05-15-2017, 07:38 PM | #126 |
Re: What did you do to your truck today part IV
Working on the roof.
05-16-2017, 10:15 AM | #127 | |
simple enough fix; Take the sway bar apart and shorten the sleeves by 1/2" |
05-16-2017, 10:48 PM | #128 |
Thanks for the heads up i will check on it this weekend.
05-21-2017, 03:38 PM | #129 |
Just scored these truck ralleys for $100 for all 4. 15 x 8
1981 K10 (4.8 / 4L60E swap) 1982 C10 (5.3 / 4L80E swap) 1985 C20 Suburban (454 / 4L80E) |
05-21-2017, 05:36 PM | #130 |
That's what I'm going to run on my truck, like the center caps, what are they off of.
05-21-2017, 05:42 PM | #131 |
Not really sure, the guy said they were on his '85 C10 when he bought it. They are in really good shape too....
05-21-2017, 11:31 PM | #132 |
Thats the same wheels I have on my burb. They came off of an 86 Suburban. Kind of hard to see but I temporarily sprayed them silver until I can get them back to original. Also going to make my center caps all chrome. Saw the how to on Youtube
05-22-2017, 08:54 AM | #133 |
finally home for a couple weeks so lets see what I can get done, so far the fire wall is painted will pick it up today, got ebrake mounted
Posted via Mobile Device |
05-22-2017, 11:48 AM | #134 |
If you fail at your attempt to do something did you still get something done.
Spent the day trying to figure out why my tail lights are not working. And yes I checked the ground |
05-24-2017, 07:57 PM | #135 |
Tried to road trip her, she had other plans...
full story coming to my build thread soon
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
05-24-2017, 08:51 PM | #136 |
My buddy put those rally wheels on his 68 SWB. Ordered a set of clips that bolt in where the 3 screws that hols the rally cap go on. Has a set of mid 50s Chev pickup caps coming to install. Painted the wheels whits with a narrow trim ring. Will try to get a pic in a week or two when all together. I think they will look really good.
05-24-2017, 09:11 PM | #137 |
Finished the CPP disc brake upgrade on my 1965 Short Step. Captainfab firewall adapter plate, 1995 Blazer brake booster and MC, Speedway pushrod extender with Heim joint, Summit Racing brake bias (but has Wilwood name - cast into the metal) so I can fine tune the rear brakes.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
05-24-2017, 09:30 PM | #138 |
got cab on and started on master cylinder and pedal and shifter
05-25-2017, 03:37 PM | #139 |
05-25-2017, 03:45 PM | #140 | |
05-25-2017, 03:47 PM | #141 |
I think he seen the shifter in your truck
05-25-2017, 03:54 PM | #142 |
05-25-2017, 04:07 PM | #143 |
05-25-2017, 04:29 PM | #144 |
Moderator
I took the brake pedal bracket from inside the cab, laid in on carpet sideways.
Installed the brake pedal spring and return bumper. Mounted captainfabs bracket to it. Mounted the power brake booster to that. Then built out the brake pedal pushrod to the correct length, with adjustment left of course. That way I didnt have to do it in the truck after their done painting it. Just wish I took pictures.
05-26-2017, 06:11 PM | #145 |
http://67-72chevytrucks.com/vboard/a...&d=1495836428e
old and new pictures of wheels and tires I had on my 64 panel, old wheels and tires were 16.5 , new ones are 17 inch |
05-26-2017, 06:25 PM | #146 | |
Good lord I love these wheels!!!
1966 Chevy C10 Not named yet, help! 1984 GMC 4x4 SB "The Hunter" My 66 C10 fun build: http://67-72chevytrucks.com/vboard/s...d.php?t=738705 |
05-26-2017, 06:29 PM | #147 |
Out of all the things on my build, this one is what I am most proud today! lol the painted white shifter ball
05-26-2017, 10:22 PM | #148 |
Added another option.....my Bing Crosby Option.
http://s1299.photobucket.com/user/jb...23904108567829 |
05-27-2017, 12:26 AM | #149 |
so today I got the hydro boost plumbed and the new wiper motor installed
05-27-2017, 05:11 PM | #150 |
Finally got the crossmember parking brake set up remove, cleaned up and re-installed and I have a parking brake now!
I'm pretty sure I put everything back correctly. |
