Erics51chevy
I bought this radiator for my 51 3600. Fits like stock. 4 core with a fan and trans cooler for that price, i couldn't pass that up. I am running another external trans cooler as well. Mechanical fan pulls more air though but there isn't enough room for it.
http://www.ebay.com/itm/162272040183...%3AMEBIDX%3AIT
Erics51chevy is offline   Reply With Quote
Old 01-06-2017, 04:22 PM   #8
youngrodder
youngrodder's Avatar
Its funny, I checked out this link the other day and the radiators were sold out for I think $286.00. Now they have (3) available for $586.00 each. Ouch, some price hike or did I look at it incorrectly the first time.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-06-2017, 04:24 PM   #9
Curt - TN
Marc
HAHA, I looked at the link and saw the $586 price so I have still been looking
Curt
Brentwood TN
1957 GMC 100
Old 01-06-2017, 04:53 PM   #10
joedoh
joedoh's Avatar
I said this in another radiator thread and he was looking for a nicer radiator, but I did some thumbnail measuring of a 2010-2014 chevy colorado 5.3 radiator and it was 22" wide x 19 tall so it SHOULD fit against the stock rad shroud. best of all its already made to cool a 5.3 so it might already have the steam pipe connection and there is a matching size AC condenser available with compatible fittings if you plan to run AC. its a top tank type, so easier to fit than a side tank type.
Old 01-06-2017, 10:18 PM   #11
Advanced Design
Great idea. Curt, can you do a video on fab and install?
Found one here...I think...http://www.rakuten.com/prod/oem-2596...FUlNfgod1oEIAw
Old 01-07-2017, 11:46 AM   #12
joedoh
joedoh's Avatar
wow I had only seen plastic tank radiators, and I will be honest I clicked the link thinking it would be several hundred dollars, not $145. I think I am going to put a tape on my 41 radiator support today and see if that fits. nice find!
Old 01-09-2017, 07:28 PM   #13
Erics51chevy
http://www.ebay.com/itm/FIT-Chevrole...RYSkdf&vxp=mtr
Thats better. Not 500 some haha.
Old 01-09-2017, 09:58 PM   #14
Curt - TN
Cool, that is not bad at all, I have to figure out an electric fan.
I came across this to go on the upper hose to take care of a steam pipe provision. They also offer a number of different hose size adapters.
http://jagsthatrun.com/Pages/Parts_Cooling_LSI-tee.html
Curt
Brentwood TN
1957 GMC 100
Old 01-09-2017, 10:31 PM   #15
youngrodder
Check out Cooling Components fans.http://coolingcomponentsinc.us.com/portal/
They are slim and move a lot of air. They offer a 2 speed fan controller. It comes with a plastic shroud as well. On my 48 truck I didn't have a lot of room with my LT1 motor and this fan fit really moves air. I was having cooling issues but this fan solved it. The is also pretty quiet.
Great customer service and I will probably run one on my 53 Suburban
Marc
Old 01-09-2017, 11:37 PM   #16
iowaboynca
iowaboynca's Avatar
What do people think of this one from Eastwood? I've been thinking...
http://www.eastwood.com/maxx-power-t...arent_id=50912
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 01-10-2017, 08:16 AM   #17
b00sted
b00sted's Avatar
I guess I am not in the norm. I fill my ls first without a tstat. Then install the tstat and fill the radiator. No need for the steam pipe thing.I like the champion solution as it allows me to spend money on other things as I am not rich....
Good luck with your choice...
