LS Cooling Issue
Just completed an LS 6.2 swap in my 71 GMC
Unfortunately, I'm having cooling issues. I was hoping to get your thoughts on my setup. I have a large capacity radiator with overflow and dual fans that seem to kick on ~200 deg. For now I am just using distilled water and a little coolant. Just started to run long enough to get an initial road test. On my recent road test the temp bounced from 180 all the way as high as 240 maybe even 260 and would not fall off while driving. This is obviously way too hot, dual fans come on etc. I suspect from reading other posts this could be due to an air pocket and that I need to "burp". I also wanted to post some pictures of my setup in case something looks odd. Additional possible concerns - (overflow is to low, steam port is to low, steam port is introducing air, heater core has introduced air, wired dual fans with pigtail directly to GMPP controller cfan output) Filled coolant through radiator not through engine hose. Never opened up heater until yesterday when heat started to climb. Thanks for any thoughts or comments. Last edited by MotoWells; 07-25-2017 at 05:51 PM. |
![]() ![]() Join Date: May 2015
Re: LS Cooling Issue
yep...air pocket...common issue...remove top hose from the radiator and fill engine thru the top hose...I tied the hose up and just kept filling until it wouldn't take any more.make sure all air is out .then reinstall hose and you should be good..
Thanks for the quick response Mongo! I will attempt to fill through radiator hose and report back.
I had this problem on my last swap. Had to fill thru the hose and it took another gallon...
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Yep that should take care of it. Just fill the block thru the upper hose.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Thanks guys, hoping to get out to the garage before Friday to test. I will be sure to give an update.
The little voice in the back of my head said you screwed up your new motor. Anyone know if these are fairly forgiving after running that kind of temp? It was not for long, maybe 6-7 miles before pulling back in the garage and washing down the rad with water. Last edited by MotoWells; 07-25-2017 at 11:59 PM. |
meowMEOWmeowMEOW
Depends if your coolant sensor was reading a coolant temp, or trying to measure the temp of the air pocket. Do you have any signs of coolant coming out of places it shouldn't? (look for white residue on aluminum on the heads), and make sure there isn't any coolant in the oil. If you didn't pop an HG, your probably alright. When these get hot the ECM will pull a ton of timing to prevent det. and hitting the Kr* count.
Did is sputter/limp on its way home?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Everything seems to be ok, no coolant out of weird places that I can tell. Have not checked the oil for milkyness yet.
I had a faint hint of steam from the overflow at one point but that was a very limited time, maybe 1-2 minutes. It did seem to detune a little right before I hit the driveway, not as perky as it was heading out but that could have been hypersensitivity to the situation. Figured if it did it was a fail-safe kicking in? I'm running the GMPP controller. Thanks everyone! |
#9 | |
meowMEOWmeowMEOW
Scan the ECM with a code reader and see what it threw. Then clear it all off ( half of the codes can be false triggers from the air bubble and temp issues. I'd consider changing the oil out anyway, even if it looks ok.
I'd say if it's running alright now then its going to be fine. I don't know how many people remember this, but GM themselves used to say in the brochure for the Camaro in about 98 or 99 that the LS1 was capable of being driven up to I think 50 miles with no coolant at all since the computer would deactivate cylinders to try and keep it cool. I never tried it, and they don't mention it anymore so not sure how true it is but I would think they did test it out and just dont say it anymore to keep idiots from doing it!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Worked on the truck today and unfortunately don't have much forward progress to report. Here is what I did.
1st - Unclamped the top hose and slowly filled the truck, went for ride with heater blasting and temp slowly climbed, longest its taken to get to 220 but it got to 220. Fans kicked on... 2nd - Parked at a significant incline with nose up. Stuffed a funnel down the radiator cap and slowly filled as temp rose. Shut it down, waited and then took it for a drive. Temp rose steadily until I pulled back into garage - 220-230 degrees - fans kicked on. 3rd - Pulled hoses off heater core. Made a loop back. Burped system, again using the top hose technique. Temp rose steadily, tried to burp any introduced air with funnel as well. Took out for a test spin, water quickly went to 180 and then slowly waltzed into 210-220...fans again. 4th and final - Pulled hose off the steam port and verified coolant was coming out as I topped off fill. Temp quickly climbed to 230...fans..shut it down and parked it. Not much more time in day between waiting for cool downs. Any thoughts on what to try next? Radiator is an RND Early Crossflow radiator with dual 12 inch fans. Both top and bottom hoses are on the same side. I pulled the lead from the GMPP controller and pigtailed to both fans, is that ok? They dont seem to pull a lot of air (cfm's) through the rad. I have a healthy 14 volts to the battery. Some thoughts I had on next steps... 1 - Remove thermostat and attempt to run wide open? 2 - Should I get one of the special funnels made for burping air (image attached)? 3 - Get special controller from painless for wiring up fans (image attached) 4 - Replace RND fans with something else? Thank you! Jeff Last edited by MotoWells; 07-27-2017 at 12:43 AM. Reason: Added more pics |
what are you controlling your fans with..mine are run thru my ecm by way of my psi harness and relays. ...fan1 kicks in at 175 and fan2 comes in at 185...my temps never go over 185-190..thats the way my tuner guy set it up...just keep in mind that LS engines run at higher temps than the ol smallblock...215-220 is not uncommon for LS..
you might try wiring fans "on" from initial start with cool engine and see what happens Last edited by mongocanfly; 07-27-2017 at 06:19 AM. |
Thanks Mongo, that's a great suggestion. Just hard wire the fans from the start to see if that helps.
My GM ECM has a wire output for fans and that is what I am currently using. I took that wire and wired them to the two fans. Those two fans come on around 200 deg. I agree, the LS run hotter and seem to make more power with some heat. My only concern is that the temp never stabilizes. I just keeps getting hotter. I shut it down around 220 as I am a bit skiddish after Mondays trials and running 20-30 deg warmer than that. I am fairly confident it will keep climbing and never recover. On a side note - Any recommendation on ECM reader? I agree BR3W CITY, I should probably read and clear any codes. That might help diagnose as well. |
Where is your temp sender located? Is it boiling over at all? If not are you sure the gauge is accurate? If you can it would be nice to see what temp the ECM is seeing.
#15 | |
Thanks, Jeff |
#16 |
I am considering picking up one of these to double check parts of motor and radiator, worth it?
#17 |
One last thing I thought I would add that I forgot to mention in my update. The initial run I did after burping the coolant, I had the heater on full blast. That seemed to keep everything fairly happy at 200 if not a bit less for a majority of the time.
As I was getting closer to home I turned off the heater and the heat started to climb. Not sure if it was coincidence or not but the heater on full blast with initial run and burping did have the most stable results thus far. |
#18 |
meowMEOWmeowMEOW
Are you running the fans directly off the output wire on the GMPP controller? Does it require a relay? Running fans directly off the signal wire may not provide enough power.
Was it tuned at any point, or is the controller plug-n-play. A cheapo ECM scanner from Harbor Freight will give you the codes. If you want to read/watch things like temp PID's, you'll need a more advanced scanner, or access to something like HP Tuners. The heater core hoses come right off the waterneck where the Thermostat is, so it might be worth bypassing the heater core and seeing what changes.
#19 | |
![]() Join Date: Apr 2005
I think it has something to do with the Dakota digital gauge/sender. Where is it installed? Mine is really close to my headers which throws it off somewhat. Did you use a lot of Teflon on the threads? This can mess with the grounding of the sender which will cause an inaccurate reading. A good scanner will help you figure this out.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-27-2017 at 10:27 AM. |
#20 |
Sounds to me like you might still have an air pocket in the back.
Best way I found to get "ALL" the air out is to remove the radiatior cap, open the overflow bottle lid, and take the steam port line off at the engine. Then jack the vehicle as high up in the air as possible so that the top the rad. cap is much higher than the rear of the motor. Fill all up and let it sit. about every 15 minutes add any water that it needs to keep it full. What this will do is allow the water near the top of the rad. to migrate into the back of the LS motor steam passages and it will displace (push) any trapped air towards the front and out the steam passage at the front of the motor. As soon as you see solid water coming out of the front steam passage you are done, put that line back on and lower the vehicle. Usually takes me about 30 minutes, and works every time. If it's still going past 230 you have another problem, but 220 is fine with these motors. They like to run 220+ when AC is on.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#21 | |
#22 |
Also, forgot to mention, cross check the Dakota Digital LED readout of the temp with what the analog gauge is saying. They should be pretty close.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#23 |
I just remembered also that my tuner guy had my fan settings messed up when he did my ecm...my ecm was from a truck and it wouldn't control 2 fans..I sent it back to him and he straightened it out...one fan would run full speed but fan 2 would just barely run..works great now..
#24 |
one other thing, are you running the stock thermostat?
#25 |
Since I couldn't see the answer, I've got to ask a basic question: are the fans running at max?
If your engine is >220F and your fans aren't on, that's the problem. I'm guessing that's what's going on, and that you/we believe the engine ECM is not seeing the same temps as the gauge? I would definitely get HPTuners or some kind of scan tool on there to see what the engine is seeing. You need to know if the fans are being commanded on, and if not, why not. And if they are, why they aren't running. Unless the fans ARE running at max at that point, but I couldn't deduce that from my scan of the thread. For my LS swap I let the stock ECM control the fan outputs and then connected those to a three-relay setup so that it runs them in stages: - Both fans on LO - One fan on HI - Both fans on HI Even with an old school BeCool aluminum radiator I had left over the from the old big block it never gets past the "One fan on HI" stage. I've never needed both fans yet, even in heavy stop and go traffic.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
